[Qgis-user] QGIS3 Zonal Stat in raster Analysis fail count
Mensio Federico
mensio at ipla.org
Tue Jun 5 09:25:22 PDT 2018
But the raster and vector have the same CRS.
The raster is 20X20m, the grid 100mX100m and the two files have the same
origin.
On Tue, Jun 5, 2018 at 4:06 PM, Luigi Pirelli <luipir at gmail.com> wrote:
> please check if this is fixed by Nyall Dawson
> https://github.com/qgis/QGIS/commit/88a49e7e331e0f728ffed8c63d99eb
> 0f59fb2272 not sure it's related
> Luigi Pirelli
> * LinkedIn: https://www.linkedin.com/in/luigipirelli
> * Stackexchange: http://gis.stackexchange.com/users/19667/luigi-pirelli
> * GitHub: https://github.com/luipir
> * Mastering QGIS 2nd Edition:
> * https://www.packtpub.com/big-data-and-business-
> intelligence/mastering-qgis-second-edition
> * Hire me: http://goo.gl/BYRQKg
> On 5 June 2018 at 15:50, Mensio Federico <mensio at ipla.org> wrote:
>> Ok. I prepared the data. Because they are very large i post here the
>> wetransfer link (available up to 06/12) https://wetransfer.com
>> /downloads/7639472c353a5c3c151972d694fa148d20180605134054/
>> 6594c239a24a7e346bb3bd5b0a38533220180605134054/21473e
>> All vector data are stored in a Postgres DB, exported to a csv (with
>> header comma delimited) and they are:
>> grid.csv, the grid zone where i need to calculate the number of pixel
>> contained in the raster file uf.tif. All pixel have vale of 1
>> uf_qgis2.csv the result of zonal statistics using qgis 2.18.15 that is
>> correct
>> uf_qgis3.csv the result of zonal statistics using qgis 3.0.3 that is not
>> correct
>> If you compare the uf_count or uf_sum fields of the two files you can see
>> difference
>> thanks in advance for explain and eventually solve the problem
>> Sincerly Federico
>> 2018-06-04 9:31 GMT+02:00 Mensio Federico <mensio at ipla.org>:
>>> yes. ASAP
>>> 2018-06-01 2:06 GMT+02:00 Nyall Dawson <nyall.dawson at gmail.com>:
>>>> 2018-05-31 22:34 GMT+10:00 Mensio Federico <mensio at ipla.org>:
>>>> > Hi.
>>>> > I used zonal statistics for raster analysis both in Qgis 2.18 and
>>>> Qgis 3.0.
>>>> > In the first it's work perfectly with the count of cell is correct,
>>>> in the
>>>> > second is totally uncorrect.
>>>> > Some solution?
>>>> Can you share sample data and the parameters you use?
>>>> Nyall
>>>> > Federico MENSIO
>>>> > IPLA spa
>>>> > Corso Casale, 476 - 10132 Torino
>>>> <https://maps.google.com/?q=Corso+Casale,+476+-+10132+Torino&entry=gmail&source=g>
>>>> > Mobile +39.340.06.01.363
>>>> > TEL +39.011.432.0443 FAX +39.011.89.89.333
>>>> > mensio at ipla.org - www.ipla.org
>>>> > Questa e-mail è personale e i suoi contenuti contengono informazioni
>>>> > riservate ai destinatari. Pertanto la lettura, copia od altro uso da
>>>> parte
>>>> > di altri o qualsiasi altra azione derivante dalla conoscenza di queste
>>>> > informazioni sono rigorosamente vietate e perseguibili ai sensi del
>>>> Dlgs
>>>> > 196/03.
>>>> > Qualora abbiate ricevuto questo documento per errore siete
>>>> cortesemente
>>>> > pregati di darne immediata comunicazione al mittente ai riferimenti
>>>> indicati
>>>> > e provvedere immediatamente alla sua distruzione.
>>>> > Salvaguardiamo l'ambiente: se non ti è necessario, non stampare
>>>> questa mail
>>>> > _______________________________________________
>>>> > Qgis-user mailing list
>>>> > Qgis-user at lists.osgeo.org
>>>> > List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>>>> > Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
>>> Federico MENSIO
>>> IPLA spa
>>> riservate ai destinatari. Pertanto la lettura, copia od altro uso da parte
>>> informazioni sono rigorosamente vietate e perseguibili ai sensi del Dlgs
>>> 196/03.
>>> Qualora abbiate ricevuto questo documento per errore siete cortesemente
>>> indicati e provvedere immediatamente alla sua distruzione.
>>> Salvaguardiamo l'ambiente: se non ti è necessario, non stampare questa
>>> mail
>> Federico MENSIO
>> IPLA spa
>> 196/03.
>> mail
Federico MENSIO
IPLA spa
196/03.
Salvaguardiamo l'ambiente: se non ti è necessario, non stampare questa mail
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20180605/6cea48fb/attachment.html>
