[Qgis-user] Problems building QGIS: "error: variable ‘Q_XML_EXPORT QDomImplementation’ has initializer but incomplete type"
Hernán De Angelis
dhdeangelis at gmail.com
Thu Feb 8 02:38:46 PST 2018
Hi
I recently updated my operative system (openSuSE Leap 42.3) and I am now
having problems building QGIS (2.18.16).
The error is the following:
[ 72%] Building CXX object src/plugins/georeferencer/
CMakeFiles/georefplugin.dir/qgsgcpcanvasitem.cpp.o
In file included from /usr/include/QtXml/QDomDocument:1:0,
from /usr/local/src/qgis-2.18.16/
src/plugins/georeferencer/../../core/qgsexpression.h:23,
src/plugins/georeferencer/../../core/qgsexpressioncontext.h:23,
src/plugins/georeferencer/../../gui/qgsmapcanvas.h:23,
from /usr/local/src/qgis-2.18.16/src/plugins/georeferencer/
qgsgcpcanvasitem.h:19,
qgsgcpcanvasitem.cpp:16:
/usr/include/QtXml/qdom.h:99:20: error: variable ‘Q_XML_EXPORT
class Q_XML_EXPORT QDomImplementation
To my knowledge the Qt5 environment is properly installed, with all the
corresponding devel packages and including the Qt XML libraries. I saw this
thread (*) in which it is concluded that cleaning the build directory
solved the problem, but it wasn't the solution in my case.
http://osgeo-org.1560.x6.nabble.com/Error-in-compiling-current-master-td5310725.html
I understand this is most probably not related to QGIS but to the building
environment. In any case I wonder if someone here can have a hint on how to
overcome this.
Regards,
H.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20180208/0078661c/attachment.html>
