[Qgis-user] Unable to load project
Patrick Dunford
enzedrailmaps at gmail.com
Thu Jun 7 21:01:51 PDT 2018
The Windows version of Qgis allows you to run multiple versions on your
computer side by side. I personally haven't used the Windows version for
several years so I can't be sure if you will have any issues running 3.0
alongside your current version. I run many of the editions I have in
virtual machines. If your PC has 8 GB or more of memory, or if you have
access to another computer that can run Linux, then you can try it out
in a Linux virtual machine or physical computer environment without
disturbing your current installation.
On 08/06/18 07:38, Springfield Harrison wrote:
> hello Patrick, thanks for your ideas. I will try the no plugins option.
> The program will run with no project loaded and it will run older
> project files but has problems with newer ones for the same project.
> I can load an older project file and then add newer layers to it and
> reconfigure them, Etc. This is very tedious but will amount to a
> recovery. It is better than starting from scratch for sure. But will
> the same problem reoccur?
> I have contemplated migrating to version 3 but I'm always leery of
> upgrades of anything as they often bring problems with them. In this
> list I notice many references to installation issues and things not
> running. 2.10 is a devil I know.
> can I expect any difficulties installing 3.0 +?
> Cheers . . . . . Spring
> Samsung Tab 4
> On Jun 7, 2018 1:30 AM, "Patrick Dunford" <enzedrailmaps at gmail.com
> <mailto:enzedrailmaps at gmail.com>> wrote:
> Thre are a number of troubleshooting steps to try out
> 1. Start up qgis using the -noplugins switch or remove all
> installed plugins or test removing one at a time.
> 2. Backup the config file and start with a new empty config.
> Qgis 2.10 is well out of support, is there any reason you can't
> migrate to 3.0?
> On 07/06/18 18:28, Springfield Harrison wrote:
>> hello Phil,
>> I did open the project file in Word, 2033 pages, and found 13
>> instances referring to the dxf file. Hard to say if anything was
>> wrong there, nothing obvious. At least to me. Some other research
>> I did indicates that maybe there is an authentication problem,
>> not sure just what that boils down to.
>> I don't think the dxf file is the problem. I renamed it and
>> bypassed it on the startup routine which the program accepted but
>> it still seized up with a spinning cursor. Some things still
>> function, such as modifying the properties of a layer , Etc. But
>> the screen is blank and nothing can be saved.
>> For some time I have noticed that loading a project file bogs
>> down for a while and then would resume to completion. Now it bogs
>> down and blows up. The key message seems to be unknown exception.
>> Some older project files do load successfully however...
>> Samsung Tab 4
>> On Jun 6, 2018 11:15 PM, "Phil Wyatt" <phil at wyatt-family.com
>> <mailto:phil at wyatt-family.com>> wrote:
>> Can you open a copy of the previous project file in something
>> like notepad and see if anything obvious can be fixed and or
>> removed in relation to the DXF layer?
>> *From:*Qgis-user [mailto:qgis-user-bounces at lists.osgeo.org
>> <mailto:qgis-user-bounces at lists.osgeo.org>] *On Behalf Of
>> *Springfield Harrison
>> *Sent:* Thursday, 7 June 2018 1:36 PM
>> *To:* qgis-user at lists.osgeo.org
>> <mailto:qgis-user at lists.osgeo.org> List
>> *Subject:* [Qgis-user] Unable to load project
>> Hello All,
>> Bad News. I am unable to load a project that normally works
>> with no problems:
>> 1. QGIS 2.10.1, Windows 7.
>> 2. Project starts to load, loads many layers . . .
>> 3. halts loading "point Entity", a DXF file
>> 4. the DXF file was renamed to trigger the Handle Bad Layers
>> service
>> 5. this was bypassed but project loading still fails to
>> complete, cursor spinner on constantly
>> 6. exiting with Save triggers "Unknown Exception"
>> 7. the project file is trashed to 0kb
>> 8. Exiting without Save is OK but no project can be loaded
>> 9. Restoring previous project file versions yields the same
>> results
>> 10. Loading some other projects works but may have cursor spinner
>> Any ideas what is going on here? I have rebooted the computer.
>> Thanks very much . . . .
>> Cheers . . . . . Springfield Harrison
>> Qgis-user mailing list
>> Qgis-user at lists.osgeo.org <mailto:Qgis-user at lists.osgeo.org>
>> List info:https://lists.osgeo.org/mailman/listinfo/qgis-user
>> <https://lists.osgeo.org/mailman/listinfo/qgis-user>
>> Unsubscribe:https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20180608/733ab680/attachment.html>
