[Qgis-user] Unable to load project
DelazJ
delazj at gmail.com
Fri Jun 8 06:25:53 PDT 2018
Years that I'm using the osgeo4w installer (advanced install) with three
concurrent releases minimum (ltr, current release, dev, and sometimes
ltr-dev) and I can't recall on any issue I got due to this situation.
And afaics there's nothing to be particularly careful of, it's just about
click click click process and all got installed in the c:\osgeo4w64 folder.
Just wanted to share my experience.
Regards,
Harrissou
2018-06-08 13:49 GMT+02:00 Philip Barlow <philipb at pembrokeshirecoast.org.uk>
> AFAIK if you install QGIS with the standalone installer that just puts the
> application and everything it needs into a folder in program files. You may
> encounter issues if you installed multiple versions with the osgeo4w
> installer if you aren’t careful.
> *From:* Qgis-user [mailto:qgis-user-bounces at lists.osgeo.org] *On Behalf
> Of *Patrick Dunford
> *Sent:* 08 June 2018 11:01
> *To:* qgis-user ML
> *Subject:* Re: [Qgis-user] Unable to load project
> That may be the case for the application. However, depending on the
> installation, shared libraries may be overwritten when a new installation
> is carried out and cause older software versions to stop working.
> On 08/06/18 20:11, Philip Barlow wrote:
> I am happily running 2.18.20, 3.0.3 and 3.1 (nightly builds) side by side
> on Windows 10. 2.x and 3.x store their user settings and plugins in
> different locations so there are no conflicts.
> Phil
> <qgis-user-bounces at lists.osgeo.org>] *On Behalf Of *Patrick Dunford
> *Sent:* 08 June 2018 05:02
> *To:* qgis-user ML
> The Windows version of Qgis allows you to run multiple versions on your
> computer side by side. I personally haven't used the Windows version for
> several years so I can't be sure if you will have any issues running 3.0
> alongside your current version. I run many of the editions I have in
> virtual machines. If your PC has 8 GB or more of memory, or if you have
> access to another computer that can run Linux, then you can try it out in a
> Linux virtual machine or physical computer environment without disturbing
> your current installation.
> On 08/06/18 07:38, Springfield Harrison wrote:
> hello Patrick, thanks for your ideas. I will try the no plugins option.
> The program will run with no project loaded and it will run older project
> files but has problems with newer ones for the same project.
> I can load an older project file and then add newer layers to it and
> reconfigure them, Etc. This is very tedious but will amount to a recovery.
> It is better than starting from scratch for sure. But will the same problem
> reoccur?
> I have contemplated migrating to version 3 but I'm always leery of
> upgrades of anything as they often bring problems with them. In this list I
> notice many references to installation issues and things not running. 2.10
> is a devil I know.
> can I expect any difficulties installing 3.0 +?
> Cheers . . . . . Spring
> Samsung Tab 4
> On Jun 7, 2018 1:30 AM, "Patrick Dunford" <enzedrailmaps at gmail.com> wrote:
> Thre are a number of troubleshooting steps to try out
> 1. Start up qgis using the -noplugins switch or remove all installed
> plugins or test removing one at a time.
> 2. Backup the config file and start with a new empty config.
> Qgis 2.10 is well out of support, is there any reason you can't migrate to
> 3.0?
> On 07/06/18 18:28, Springfield Harrison wrote:
> hello Phil,
> I did open the project file in Word, 2033 pages, and found 13 instances
> referring to the dxf file. Hard to say if anything was wrong there, nothing
> obvious. At least to me. Some other research I did indicates that maybe
> there is an authentication problem, not sure just what that boils down to.
> I don't think the dxf file is the problem. I renamed it and bypassed it on
> the startup routine which the program accepted but it still seized up with
> a spinning cursor. Some things still function, such as modifying the
> properties of a layer , Etc. But the screen is blank and nothing can be
> saved.
> For some time I have noticed that loading a project file bogs down for a
> while and then would resume to completion. Now it bogs down and blows up.
> The key message seems to be unknown exception.
> Some older project files do load successfully however...
> Samsung Tab 4
> On Jun 6, 2018 11:15 PM, "Phil Wyatt" <phil at wyatt-family.com> wrote:
> Can you open a copy of the previous project file in something like notepad
> and see if anything obvious can be fixed and or removed in relation to the
> DXF layer?
> Of *Springfield Harrison
> *Sent:* Thursday, 7 June 2018 1:36 PM
> *To:* qgis-user at lists.osgeo.org List
> *Subject:* [Qgis-user] Unable to load project
> Hello All,
> Bad News. I am unable to load a project that normally works with no
> problems:
> 1. QGIS 2.10.1, Windows 7.
> 2. Project starts to load, loads many layers . . .
> 3. halts loading "point Entity", a DXF file
> 4. the DXF file was renamed to trigger the Handle Bad Layers service
> 5. this was bypassed but project loading still fails to complete,
> cursor spinner on constantly
> 6. exiting with Save triggers "Unknown Exception"
> 7. the project file is trashed to 0kb
> 8. Exiting without Save is OK but no project can be loaded
> 9. Restoring previous project file versions yields the same results
> 10. Loading some other projects works but may have cursor spinner
> Any ideas what is going on here? I have rebooted the computer.
> Thanks very much . . . .
> Cheers . . . . . Springfield Harrison
> Qgis-user mailing list
> Mae'r Awdurdod yn hapus i gyfathrebu yn Gymraeg neu yn Saesneg
> The Authority is happy to communicate in Welsh or English
> Website www.pembrokeshirecoast.org.uk
> Follow us on Twitter <http://twitter.com/PembsCoast>
> Join us on Facebook
> <http://www.facebook.com/group.php?gid=26330984774&ref=ts>
> Watch us on Youtube
> <http://www.youtube.com/user/pcnpa2008#p/u/0/Tw8Udou0p5k>
> Look at us on Flickr <http://www.flickr.com/photos/pembrokeshirecoast/>
> This email and any attached files should only be read by those persons to
> whom
> they are addressed and be used by them only for their intended purpose.
> If you are not the intended recipient please destroy all copies and inform
> the
> sender by return email.
> Please note that the contents of this email may be subject to public
> disclosure
> under the Freedom of Information Act 2000 and therefore the
> confidentiality of
> this message and any reply cannot be guaranteed.
> For further information on the PCNPA please visit our website at
> Please consider the environment before printing this email.
> Dim ond y personau hynny yr anfonwyd yr e-bost hwn atynt ac unrhyw
> ffeiliau sydd
> ynghlwm ddylid eu darllen, a dim ond hwy ddylid eu defnyddio at y diben y
> bwriadwyd hwy.
> Os nad y chi yw'r person y bwriadwyd eu derbyn a fyddech gystal �
> dinistrio pob copi a rhoi
> gwybod i'r anfonwr gyda throad yr e-bost.
> Noder os gwelwch yn dda y gall cynnwys yr e-bost hwn orfod cael ei
> ddatgelu i'r cyhoedd o
> dan Deddf Rhyddid Gwybodaeth 2000 ac felly ni ellir gwarantu cyfrinachedd
> y neges hon
> nac unrhyw ateb.
> Am ragor o wybodaeth am APCAP ymwelwch �'n gwefan ar
> www.arfordirpenfro.org.uk
> Ystyrier yr amgylchedd cyn argraffu'r e-bost hwn os gwelwch yn dda.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20180608/4d247b1e/attachment.html>
