[Qgis-user] QGIS3 Zonal Stat in raster Analysis fail count
Luigi Pirelli
luipir at gmail.com
Tue Jun 5 07:06:57 PDT 2018
please check if this is fixed by Nyall Dawson
https://github.com/qgis/QGIS/commit/88a49e7e331e0f728ffed8c63d99eb0f59fb2272
not sure it's related
Luigi Pirelli
* LinkedIn: https://www.linkedin.com/in/luigipirelli
* Stackexchange: http://gis.stackexchange.com/users/19667/luigi-pirelli
* GitHub: https://github.com/luipir
* Mastering QGIS 2nd Edition:
https://www.packtpub.com/big-data-and-business-intelligence/mastering-qgis-second-edition
* Hire me: http://goo.gl/BYRQKg
On 5 June 2018 at 15:50, Mensio Federico <mensio at ipla.org> wrote:
> Ok. I prepared the data. Because they are very large i post here the
> wetransfer link (available up to 06/12) https://wetransfer.com/downloads/
> 7639472c353a5c3c151972d694fa148d20180605134054/6594c239a24a7
> e346bb3bd5b0a38533220180605134054/21473e
> All vector data are stored in a Postgres DB, exported to a csv (with
> header comma delimited) and they are:
> grid.csv, the grid zone where i need to calculate the number of pixel
> contained in the raster file uf.tif. All pixel have vale of 1
> uf_qgis2.csv the result of zonal statistics using qgis 2.18.15 that is
> correct
> uf_qgis3.csv the result of zonal statistics using qgis 3.0.3 that is not
> correct
> If you compare the uf_count or uf_sum fields of the two files you can see
> difference
> thanks in advance for explain and eventually solve the problem
> Sincerly Federico
> 2018-06-04 9:31 GMT+02:00 Mensio Federico <mensio at ipla.org>:
>> yes. ASAP
>> 2018-06-01 2:06 GMT+02:00 Nyall Dawson <nyall.dawson at gmail.com>:
>>> 2018-05-31 22:34 GMT+10:00 Mensio Federico <mensio at ipla.org>:
>>> > Hi.
>>> > I used zonal statistics for raster analysis both in Qgis 2.18 and Qgis
>>> 3.0.
>>> > In the first it's work perfectly with the count of cell is correct, in
>>> the
>>> > second is totally uncorrect.
>>> > Some solution?
>>> Can you share sample data and the parameters you use?
>>> Nyall
>>> > Federico MENSIO
>>> > IPLA spa
>>> > Corso Casale, 476 - 10132 Torino
>>> > Mobile +39.340.06.01.363
>>> > TEL +39.011.432.0443 FAX +39.011.89.89.333
>>> > mensio at ipla.org - www.ipla.org
>>> > Questa e-mail è personale e i suoi contenuti contengono informazioni
>>> > riservate ai destinatari. Pertanto la lettura, copia od altro uso da
>>> parte
>>> > di altri o qualsiasi altra azione derivante dalla conoscenza di queste
>>> > informazioni sono rigorosamente vietate e perseguibili ai sensi del
>>> Dlgs
>>> > 196/03.
>>> > Qualora abbiate ricevuto questo documento per errore siete cortesemente
>>> > pregati di darne immediata comunicazione al mittente ai riferimenti
>>> indicati
>>> > e provvedere immediatamente alla sua distruzione.
>>> > Salvaguardiamo l'ambiente: se non ti è necessario, non stampare questa
>>> mail
>>> > _______________________________________________
>>> > Qgis-user mailing list
>>> > Qgis-user at lists.osgeo.org
>>> > List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>>> > Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
>> Federico MENSIO
>> IPLA spa
>> riservate ai destinatari. Pertanto la lettura, copia od altro uso da parte
>> informazioni sono rigorosamente vietate e perseguibili ai sensi del Dlgs
>> 196/03.
>> indicati e provvedere immediatamente alla sua distruzione.
>> mail
> Federico MENSIO
> IPLA spa
> 196/03.
> Salvaguardiamo l'ambiente: se non ti è necessario, non stampare questa mail
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20180605/ade940ef/attachment.html>
