[Qgis-user] QGIS3 Zonal Stat in raster Analysis fail count
Mensio Federico
mensio at ipla.org
Tue Jun 5 06:50:19 PDT 2018
Ok. I prepared the data. Because they are very large i post here the
wetransfer link (available up to 06/12) https://wetransfer.com/dow
nloads/7639472c353a5c3c151972d694fa148d20180605134054/6594c2
39a24a7e346bb3bd5b0a38533220180605134054/21473e
All vector data are stored in a Postgres DB, exported to a csv (with header
comma delimited) and they are:
grid.csv, the grid zone where i need to calculate the number of pixel
contained in the raster file uf.tif. All pixel have vale of 1
uf_qgis2.csv the result of zonal statistics using qgis 2.18.15 that is
correct
uf_qgis3.csv the result of zonal statistics using qgis 3.0.3 that is not
correct
If you compare the uf_count or uf_sum fields of the two files you can see
difference
thanks in advance for explain and eventually solve the problem
Sincerly Federico
2018-06-04 9:31 GMT+02:00 Mensio Federico <mensio at ipla.org>:
> yes. ASAP
> 2018-06-01 2:06 GMT+02:00 Nyall Dawson <nyall.dawson at gmail.com>:
>> 2018-05-31 22:34 GMT+10:00 Mensio Federico <mensio at ipla.org>:
>> > Hi.
>> > I used zonal statistics for raster analysis both in Qgis 2.18 and Qgis
>> 3.0.
>> > In the first it's work perfectly with the count of cell is correct, in
>> the
>> > second is totally uncorrect.
>> > Some solution?
>> Can you share sample data and the parameters you use?
>> Nyall
>> > Federico MENSIO
>> > IPLA spa
>> > Corso Casale, 476 - 10132 Torino
>> > Mobile +39.340.06.01.363
>> > TEL +39.011.432.0443 FAX +39.011.89.89.333
>> > mensio at ipla.org - www.ipla.org
>> > Questa e-mail è personale e i suoi contenuti contengono informazioni
>> > riservate ai destinatari. Pertanto la lettura, copia od altro uso da
>> parte
>> > di altri o qualsiasi altra azione derivante dalla conoscenza di queste
>> > informazioni sono rigorosamente vietate e perseguibili ai sensi del Dlgs
>> > 196/03.
>> > Qualora abbiate ricevuto questo documento per errore siete cortesemente
>> > pregati di darne immediata comunicazione al mittente ai riferimenti
>> indicati
>> > e provvedere immediatamente alla sua distruzione.
>> > Salvaguardiamo l'ambiente: se non ti è necessario, non stampare questa
>> mail
>> > _______________________________________________
>> > Qgis-user mailing list
>> > Qgis-user at lists.osgeo.org
>> > List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>> > Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
> Federico MENSIO
> IPLA spa
> riservate ai destinatari. Pertanto la lettura, copia od altro uso da parte
> 196/03.
> indicati e provvedere immediatamente alla sua distruzione.
> Salvaguardiamo l'ambiente: se non ti è necessario, non stampare questa mail
Federico MENSIO
IPLA spa
196/03.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20180605/d0d73e8a/attachment.html>
