[Qgis-user] Grass V.clean error in 3.2
Mensio Federico mensio at ipla.org
Wed Aug 22 02:53:21 PDT 2018
It was my fault when i wrote the PATH variable in the user custom variables.
QGIS 3 does not find external tools needed for Processing. Some
configuration options are missing. A workaround is to use QGIS custom
variables. Open QGIS Preferences → System.
- Under the *Environment* section, turn on *Use Custom Variables*.
- Add (+) a variable
- Select *Prepend* from the *Apply* popup
- Enter *PATH* for the variable
- For the *Value* enter:
/Library/Frameworks/Python.framework/Versions/3.6/bin:/Library/Frameworks/GDAL.framework/Versions/2.2/Programs:
- Quit QGIS 3 and start it again
Il giorno mer 22 ago 2018 alle ore 10:45 Paolo Cavallini <
cavallini at faunalia.it> ha scritto:
> Please share your solution here.
> Thanks.
> On 08/22/2018 10:42 AM, Mensio Federico wrote:
> Solved.
> Il giorno mar 21 ago 2018 alle ore 11:59 Mensio Federico <mensio at ipla.org>
> ha scritto:
>> V.clean still continue to not working...
>> 2018-07-29 10:42 GMT+02:00 Mensio Federico <mensio at ipla.org>:
>>> Some news?
>>> 2018-07-18 12:13 GMT+02:00 Mensio Federico <mensio at ipla.org>:
>>>> Hi everybody, when i use v.clean command in Qgis 3.2 the tool doesn't
>>>> work, it's interrupt itself with this error:
>>>> processCommands end. Commands: ['g.proj -c proj4="+proj=utm +zone=32
>>>> +datum=WGS84 +units=m +no_defs"', 'v.in.ogr min_area=0.0001 snap=1.0
>>>> input="/var/folders/_p/g0dpln352f7fw6mpryz77ddc0000gn/T/processing_a9636d257dac447bbd86f8483cd9eaa0/87b5209a7b6f4603ba16aaef38245d5a/input.shp"
>>>> output="vector_5b4f11ea685cf4" --overwrite -o', 'g.region
>>>> n=5067532.390799999 s=4905848.379899999 e=515019.39460000023
>>>> w=350249.30290076975', 'v.clean input=vector_5b4f11ea685cf4
>>>> type="point,line,boundary,centroid,area,face,kernel" tool="break"
>>>> output=output87b7c1f374d74e19bacb102a76d633e3
>>>> error=error87b7c1f374d74e19bacb102a76d633e3 --overwrite']
>>>> Anyone else have the same problem?
>>>> Qgis 3.2.0 on MacOs
>>>> Federico MENSIO
>>>> IPLA spa
>>>> Corso Casale, 476 - 10132 Torino
>>>> Mobile +39.340.06.01.363
>>>> TEL +39.011.432.0443 FAX +39.011.89.89.333
>>>> mensio at ipla.org - www.ipla.org
>>>> Questa e-mail è personale e i suoi contenuti contengono informazioni
>>>> riservate ai destinatari. Pertanto la lettura, copia od altro uso da parte
>>>> di altri o qualsiasi altra azione derivante dalla conoscenza di queste
>>>> informazioni sono rigorosamente vietate e perseguibili ai sensi del Dlgs
>>>> 196/03.
>>>> Qualora abbiate ricevuto questo documento per errore siete cortesemente
>>>> pregati di darne immediata comunicazione al mittente ai riferimenti
>>>> indicati e provvedere immediatamente alla sua distruzione.
>>>> Salvaguardiamo l'ambiente: se non ti è necessario, non stampare questa
>>>> mail
>>> Federico MENSIO
>>> IPLA spa
>>> 196/03.
>>> mail
>> Federico MENSIO
>> IPLA spa
>> 196/03.
>> mail
> Federico MENSIO
> IPLA spa
> 196/03.
> Salvaguardiamo l'ambiente: se non ti è necessario, non stampare questa mail
> Qgis-user mailing listQgis-user at lists.osgeo.org
> Paolo Cavallini - www.faunalia.eu
> QGIS & PostGIS courses: http://www.faunalia.eu/training.htmlhttps://www.google.com/trends/explore?date=all&geo=IT&q=qgis,arcgis
Federico MENSIO
IPLA spa
196/03.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20180822/4d5b0428/attachment.html>
