[Qgis-user] Unable to load project
Patrick Dunford enzedrailmaps at gmail.com
Thu Jun 7 01:29:51 PDT 2018
Thre are a number of troubleshooting steps to try out
1. Start up qgis using the -noplugins switch or remove all installed
plugins or test removing one at a time.
2. Backup the config file and start with a new empty config.
Qgis 2.10 is well out of support, is there any reason you can't migrate
to 3.0?
On 07/06/18 18:28, Springfield Harrison wrote:
> hello Phil,
> I did open the project file in Word, 2033 pages, and found 13
> instances referring to the dxf file. Hard to say if anything was wrong
> there, nothing obvious. At least to me. Some other research I did
> indicates that maybe there is an authentication problem, not sure just
> what that boils down to.
> I don't think the dxf file is the problem. I renamed it and bypassed
> it on the startup routine which the program accepted but it still
> seized up with a spinning cursor. Some things still function, such as
> modifying the properties of a layer , Etc. But the screen is blank and
> nothing can be saved.
> For some time I have noticed that loading a project file bogs down for
> a while and then would resume to completion. Now it bogs down and
> blows up. The key message seems to be unknown exception.
> Some older project files do load successfully however...
> Cheers . . . . .   Spring
> Samsung Tab 4
> On Jun 6, 2018 11:15 PM, "Phil Wyatt" <phil at wyatt-family.com
> <mailto:phil at wyatt-family.com>> wrote:
>     Can you open a copy of the previous project file in something like
>     notepad and see if anything obvious can be fixed and or removed in
>     relation to the DXF layer?
>     *From:*Qgis-user [mailto:qgis-user-bounces at lists.osgeo.org
>     <mailto:qgis-user-bounces at lists.osgeo.org>] *On Behalf Of
>     *Springfield Harrison
>     *Sent:* Thursday, 7 June 2018 1:36 PM
>     *To:* qgis-user at lists.osgeo.org <mailto:qgis-user at lists.osgeo.org>
>     List
>     *Subject:* [Qgis-user] Unable to load project
>     Hello All,
>     Bad News.  I am unable to load a project that normally works with
>     no problems:
>      1. QGIS 2.10.1, Windows 7.
>      2. Project starts to load, loads many layers . . .
>      3. halts loading "point Entity", a DXF file
>      4. the DXF file was renamed to trigger the Handle Bad Layers service
>      5. this was bypassed but project loading still fails to complete,
>         cursor spinner on constantly
>      6. exiting with Save triggers "Unknown Exception"
>      7. the project file is trashed to 0kb
>      8. Exiting without Save is OK but no project can be loaded
>      9. Restoring previous project file versions yields the same results
>     10. Loading some other projects works but may have cursor spinner
>     Any ideas what is going on here?  I have rebooted the computer.
>     Thanks very much . . . .
>     Cheers . . . . . Springfield Harrison
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20180607/2d81cd2a/attachment.html>
