[Qgis-user] Qgis-user Digest, Vol 143, Issue 27
Chas Sheen
chassheengeo at gmail.com
Wed Jan 17 15:04:50 PST 2018
Thanks- problem solved.
Chas Sheeb
On 17 January 2018 at 22:43, <qgis-user-request at lists.osgeo.org> wrote:
> Send Qgis-user mailing list submissions to
> qgis-user at lists.osgeo.org
> To subscribe or unsubscribe via the World Wide Web, visit
> https://lists.osgeo.org/mailman/listinfo/qgis-user
> or, via email, send a message with subject or body 'help' to
> You can reach the person managing the list at
> qgis-user-owner at lists.osgeo.org
> When replying, please edit your Subject line so it is more specific
> than "Re: Contents of Qgis-user digest..."
> Today's Topics:
> 1. Re: Generating black white from RGB landsat using Raster Map
> calculator? (Michel Stuyts)
> ---------- Forwarded message ----------
> From: Michel Stuyts <michel.stuyts at edegem.be>
> To: "qgis-user at lists.osgeo.org" <qgis-user at lists.osgeo.org>
> Cc:
> Bcc:
> Date: Wed, 17 Jan 2018 14:33:03 +0000
> Subject: Re: [Qgis-user] Generating black white from RGB landsat using
> Raster Map calculator?
> Chas,
> If I have a color GEOTIFF and I want to show or save it as a grayscale
> GEOTIFF, I use one of these 2 solutions. Depending on the control you want
> on the color to grayscale conversion it might also be a solution for you.
> Solution 1:
> If the only thing you want to do is show a colour geotiff in grayscale,
> you can just change the properties of the layer. In the layer properties
> you go to the tab “Style”. Under “Color rendering” you will find the option
> “Grayscale”. By default the option will be set to “Off”, but you can change
> it to turn grayscale on. Try one of the three options to see what fits your
> image best. After that you can also change the values of “Brightness” or
> “Contrast” to get the best result.
> This way you won’t change anything in your source file and it won’t save a
> grayscale tiff, but it will just show your raster file as grayscale in QGIS.
> Solution 2:
> If you want to end up with a geotiff file that has the same information in
> grayscale I usually use some graphical software in the process, but for
> that you can’t use a GeoTiff, because you would loose the georeference
> information of the file. Therefore I use the following steps:
> 1. Save your geotiff file as TIFF-file with a TFW file:
> a. Right click on your source geotiff file in the layers panel.
> b. Select Save As…
> c. Select Rendered image as Output Mode
> d. Select Gtiff as format
> e. Deselect “Add saved file to map”
> f. Under “Create Options” click on the + button to add an option.
> For the newly added option you have to type TFW as “Name” and YES as
> “Value” (double click in the newly created Option cell to type in it).
> g. Click on the “Browse…” button to select a name and location for
> your grayscale TIFF file.
> h. Click on the “OK” button
> 2. Open the newly created TIFF file in graphical software like
> XnView, IrfanView or GIMP. Change the image in that software to grayscale
> and save the file.
> 3. Add the newly created TIFF file back to QGIS
> 4. Save your newly created TIFF file as a GeoTIFF file:
> a. Right click on your newly created TIFF file in the layers panel.
> b. Select Save As…
> e. Click on the “Browse…” button to select a name and location for
> your grayscale GEOTIFF file.
> f. Click on the “OK” button
> Michel
> *Van:* Qgis-user [mailto:qgis-user-bounces at lists.osgeo.org] *Namens *Chas
> Sheen
> *Verzonden:* woensdag 17 januari 2018 14:33
> *Aan:* 'Micha Silver' <tsvibar at gmail.com>; qgis-user at lists.osgeo.org
> *Onderwerp:* Re: [Qgis-user] Generating black white from RGB landsat
> using Raster Map calculator?
> Mike,
> So everything in the capture below of the Raster calculator should work? I
> cannot find any output.
> I’m in Perth, Australia so home now and away from the office and QGIS, but
> would like to get it working tomorrow.
> How do apply a grayscale to a raster? As I said, I’m new to QGIS
> Chas Sheen
> *From:* Micha Silver [mailto:tsvibar at gmail.com]
> *Sent:* Wednesday, January 17, 2018 8:39 PM
> *To:* Chas Sheen <chassheengeo at gmail.com>; qgis-user at lists.osgeo.org
> *Subject:* Re: [Qgis-user] Generating black white from RGB landsat using
> Hello Chas
> On 01/17/2018 01:52 PM, Chas Sheen wrote:
> Richard,
> I should have made my initial query clearer.
> I am trying to output a black and white geotiff.
> It's still not clear what you are asking. AFAIK, there's no such thing as
> a "black and white geotiff". You can apply any color table you want to any
> raster. You can apply a gray scale to any of the landsat bands.
> If you are trying to create a new raster from the three RGB bands using
> some expression, that should work. You can use either of three tools: the
> built in QGIS raster calculator, or thru the Processing toolbox there's
> SAGA Raster calculus and the GRASS module r.mapcalculator.
> Again, none of this has anything to do with coloring. After running the
> raster calculator, you can color the result with a gray scale color table,
> a red color table, or any other color ramp you choose.
> Have split the original (landsat) image into RGB images.
> When I apply the expression in the capture below, and hit run, nothing is
> saved to the results directory.
> I’m assuming that my expression or something else in the raster calculator
> is wrong?
> The final product that I’m after is a xyz grid where z is the black-white
> amplitude…which I think should be relatively easy (?) once I have the
> black-white image.
> After you running the calculator expression, then you can save the result
> in many formats, including gridded XYZ, ArcINFO ASCII, or many others,
> using the gdal_translate tool. This is under the Raster->Conversion menu.
> Chas Sheen
> 0448017282
> *From:* Richard McDonnell [mailto:richard.mcdonnell at opw.ie
> <richard.mcdonnell at opw.ie>]
> *Sent:* Wednesday, January 17, 2018 7:13 PM
> *To:* Chas Sheen <chassheengeo at gmail.com> <chassheengeo at gmail.com>;
> Chas,
> Two options for splitting RGB into separate images in QGIS.
> 1. Semi-Automatic Classification Plugin, Preprocessing, Split Raster
> Bands
> 2. Grass r-rgb (Processing Toolbox)
> Any one of these tools will split the Raster for you easy enough
> Regards,
> Richard
> On 17/01/2018 00:48, Chas Sheen wrote:
> I split the image into R, G, B
> Worked out in QGIS wher the Raster map calculator is.
> Run...several times
> No result foud in Results Directory. It runs quickly then refreshes inputs
> and logs to blanks.
> I'm new to QGIS....so have probably left out something basic.
> Any clues
> [image: Displaying image.png]
> *Richard McDonnell*
> *GIS Specialist PgD GIS AssocSCSI*
> *OPW FRM Data Management*
> *52 Stephens Green, Dublin 2.*
> TEL: 01 6476543
> [image: Afbeelding verwijderd door afzender.] <http://www.opw.ie/>
> Email Disclaimer: http://www.opw.ie/en/disclaimer/
> Micha Silver
> Ben Gurion Univ.
> Sde Boker, Remote Sensing Lab
> cell: +972-523-665918
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20180118/6d935ab3/attachment.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20180118/6d935ab3/attachment.png>
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20180118/6d935ab3/attachment.jpg>
