[Qgis-user] WCS isnot working correctly
Pablo J. Zader
pzader at gmail.com
Mon Feb 26 08:07:07 PST 2018
2018-02-26 12:43 GMT-03:00 Richard Duivenvoorde <rdmailings at duif.net>:
> Hi Pablo,
Hi Richard
> I think(!) that you have a problem with the WCS server itself. It is not
> able to serve a valid GetCapabilities document.
> I try to make the call from the browser directly and it works correctly,
returns the document of capacities. (but only works with WCS 1.1.0 and
above). On the other hand, as I wrote below, for versions 1.1.0 and higher,
QGIS returns the list of layers (that is, the getcapabilities request works
fine!) But when trying to "Save as", it generates an error indicating that
the source of the data is not valid. What can this error be attributed to?
> The first thing QGIS does when you connect is try:
> http://YOURSERVER/wcs?service=WCS&request=GetCapabilities&version=1.0.0
> But apparently the coverage NDVI_Historico:NDVI_10_h10v10 or it's style
> is broken, so QGIS retrieves a corrupt xml doc.
> In Geoserver you can for every service choose to ignore 'non valid'
> layers, then the tainted layers are skipped and there will always be a
> valid document.
Where is the option 'non valid' ? I can not find it in geoserver...
> Can you share the url of the service with me/us?
Sorry, the access is only Intranet
> Regards,
> Regards
Pablo
> On 26-02-18 04:51, Pablo J. Zader wrote:
> > Hi list
> > I am using:
> > Ubuntu 14.04 LTS
> > QGIS 2.18.17
> > I am trying to connect to the WCS service, but I have problems when
> > downloading the raw data.
> > Using WCS 1.0.0...
> > ServiceExceptionReport version="1.2.0" > <ServiceException>
> > java.io.IOException
> > null
> > java.lang.RuntimeException: Capabilities document generation failed on
> > Capabilities document generation failed on coverage
> > No input stream for the provided source
> > </ServiceException></ServiceExceptionReport>
> > Using... WCS 1.1.1
> > The connection si correct. But...but when I want to save as, throws me
> > the error: data source not supported, and saves nothing.
> > Thanks in advanced
> > Pablo J. Zader
> > Lic. en Cs. de la Computación + MSc. en Aplicaciones Espaciales de
> > Alerta y Respuesta Temprana a Emergencias
> > pablo.zader at gmail.com <mailto:pablo.zader at gmail.com>
> > Universidad Nacional de Córdoba
> > Av. Valpáraíso s/n Ciudad Universitaria
> > skype linkedIn <http://linkedin.com/in/pablo-javier-zader-7a232125>
> > /"Los Grandes Hombres hablan sobre ideas... Los Hombres Promedio
> > hablan sobre cosas... Los Hombres Pequeños hablan.. de otros
> Hombres./
> > /del libro Matemática estas ahí? A. Paenza "/
> > Qgis-user mailing list
> > Qgis-user at lists.osgeo.org
> > List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
> > Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
Pablo J. Zader
Lic. en Cs. de la Computación + MSc. en Aplicaciones Espaciales de Alerta y
[image: skype] [image: linkedIn]
*"Los Grandes Hombres hablan sobre ideas... Los Hombres Promedio hablan
sobre cosas... Los Hombres Pequeños hablan.. de otros Hombres.*
*del libro Matemática estas ahí? A. Paenza "*
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20180226/461ceda7/attachment.html>
