[Qgis-user] Issue with joining attributes by location
Stefan Giese
Stefan.Giese at wheregroup.com
Thu Feb 1 08:09:28 PST 2018
Hi Neil,
the problem you encountered belongs to the different projection of your
2 layers. If you want to perform an intersect you should reproject your
point layer to the same system like your zone-Layer. Just right-click on
the point layer and select "save as". in the following dialog set the
projection to the same as your california layer and load the data. then
the intersection should work..
Good luck
stefan
Mit freundlichen Grüßen
Stefan Giese
Projektleiter/Consultant
FOSS Academy Kompaktkurs Winterschule 2018
Grundwissen zum Aufbau von Geodateninfrastrukturen mit Open-Source-Software
https://www.foss-academy.com/schulungstermine/kompaktkurs-winterschule
WhereGroup GmbH & Co. KG
Schwimmbadstr. 2
79100 Freiburg
Germany
Fon: +49 (0)761 / 519 102 - 61
Fax: +49 (0)761 / 519 102 - 11
stefan.giese at wheregroup.com
www.wheregroup.com
Amtsgericht Bonn, HRA 6788
Komplementärin:
WhereGroup Verwaltungs GmbH
vertreten durch:
Olaf Knopp, Peter Stamm
Am 01.02.2018 um 16:23 schrieb Berg, Neil:
> Hi Stefan,
> Thanks for clarifying - I’ve uploaded the .shp, .shx, and .dbf files
> to the drive below. Hopefully this helps!
> Best,
> Neil
>> On Jan 31, 2018, at 11:24 PM, Stefan Giese
>> <Stefan.Giese at wheregroup.com <mailto:Stefan.Giese at wheregroup.com>> wrote:
>> Hi Neil,
>> just a note to your link: if you provide shapefiles, you'll have to
>> put at least 3 files: CC4a_RegionsSub.shp, CC4a_RegionsSub.dbf and
>> CC4a_RegionsSub.shx. (shp contains the geometry, dbf the attributes
>> and shx is the index between shp and dbf)..
>> best regards
>> stefan
>> Stefan Giese
>> Schwimmbadstr. 2
>> 79100 Freiburg
>> Germany
>> www.wheregroup.com
>> Komplementärin:
>> vertreten durch:
>> Am 01.02.2018 um 05:42 schrieb Berg, Neil:
>>> Hi all,
>>> I’m working with (1) a CSV file containing columns of “lat” and
>>> “lon” which represent grid cell centroids from a gridded model
>>> product over California (“loca_lat_lon.csv”), and (2) a shape file
>>> that carves up California into 12 distinct subregions
>>> (“CC4a_RegionsSub.shp”).
>>> These files can be accessed here:
>>> https://drive.google.com/drive/folders/1IUrpVSJYBRIoCS4vzGYK9sBEzdwZec-c?usp=sharing
>>> I am trying to determine which grid cells reside in each of the 12
>>> subregions (or NA/NULL if outside all subregions) using Vector ->
>>> Data Management Tools -> Join Attributes by Location. I have
>>> specified my Target vector layer as loca_lat_lon.csv, the Join
>>> vector layer as CC4a_RegionsSub.shp, the Geometric predicate as
>>> “intersects”, and am taking attributes of the first located feature,
>>> and only keeping matching records.
>>> The issue is that the returned joined layer assigns just 1 of the 12
>>> subregions, “Sierra Nevada Mountains”, to all grid cells, rather
>>> than different subregions (or None) to the cells.
>>> The shape file has a CRS of NAD83/California Albers and the
>>> coordinates in the CSV file are simply WGS 84. I’ve tried resetting
>>> the latter CRS to NAD83/California Albers, but the same issue persists.
>>> I’m using QGIS 2.18.14.
>>> Any help is greatly appreciated. Thanks in advance!
>>> Neil
>>> Qgis-user mailing list
>>> Qgis-user at lists.osgeo.org
>>> List info:https://lists.osgeo.org/mailman/listinfo/qgis-user
>>> Unsubscribe:https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20180201/ae084cd1/attachment.html>
