[Qgis-user] CRS problem for OVR file
Andre Joost andre+joost at nurfuerspam.de
Tue Dec 18 06:39:52 PST 2018
Taimur,
both files lack any CRS information. For Shapefiles, this should be in
the .prj file. Looking at the extent, it seems to be latlon degrees,
placing it on a nature reserve in Central Oman (sorry I can't read the
Arabic label on Openstreetmap, but bing imagery has AL Wusta around there).
BTW if you share shapefiles, add the .dbf/.prj/.shx files too.
The raster seems to be unreferenced. If you have a XML file containing
metadata, it might contain the necessary CRS information. The .ovr alone
is not enough.
Am 18.12.18 um 15:00 schrieb Taimur al said:
> Hi all,
> I have been trying to sort this issue im facing at the moment. I have
> 2 files, a Shp file and a OVR file (done using ArcGis). I used the
> same CRS for both of them including the CRS on the canvas, but it
> seems that they are not projecting in the correct place.
> I have attached the Shp file and sent the OVR file in my next email
> as the file is too large (WeTransfer.com). I prefer using Qgis 2.18
> Can anyone help i would really appreciate it ,
> Thank you and regards,
> Taimur
> _______________________________________________ Qgis-user mailing
> list Qgis-user at lists.osgeo.org List info:
> https://lists.osgeo.org/mailman/listinfo/qgis-user Unsubscribe:
