[Qgis-user] Unable to load project
Springfield Harrison
stellargps at gmail.com
Thu Jun 7 01:04:26 PDT 2018
Hello Phil,
I would say less than 50 layers mostly shapefiles. I was hoping to be able
to tweak the project file but that appears to be out of the question except
possibly by a programmer.
Not sure what can be done next, waiting for expert ideas...
Cheers . . . . . Spring
Samsung Tab 4
On Jun 7, 2018 12:29 AM, "Phil Wyatt" <phil at wyatt-family.com> wrote:
> When you say “loads many layers”…how many are we talking about – 20, 50,
> 250? Shape files, WMS, Raster, Vector? Unknown Exception I suspect is hard
> to diagnose, especially now on QGIS 2.10 and Windows 7 which are both
> pretty old.
> *From:* Springfield Harrison [mailto:stellargps at gmail.com]
> *Sent:* Thursday, 7 June 2018 4:28 PM
> *To:* Phil (The Geek) Wyatt
> *Cc:* qgis-user
> *Subject:* RE: [Qgis-user] Unable to load project
> hello Phil,
> I did open the project file in Word, 2033 pages, and found 13 instances
> referring to the dxf file. Hard to say if anything was wrong there, nothing
> obvious. At least to me. Some other research I did indicates that maybe
> there is an authentication problem, not sure just what that boils down to.
> I don't think the dxf file is the problem. I renamed it and bypassed it on
> the startup routine which the program accepted but it still seized up with
> a spinning cursor. Some things still function, such as modifying the
> properties of a layer , Etc. But the screen is blank and nothing can be
> saved.
> For some time I have noticed that loading a project file bogs down for a
> while and then would resume to completion. Now it bogs down and blows up.
> The key message seems to be unknown exception.
> Some older project files do load successfully however...
> Samsung Tab 4
> On Jun 6, 2018 11:15 PM, "Phil Wyatt" <phil at wyatt-family.com> wrote:
> Can you open a copy of the previous project file in something like notepad
> and see if anything obvious can be fixed and or removed in relation to the
> DXF layer?
> *From:* Qgis-user [mailto:qgis-user-bounces at lists.osgeo.org] *On Behalf
> Of *Springfield Harrison
> *Sent:* Thursday, 7 June 2018 1:36 PM
> *To:* qgis-user at lists.osgeo.org List
> *Subject:* [Qgis-user] Unable to load project
> Hello All,
> Bad News. I am unable to load a project that normally works with no
> problems:
> 1. QGIS 2.10.1, Windows 7.
> 2. Project starts to load, loads many layers . . .
> 3. halts loading "point Entity", a DXF file
> 4. the DXF file was renamed to trigger the Handle Bad Layers service
> 5. this was bypassed but project loading still fails to complete,
> cursor spinner on constantly
> 6. exiting with Save triggers "Unknown Exception"
> 7. the project file is trashed to 0kb
> 8. Exiting without Save is OK but no project can be loaded
> 9. Restoring previous project file versions yields the same results
> 10. Loading some other projects works but may have cursor spinner
> Any ideas what is going on here? I have rebooted the computer.
> Thanks very much . . . .
> Cheers . . . . . Springfield Harrison
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20180607/91e36e8d/attachment.html>
