[Qgis-user] Help with cached join layer refresh using PyQGIS
Kory Roberts
kaptainkory at gmail.com
Wed Jan 31 19:50:41 PST 2018
For reasons I won't go too deeply into, unless requested, I regularly
need to run a very short PyQGIS query/filter code on 2 Spatialite layers:
query = '"id_a" IN (47, 120)'
canvas = qgis.utils.iface.mapCanvas()
allLayers = canvas.layers()
for layer in allLayers:
if layer.name() == 'Layer_A':
layer.setSubsetString(query)
elif layer.name() == 'Layer_B':
Layer_A contains a geometry field, Layer_B does not. Layer_B is a view,
which honestly is very slow to process. I have these joined in QGIS:
Layer Properties -> Joins. For performance reasons, I have "Cache join
layer in virtual memory" selected, otherwise editing is *unbearably
slow* to the point that QGIS completely locks up for long periods of time.
The issue then, is that after I run the code subsequent times (changing
for new queries), I have to go back into Layer Properties -> Joins ->
specific join, click OK (without need to change any settings) to refresh
the cache.
Probably a long way to this, but... Is there a way in PyQGIS to refresh
the cache for the join layer and just add that line in at the end of the
already existing code?
Thanks.
