[Qgis-user] Issue with joining attributes by location
Berg, Neil
nberg at ioes.ucla.edu
Thu Feb 1 07:23:27 PST 2018
Hi Stefan,
Thanks for clarifying - I’ve uploaded the .shp, .shx, and .dbf files to the drive below. Hopefully this helps!
Best,
Neil
On Jan 31, 2018, at 11:24 PM, Stefan Giese <Stefan.Giese at wheregroup.com<mailto:Stefan.Giese at wheregroup.com>> wrote:
Hi Neil,
just a note to your link: if you provide shapefiles, you'll have to put at least 3 files: CC4a_RegionsSub.shp, CC4a_RegionsSub.dbf and CC4a_RegionsSub.shx. (shp contains the geometry, dbf the attributes and shx is the index between shp and dbf)..
best regards
stefan
Mit freundlichen Grüßen
Stefan Giese
Projektleiter/Consultant
FOSS Academy Kompaktkurs Winterschule 2018
Grundwissen zum Aufbau von Geodateninfrastrukturen mit Open-Source-Software
https://www.foss-academy.com/schulungstermine/kompaktkurs-winterschule
WhereGroup GmbH & Co. KG
Schwimmbadstr. 2
79100 Freiburg
Germany
Fon: +49 (0)761 / 519 102 - 61
Fax: +49 (0)761 / 519 102 - 11
stefan.giese at wheregroup.com<mailto:stefan.giese at wheregroup.com>
www.wheregroup.com<http://www.wheregroup.com/>
Amtsgericht Bonn, HRA 6788
Komplementärin:
WhereGroup Verwaltungs GmbH
vertreten durch:
Olaf Knopp, Peter Stamm
Am 01.02.2018 um 05:42 schrieb Berg, Neil:
Hi all,
I’m working with (1) a CSV file containing columns of “lat” and “lon” which represent grid cell centroids from a gridded model product over California (“loca_lat_lon.csv”), and (2) a shape file that carves up California into 12 distinct subregions (“CC4a_RegionsSub.shp”).
These files can be accessed here:
https://drive.google.com/drive/folders/1IUrpVSJYBRIoCS4vzGYK9sBEzdwZec-c?usp=sharing
I am trying to determine which grid cells reside in each of the 12 subregions (or NA/NULL if outside all subregions) using Vector -> Data Management Tools -> Join Attributes by Location. I have specified my Target vector layer as loca_lat_lon.csv, the Join vector layer as CC4a_RegionsSub.shp, the Geometric predicate as “intersects”, and am taking attributes of the first located feature, and only keeping matching records.
The issue is that the returned joined layer assigns just 1 of the 12 subregions, “Sierra Nevada Mountains”, to all grid cells, rather than different subregions (or None) to the cells.
The shape file has a CRS of NAD83/California Albers and the coordinates in the CSV file are simply WGS 84. I’ve tried resetting the latter CRS to NAD83/California Albers, but the same issue persists.
I’m using QGIS 2.18.14.
Any help is greatly appreciated. Thanks in advance!
Neil
Qgis-user mailing list
Qgis-user at lists.osgeo.org<mailto:Qgis-user at lists.osgeo.org>
List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20180201/654bd0ba/attachment.html>
