[Qgis-user] Generating black white from RGB landsat using Raster Map calculator?
    Richard McDonnell
    richard.mcdonnell at opw.ie
    Wed Jan 17 05:02:08 PST 2018
Chas,
The only thing I can see wrong with your equation is the lack of Brackets
Try:
(R*0.2989)+(G*0.587)+(B*0.144)
See Does that help. you should also try the QGIS Raster Calculator, see
if its an issue with the GRASS Plugin/Instillation.
Regards,
Richard
On 17/01/2018 11:52, Chas Sheen wrote:
> Richard,
> I should have made my initial query clearer.
> I am trying to output a black and white geotiff.
> Have split the original (landsat) image into RGB images.
> When I apply the expression in the capture below, and hit run, nothing
> is saved to the results directory.
> I’m assuming that my expression or something else in the raster
> calculator is wrong?
> The final product that I’m after is a xyz grid where z is the
> black-white amplitude…which I think should be relatively easy (?) once
> I have the black-white image.
> Chas Sheen
> 0448017282
> *From:*Richard McDonnell [mailto:richard.mcdonnell at opw.ie]
> *Sent:* Wednesday, January 17, 2018 7:13 PM
> *To:* Chas Sheen <chassheengeo at gmail.com>; qgis-user at lists.osgeo.org
> *Subject:* Re: [Qgis-user] Generating black white from RGB landsat
> Chas,
> Two options for splitting RGB into separate images in QGIS.
>  1. Semi-Automatic Classification Plugin, Preprocessing, Split Raster
>     Bands
>  2. Grass r-rgb (Processing Toolbox)
> Any one of these tools will split the Raster for you easy enough
> Regards,
> Richard
> On 17/01/2018 00:48, Chas Sheen wrote:
>     I split the image into R, G, B
>     Worked out in QGIS wher the Raster map calculator is.
>     Run...several times
>     No result foud in Results Directory. It runs quickly then
>     refreshes inputs and logs to blanks.
>     I'm new to QGIS....so have probably left out something basic.
>     Any clues
>     _______________________________________________
>     Qgis-user mailing list
>     Qgis-user at lists.osgeo.org <mailto:Qgis-user at lists.osgeo.org>
>     List info:https://lists.osgeo.org/mailman/listinfo/qgis-user
>     Unsubscribe:https://lists.osgeo.org/mailman/listinfo/qgis-user
> *_Richard McDonnell_*
> *GIS Specialist PgD GIS AssocSCSI*
> *OPW FRM Data Management*
> *52 Stephens Green, Dublin 2.*
> TEL: 01 6476543
> <http://www.opw.ie/>
> Email Disclaimer: http://www.opw.ie/en/disclaimer/
TEL: 01 6476543
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20180117/e8ae6f5e/attachment.html>
Name: not available
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20180117/e8ae6f5e/attachment.png>
