[Qgis-user] Opening dxf files for 3D
Nicolas Cadieux
nicolas.cadieux at archeotec.ca
Sat Aug 25 20:21:15 PDT 2018
I have not worked with the 3D in QGIS 3 but I did do some work with Qgis2treejs a few years ago. As far as I know, you will not be able for visualise a dxf like you would in a CAD. Qgis was, with that plugin more like a 2.5D where the ground surface can be modelled with a raster surface and flat polygons could be extended to make buildings with a z value. Maybe I did not get to play enough with the plugin to find the proper functions... maybe QGIS 3 has more built in function? Not sure but I think you will need a real cad software in order to see a real 3D structure. There are a few OpenSource CADs, none of which I would work with professionally :( but they may be good enough for visualization. FreeCad was one. MeshLab or Cloud Compare may work with DXF. Not sure.
Please correct me if I am wrong anybody. I would like to be informed if things have changed.
Nicolas
> Le 25 août 2018 à 03:36, Grant Boxer <boxerg at iinet.net.au> a écrit :
> I am trying to import a 3D dxf for viewing in QGIS v3 either via the 3D window or QGIS2Threejs plugin. Whenever I import a dxf there does not appear to be any z data imported. Does anyone have any suggestions?
> Grant Boxer
> Perth, Western Australia
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20180825/deeead07/attachment.html>
