[Qgis-user] looking for mapping program
    Stefan Giese (WhereGroup)
    stefan.giese at wheregroup.com
    Wed Aug 29 23:03:14 PDT 2018
Hi Diane,
some thoughts to your question: QGIS would be a very good choice (or the
best!) and will be a substainable GIS for your company. You are writing
that there is only a txt export option? A quick view on the user guide
(http://static.garmin.com/pumac/XMap7Manual.pdf) shows, that xmap works
(can work) with databases and has a bulk export option, at least it can
export kml. So first, the migration process will depend on how your data
infrastrucure is organized. In general a migration process from one GIS
into an other can be a lot of work. as many GIS systems xmap distinguish
between projects (how your data is organized and displayed in the map)
and the spatial data itself. I suppose the export of the projects will
not be possible, whereas the data should not be that problem. May be it
will be worth to use the help from a GIS professional to manage the
migration process. This depends on your workflows and as described
before from the infrastructure of your data.
best regards
stefan
Mit freundlichen Grüßen
Stefan Giese
Projektleiter/Consultant
FOSS Academy Sommerschule 2018
Alles Wichtige zur Erstellung einer GDI in nur 5 Tagen erlernen!
https://www.foss-academy.com/kompaktkurse
WhereGroup GmbH & Co. KG
Schwimmbadstr. 2
79100 Freiburg
Germany
Fon: +49 (0)761 / 519 102 - 61
Fax: +49 (0)761 / 519 102 - 11
www.wheregroup.com
Amtsgericht Bonn, HRA 6788
Komplementärin:
WhereGroup Verwaltungs GmbH
vertreten durch:
Olaf Knopp, Peter Stamm
Am 2018-08-29 17:33, schrieb Diane Green:
> We currently use XMap 7 pro and are looking for a replacement package.
>  I need some feedback to see if QGIS is a good replacement.  We also
> need in the new package the ability to import the old projects from
> XMap 7 pro which does not have an export option except txt format.  We
> are a forestry based company.
> Any comments are welcome.
> Diane Green
> Qgis-user mailing list
