[Qgis-user] Mac OS X testing for QGIS 3
David Liontooth
lionteeth at cogweb.net
Wed Feb 14 11:52:22 PST 2018
Vincent at Macports has done a great job packaging qgis3, cf.
https://trac.macports.org/ticket/55020
grass7 was just upgraded to 7.4, postgresql10 to 10.2.
qgis3 is at 20180124.
Cheers,
David
On 2/14/18 11:18 AM, Madry, Scott wrote:
> Hi all.
> As a dedicated Mac QGIS user, trainer, and research. I want to put in
> a plea to keep the Mac OS development process on pace. There are many
> of us out there who use the Mac OS version, and we need to get these
> issues with matplotlib, GRASS, and others addresses so that we have a
> good 3.0 rollout.
> I would be happy to assist with testing, thanks for all your efforts,
> Scott
> Scott Madry, Ph.D.
> Research Associate Professor of Archaeology
> The University of North Carolina at Chapel Hill
> Tel 1-919-448-4493
> Email: madrys at email.unc.edu <mailto:madrys at email.unc.edu>
> https://scottmadry.web.unc.edu
> Skype: scott madry
>> On Feb 14, 2018, at 12:20 PM, John Harrop <jcharrop at gmail.com
>> <mailto:jcharrop at gmail.com>> wrote:
>> Burghardt,
>> Thanks for the pointers, they seen much more up to date than the
>> older ones pointed to by the QGIS web site.
>> I’ve been trying to build from the notes since you posted your
>> suggestion and I see what you mean about the matplotlib problem. I
>> forked the Mac OS X build notes on GitHub and started to work on them
>> to see if I could get a working set for the matplotlib problems but
>> not much luck. However, I do seem to have it installed through pip
>> or otherwise, so I worked past that step and have been trying to get
>> CMake to configure a makefile but there are problems there as well.
>> I fixed a missing library by manually installing but I’m now having
>> problems with Qt5Positioning which is not being found.
>> its been a while since I was active in configuring build systems so
>> I’m having to clean off the dust in my memories and learn newer
>> versions of the systems.
>> I get the impression that not much has been going on with Mac OS X
>> dev builds for at least a few months and quite a few dependancies
>> have changed over that time. I’ll keep working on this and hopefully
>> there are some other GIS testers also interested in the Macs.
>> Let me know if you are still trying to get the Mac OS X dev build
>> working or if you have had success.
>> Regards,
>> John Harrop
>> jcharrop at gmail.com <mailto:jcharrop at gmail.com>
>>> On Feb 8, 2018, at 10:22 PM, Burghardt.Scholle at stadt.wolfsburg.de wrote:
>>> Hi John,
>>> I believe there is no current complete dmg-file for QGIS3-dev. But
>>> you can use the excellent site under [1] to install QGIS3-dev using
>>> Homebrew. Unfortunately, there are problems with the matplotlib
>>> dependency at the moment (see [2]). Yersterday I've tried to install
>>> the current version but it failed.
>>> Even so I hope that my hints help.
>>> Regards
>>> Burghardt
>>> [1]
>>> https://github.com/qgis/homebrew-qgisdev/blob/master/development/README.md
>>> [2] https://github.com/qgis/homebrew-qgisdev/issues/50
>>>> -----Ursprüngliche Nachricht-----
>>>> Von: Qgis-user [mailto:qgis-user-bounces at lists.osgeo.org] Im
>>>> Auftrag von
>>>> John Harrop
>>>> Gesendet: Donnerstag, 8. Februar 2018 19:53
>>>> An: qgis-user at lists.osgeo.org
>>>> Betreff: [Qgis-user] Mac OS X testing for QGIS 3
>>>> Hello,
>>>> Is it possible to be involved in OS X testing of the QGIS 3 beta?
>>>> There are
>>>> parts of the web site that suggest it is, but I have not been able
>>>> to find a web
>>>> age for up to date downloads.
>>>> Thanks,
>>>> John Harrop
>>>> _______________________________________________
>>>> Qgis-user mailing list
>>>> Qgis-user at lists.osgeo.org
>>>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>>>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
