[Qgis-user] Unable to load project
Philip Barlow
philipb at pembrokeshirecoast.org.uk
Fri Jun 8 04:49:10 PDT 2018
AFAIK if you install QGIS with the standalone installer that just puts the application and everything it needs into a folder in program files. You may encounter issues if you installed multiple versions with the osgeo4w installer if you aren’t careful.
From: Qgis-user [mailto:qgis-user-bounces at lists.osgeo.org] On Behalf Of Patrick Dunford
Sent: 08 June 2018 11:01
To: qgis-user ML
Subject: Re: [Qgis-user] Unable to load project
That may be the case for the application. However, depending on the installation, shared libraries may be overwritten when a new installation is carried out and cause older software versions to stop working.
On 08/06/18 20:11, Philip Barlow wrote:
I am happily running 2.18.20, 3.0.3 and 3.1 (nightly builds) side by side on Windows 10. 2.x and 3.x store their user settings and plugins in different locations so there are no conflicts.
Phil
Sent: 08 June 2018 05:02
To: qgis-user ML
The Windows version of Qgis allows you to run multiple versions on your computer side by side. I personally haven't used the Windows version for several years so I can't be sure if you will have any issues running 3.0 alongside your current version. I run many of the editions I have in virtual machines. If your PC has 8 GB or more of memory, or if you have access to another computer that can run Linux, then you can try it out in a Linux virtual machine or physical computer environment without disturbing your current installation.
On 08/06/18 07:38, Springfield Harrison wrote:
hello Patrick, thanks for your ideas. I will try the no plugins option.
The program will run with no project loaded and it will run older project files but has problems with newer ones for the same project.
I can load an older project file and then add newer layers to it and reconfigure them, Etc. This is very tedious but will amount to a recovery. It is better than starting from scratch for sure. But will the same problem reoccur?
I have contemplated migrating to version 3 but I'm always leery of upgrades of anything as they often bring problems with them. In this list I notice many references to installation issues and things not running. 2.10 is a devil I know.
can I expect any difficulties installing 3.0 +?
Cheers . . . . . Spring
Samsung Tab 4
On Jun 7, 2018 1:30 AM, "Patrick Dunford" <enzedrailmaps at gmail.com<mailto:enzedrailmaps at gmail.com>> wrote:
Thre are a number of troubleshooting steps to try out
1. Start up qgis using the -noplugins switch or remove all installed plugins or test removing one at a time.
2. Backup the config file and start with a new empty config.
Qgis 2.10 is well out of support, is there any reason you can't migrate to 3.0?
On 07/06/18 18:28, Springfield Harrison wrote:
hello Phil,
I did open the project file in Word, 2033 pages, and found 13 instances referring to the dxf file. Hard to say if anything was wrong there, nothing obvious. At least to me. Some other research I did indicates that maybe there is an authentication problem, not sure just what that boils down to.
I don't think the dxf file is the problem. I renamed it and bypassed it on the startup routine which the program accepted but it still seized up with a spinning cursor. Some things still function, such as modifying the properties of a layer , Etc. But the screen is blank and nothing can be saved.
For some time I have noticed that loading a project file bogs down for a while and then would resume to completion. Now it bogs down and blows up. The key message seems to be unknown exception.
Some older project files do load successfully however...
Samsung Tab 4
On Jun 6, 2018 11:15 PM, "Phil Wyatt" <phil at wyatt-family.com<mailto:phil at wyatt-family.com>> wrote:
Can you open a copy of the previous project file in something like notepad and see if anything obvious can be fixed and or removed in relation to the DXF layer?
From: Qgis-user [mailto:qgis-user-bounces at lists.osgeo.org<mailto:qgis-user-bounces at lists.osgeo.org>] On Behalf Of Springfield Harrison
Sent: Thursday, 7 June 2018 1:36 PM
To: qgis-user at lists.osgeo.org<mailto:qgis-user at lists.osgeo.org> List
Subject: [Qgis-user] Unable to load project
Hello All,
Bad News. I am unable to load a project that normally works with no problems:
1. QGIS 2.10.1, Windows 7.
2. Project starts to load, loads many layers . . .
3. halts loading "point Entity", a DXF file
4. the DXF file was renamed to trigger the Handle Bad Layers service
5. this was bypassed but project loading still fails to complete, cursor spinner on constantly
6. exiting with Save triggers "Unknown Exception"
7. the project file is trashed to 0kb
8. Exiting without Save is OK but no project can be loaded
9. Restoring previous project file versions yields the same results
10. Loading some other projects works but may have cursor spinner
Any ideas what is going on here? I have rebooted the computer.
Thanks very much . . . .
Cheers . . . . . Springfield Harrison
Qgis-user mailing list
Qgis-user at lists.osgeo.org<mailto:Qgis-user at lists.osgeo.org>
List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
Mae'r Awdurdod yn hapus i gyfathrebu yn Gymraeg neu yn Saesneg
The Authority is happy to communicate in Welsh or English
Website www.pembrokeshirecoast.org.uk<http://www.pembrokeshirecoast.org.uk>
Follow us on Twitter<http://twitter.com/PembsCoast>
Join us on Facebook<http://www.facebook.com/group.php?gid=26330984774&ref=ts>
Watch us on Youtube <http://www.youtube.com/user/pcnpa2008#p/u/0/Tw8Udou0p5k>
Look at us on Flickr<http://www.flickr.com/photos/pembrokeshirecoast/>
This email and any attached files should only be read by those persons to whom
they are addressed and be used by them only for their intended purpose.
If you are not the intended recipient please destroy all copies and inform the
sender by return email.
Please note that the contents of this email may be subject to public disclosure
under the Freedom of Information Act 2000 and therefore the confidentiality of
this message and any reply cannot be guaranteed.
For further information on the PCNPA please visit our website at www.pembrokeshirecoast.org.uk<http://www.pembrokeshirecoast.org.uk>
Please consider the environment before printing this email.
Dim ond y personau hynny yr anfonwyd yr e-bost hwn atynt ac unrhyw ffeiliau sydd
ynghlwm ddylid eu darllen, a dim ond hwy ddylid eu defnyddio at y diben y bwriadwyd hwy.
Os nad y chi yw'r person y bwriadwyd eu derbyn a fyddech gystal � dinistrio pob copi a rhoi
gwybod i'r anfonwr gyda throad yr e-bost.
Noder os gwelwch yn dda y gall cynnwys yr e-bost hwn orfod cael ei ddatgelu i'r cyhoedd o
dan Deddf Rhyddid Gwybodaeth 2000 ac felly ni ellir gwarantu cyfrinachedd y neges hon
nac unrhyw ateb.
Am ragor o wybodaeth am APCAP ymwelwch �'n gwefan ar www.arfordirpenfro.org.uk<http://www.arfordirpenfro.org.uk>
Ystyrier yr amgylchedd cyn argraffu'r e-bost hwn os gwelwch yn dda.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20180608/175b7dc6/attachment.html>
