[Qgis-user] Mac OS X testing for QGIS 3
Madry, Scott
madrys at email.unc.edu
Wed Feb 14 11:18:06 PST 2018
Hi all.
As a dedicated Mac QGIS user, trainer, and research. I want to put in a plea to keep the Mac OS development process on pace. There are many of us out there who use the Mac OS version, and we need to get these issues with matplotlib, GRASS, and others addresses so that we have a good 3.0 rollout.
I would be happy to assist with testing, thanks for all your efforts,
Scott
Scott Madry, Ph.D.
Research Associate Professor of Archaeology
The University of North Carolina at Chapel Hill
Tel 1-919-448-4493
Email: madrys at email.unc.edu<mailto:madrys at email.unc.edu>
https://scottmadry.web.unc.edu
Skype: scott madry
On Feb 14, 2018, at 12:20 PM, John Harrop <jcharrop at gmail.com<mailto:jcharrop at gmail.com>> wrote:
Burghardt,
Thanks for the pointers, they seen much more up to date than the older ones pointed to by the QGIS web site.
I’ve been trying to build from the notes since you posted your suggestion and I see what you mean about the matplotlib problem. I forked the Mac OS X build notes on GitHub and started to work on them to see if I could get a working set for the matplotlib problems but not much luck. However, I do seem to have it installed through pip or otherwise, so I worked past that step and have been trying to get CMake to configure a makefile but there are problems there as well. I fixed a missing library by manually installing but I’m now having problems with Qt5Positioning which is not being found.
its been a while since I was active in configuring build systems so I’m having to clean off the dust in my memories and learn newer versions of the systems.
I get the impression that not much has been going on with Mac OS X dev builds for at least a few months and quite a few dependancies have changed over that time. I’ll keep working on this and hopefully there are some other GIS testers also interested in the Macs.
Let me know if you are still trying to get the Mac OS X dev build working or if you have had success.
Regards,
John Harrop
On Feb 8, 2018, at 10:22 PM, Burghardt.Scholle at stadt.wolfsburg.de wrote:
Hi John,
I believe there is no current complete dmg-file for QGIS3-dev. But you can use the excellent site under [1] to install QGIS3-dev using Homebrew. Unfortunately, there are problems with the matplotlib dependency at the moment (see [2]). Yersterday I've tried to install the current version but it failed.
Even so I hope that my hints help.
Regards
Burghardt
[1] https://github.com/qgis/homebrew-qgisdev/blob/master/development/README.md
[2] https://github.com/qgis/homebrew-qgisdev/issues/50
-----Ursprüngliche Nachricht-----
Von: Qgis-user [mailto:qgis-user-bounces at lists.osgeo.org] Im Auftrag von
John Harrop
Gesendet: Donnerstag, 8. Februar 2018 19:53
An: qgis-user at lists.osgeo.org
Betreff: [Qgis-user] Mac OS X testing for QGIS 3
Hello,
Is it possible to be involved in OS X testing of the QGIS 3 beta? There are
parts of the web site that suggest it is, but I have not been able to find a web
age for up to date downloads.
Thanks,
John Harrop
Qgis-user mailing list
Qgis-user at lists.osgeo.org
List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20180214/f5be9283/attachment.html>
