[Qgis-user] Provider Error
Richard Duivenvoorde
rdmailings at duif.net
Fri Jul 13 07:39:42 PDT 2018
Hi Martin,
I can confirm your findings! Looks like a bug to me.
Are you able to create an issue for it on issues.qgis.org?
Else I will do it.
I'm going to compile Qgis 2.14 too, to see if it was already there...
Note that in QGIS3 it just works!
Regards,
On 07/13/2018 02:25 PM, Martin Bittens wrote:
> Hello QGIS Users.
> I want to create a text field in an attribute table which contains some
> data points by using the field calculator. So I selected:
> - Create a new field
> - Output field name: Comment
> - Output field type: Text (string)
> - Output field length: 10
> - Text input: 'Area 2'
> The Output preview shows: 'Area 2'. By clicking on "OK" I receive the
> following message: "Could not add the new field to the provider"
> My system is: Windows 10, QGIS2.18.21.
> In the previous versions of QGIS I did not get that error when I added
> with the field calculator text fields in attribute tables.
> Does somebody know a solution solving the error?
> Thank you very much.
> Martin
> This email has been checked for viruses by Avast antivirus software.
> https://www.avast.com/antivirus
> Qgis-user mailing list
