[Qgis-user] Provider Error
Richard Duivenvoorde
rdmailings at duif.net
Fri Jul 13 06:28:40 PDT 2018
Mmm, that should just work.
Is the shapefile maybe in a zip?
Is it read only on the file system?
If you save it as (another) shp file, does it behave the same?
Else: can you sent me (a part of) the shp so I can test here?
Regards,
On 07/13/2018 02:57 PM, Martin Bittens wrote:
> Hello Richard,
> it is a shapefile I am working with.
> Martin
> Am 7/13/2018 um 9:53 AM schrieb Richard Duivenvoorde:
>> Depending on the type of provider, you can or can not add fields.
>> Eg, if I'm correct a csv file will not work.
>> You can see in the properties of the layer what the 'capabilities' are
>> of a provider.
>> So to make this possible, you could first create a geopackage or
>> shapefile from it? And then back?
>> Regards,
>> Richard
>> On 07/13/2018 02:25 PM, Martin Bittens wrote:
>>> Hello QGIS Users.
>>> I want to create a text field in an attribute table which contains some
>>> data points by using the field calculator. So I selected:
>>> - Create a new field
>>> - Output field name: Comment
>>> - Output field type: Text (string)
>>> - Output field length: 10
>>> - Text input: 'Area 2'
>>> The Output preview shows: 'Area 2'. By clicking on "OK" I receive the
>>> following message: "Could not add the new field to the provider"
>>> My system is: Windows 10, QGIS2.18.21.
>>> In the previous versions of QGIS I did not get that error when I added
>>> with the field calculator text fields in attribute tables.
>>> Does somebody know a solution solving the error?
>>> Thank you very much.
>>> Martin
>>> This email has been checked for viruses by Avast antivirus software.
>>> https://www.avast.com/antivirus
>>> Qgis-user mailing list
>>> Qgis-user at lists.osgeo.org
>>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
