[Qgis-user] qgz format and non-ascii project names
Michel Stuyts
michel.stuyts at edegem.be
Thu Jul 19 06:51:08 PDT 2018
If I create a file called test.qgz in QGIS, rename it to tëst.qgz in Windows Explorer, and load that file in QGIS everything is loaded correct.
If I create a file called tëst.qgz in QGIS, rename it to test.qgz in Windows Explorer, and load that file in QGIS, no layers are loaded.
So the problem originates when saving the project file, not when loading it.
Michel
Van: Qgis-user [mailto:qgis-user-bounces at lists.osgeo.org] Namens Michel Stuyts
Verzonden: donderdag 19 juli 2018 15:23
Aan: Qgis-user at lists.osgeo.org
Onderwerp: Re: [Qgis-user] qgz format and non-ascii project names
Confirmed on Win10. When loading a qgz-file with special characters, the name of the project is shown in the title bar, but no layers are loaded.
Michel
Van: Qgis-user [mailto:qgis-user-bounces at lists.osgeo.org] Namens Micha Silver
Verzonden: donderdag 19 juli 2018 13:55
Aan: Qgis-user at lists.osgeo.org<mailto:Qgis-user at lists.osgeo.org>
Onderwerp: [Qgis-user] qgz format and non-ascii project names
I just noticed that a QGZ project file with non-ascii characters in the name will not open. No error message, it just doesn't open. The same project, saved as QGS opens fine, and if I save project as QGZ with only ascii characters, it also opens fine.
Can anyone confirm?
Thanks,
Micha Silver
Ben Gurion Univ.
Sde Boker, Remote Sensing Lab
+972-523-665918
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20180719/056a9b9a/attachment.html>
