[Qgis-user] WCS isnot working correctly
Richard Duivenvoorde rdmailings at duif.net
Mon Feb 26 07:43:59 PST 2018
Hi Pablo,
I think(!) that you have a problem with the WCS server itself. It is not
able to serve a valid GetCapabilities document.
The first thing QGIS does when you connect is try:
http://YOURSERVER/wcs?service=WCS&request=GetCapabilities&version=1.0.0
But apparently the coverage NDVI_Historico:NDVI_10_h10v10 or it's style
is broken, so QGIS retrieves a corrupt xml doc.
In Geoserver you can for every service choose to ignore 'non valid'
layers, then the tainted layers are skipped and there will always be a
valid document.
Can you share the url of the service with me/us?
Regards,
On 26-02-18 04:51, Pablo J. Zader wrote:
> Hi list
> I am using:
> Ubuntu 14.04 LTS
> QGIS 2.18.17
> I am trying to connect to the WCS service, but I have problems when
> downloading the raw data.
> Using WCS 1.0.0...
> ServiceExceptionReport version="1.2.0" > <ServiceException>
> java.io.IOException
> null
> java.lang.RuntimeException: Capabilities document generation failed on
> Capabilities document generation failed on coverage
> No input stream for the provided source
> </ServiceException></ServiceExceptionReport>
> Using... WCS 1.1.1
> The connection si correct. But...but when I want to save as, throws me
> the error: data source not supported, and saves nothing.
> Thanks in advanced
> Pablo J. Zader
> Lic. en Cs. de la Computación + MSc. en Aplicaciones Espaciales de
> Alerta y Respuesta Temprana a Emergencias
> pablo.zader at gmail.com <mailto:pablo.zader at gmail.com>
> Universidad Nacional de Córdoba
> Av. Valpáraíso s/n Ciudad Universitaria
>  skype linkedIn <http://linkedin.com/in/pablo-javier-zader-7a232125>
>     /"Los Grandes Hombres hablan sobre ideas...  Los Hombres Promedio
>     hablan sobre cosas...  Los Hombres Pequeños hablan.. de otros Hombres./
>                             /del libro Matemática estas ahí? A. Paenza "/
> Qgis-user mailing list
