[Qgis-user] google earth aerial is offset
Boaz Bar Ilan
boazprosie at gmail.com
Sat Jul 21 23:30:42 PDT 2018
hi phil
thanks for your help
yes, I take the aerial from open layers plugin and than google maps
with the quickmapservices plugin I don't see aerial option ( how to add it
with the contribution pack? )
to the second remark - I compare the aerial with reliable shp and/or dxf
layers and there is difference
thanks
boaz
2018-07-22 9:10 GMT+03:00 Phil Wyatt <phil at wyatt-family.com>:
> Hi Boaz,
> Are you using Google earth via “Open Layers plugin”? If so, check and see
> if the offset still exists with QuickMapServices Plugin (with the
> contributors pack). Is this in the map view or when you do a print via
> composer.
> Some imagery is not well aligned but it varies across the globe. How are
> you determining that there is an error – from known GPS traces or someone
> else’s data? Others may know of some way to ‘shift’ the imagery (if you
> feel that is necessary).
> Cheers - Phil
> *From:* Qgis-user [mailto:qgis-user-bounces at lists.osgeo.org] *On Behalf
> Of *Boaz Bar Ilan
> *Sent:* Sunday, 22 July 2018 2:50 PM
> *To:* qgis-user
> *Subject:* [Qgis-user] google earth aerial is offset
> hi
> I use google earth satellite layer
> it constantly comes with little offset
> what can be done ?
> thanks
> boaz
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20180722/e2730b87/attachment.html>
