[Qgis-user] Provider Error
Richard Duivenvoorde
rdmailings at duif.net
Fri Jul 13 05:53:10 PDT 2018
Depending on the type of provider, you can or can not add fields.
Eg, if I'm correct a csv file will not work.
You can see in the properties of the layer what the 'capabilities' are
of a provider.
So to make this possible, you could first create a geopackage or
shapefile from it? And then back?
Regards,
Richard
On 07/13/2018 02:25 PM, Martin Bittens wrote:
> Hello QGIS Users.
> I want to create a text field in an attribute table which contains some
> data points by using the field calculator. So I selected:
> - Create a new field
> - Output field name: Comment
> - Output field type: Text (string)
> - Output field length: 10
> - Text input: 'Area 2'
> The Output preview shows: 'Area 2'. By clicking on "OK" I receive the
> following message: "Could not add the new field to the provider"
> My system is: Windows 10, QGIS2.18.21.
> In the previous versions of QGIS I did not get that error when I added
> with the field calculator text fields in attribute tables.
> Does somebody know a solution solving the error?
> Thank you very much.
> Martin
> This email has been checked for viruses by Avast antivirus software.
> https://www.avast.com/antivirus
> Qgis-user mailing list
