[Qgis-user] Coordinate Conversion
Nicolas Cadieux
nicolas.cadieux at archeotec.ca
Thu Jun 7 05:53:14 PDT 2018
I am not sure about v.transforme but GDA94 is handled in QGIS. I imagine that this is not the case with the local projection and that you are trying to find the transformation? Usually, my way to deal with this is to contact the local governments. They normally have software to convert local grids when these are not widely used. If you have the epgs code, you could download the grid parameters and create a custom projection using the proj4 parameters.
http://spatialreference.org/ref/epsg/
Nicolas
> Le 7 juin 2018 à 00:36, Grant Boxer <boxerg at iinet.net.au> a écrit :
> I have local grid coordinates (no projection) and I want to convert it into real world (GDA94 z 50) UTM coordinates. I have 4 points with both local and real world coordinates. I have looked at using v.transform but I need a way to calculate the parameters for the transform. Any suggestions where/how I can do this?
> Grant Boxer
> Perth, Western Australia
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20180607/4090aeff/attachment.html>
