[Qgis-user] QGIS Mapserver - Project administration and updates, documentation
Alessandro Pasotti
apasotti at gmail.com
Fri Jan 5 00:35:40 PST 2018
On Fri, Jan 5, 2018 at 9:27 AM, Albin Blaschka <
albin.blaschka at standortsanalyse.net> wrote:
> Hello all,
> Following an update on my Linux-Server (Ubuntu), where I have an instance
> of qgis mapserver running, I stumbled upon a small gotcha - it stopped
> working.
> The reason was simple: The binary of qgis_mapserv.fcgi got updated, but
> when I set up qgis mapserver, I followed the suggestion as described under
> https://docs.qgis.org/2.18/en/docs/user_manual/working_with_
> ogc/server/getting_started.html#installation
> under the heading "Server the project" to put a project into a separate
> directory with the .qgs file and a *Copy* of qgis_mapserv.fcgi
I think that spreading copies of the CGI binary on your directory tree is
bad practice and calls for troubles, a symlink works surely better but
there are many other ways to serve a particular project depending on the
URL (any rewrite module for your favourite server would be sufficient ).
Would you mind making a pull request and fix the documentation?
Thanks!
Alessandro Pasotti
w3: www.itopen.it
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20180105/fb458b63/attachment.html>
