[Qgis-user] ArcSDE
    Luke
    coolhandluka at gmail.com
    Tue Jan  9 14:03:50 PST 2018
Hi
SDE can configure datasets to use either the SDE geometry type or native
database geometry formats. This is up to the SDE admin to control.
The attribute data can sometimes be coded and the real values are stored as
domain values. These can be queried out within the database if necessary
using XPATH. Similarly if SDE is using versioning on datasets you need to
setup some database logic (views etc) to handle ensure you have the correct
geometry record.
So you have to do some work in most cases to prepare data to be used in
native SQL environment / external GIS product but it is possible.
Regards,
Luke B
On Wed, Jan 10, 2018 at 5:25 AM, Jorge Gustavo Rocha <jgr at di.uminho.pt>
wrote:
> Hi Jürgen,
> I suspect that you are right! I used this old modules for a one time
> job, to do the migration from SDE to Postgresql.
> I would say that it is not possible to handle SDE data directly from
> QGIS any more (using standard GDAL builds).
> But someone else might have an alternative solution.
> Regards,
> Jorge
> On 09-01-2018 16:53, Jürgen E. Fischer wrote:
> > Hi Jorge,
> > On Tue, 09. Jan 2018 at 15:45:01 +0000, Jorge Gustavo Rocha wrote:
> >> I was able to do it with ms4w_3.0.6. More details on
> >> https://gis.stackexchange.com/questions/219660/get-gdal-up-
> and-running-with-arcsde-enabled
> > But only as migration path, right?   I suppose those old GDAL modules
> don't
> > work with the current GDAL builds and wouldn't enable SDE in QGIS.
> > Jürgen
> > Qgis-user mailing list
> > Qgis-user at lists.osgeo.org
> > List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
> > Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
> J. Gustavo
> Jorge Gustavo Rocha
> Departamento de Informática
> Universidade do Minho
> 4710-057 Braga
> Tel: +351 253604480
> Fax: +351 253604471
> Móvel: +351 910333888
> skype: nabocudnosor
*Luke Bassett*
* <lukembassett at gmail.com>*Melbourne Australia
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20180110/675d3900/attachment.html>
