[Qgis-user] Unable to load project
Springfield Harrison
stellargps at gmail.com
Fri Jun 8 23:06:10 PDT 2018
Hello Responders,
Thanks very much for your suggestions and comments. Very helpful.
I must say though that the last few comments have again underscored my
nervousness about changing anything that isn't completely broken.
Firstly, why are there two installation processes and what is the
purpose of each? This implies making a choice after learning about the
benefits and disadvantages of each. What are the criteria for choosing
one over the other? How long is the process of understanding the options?
Secondly, there seems to be no great consensus over the possibility (or
not) of conflicts between simultaneous installations. Again, this makes
me nervous.
Thirdly, why are some operators running two or three simultaneous
installations? Does this mean that the latest version is not adequate
for some tasks?
All these things give me pause and discourage me from wading in to
something that may have a lengthy learning curve and an unpredictable
outcome. In this case, the devil you know definitely seems to be a
worthy rule of thumb. At least, until it fails utterly.
In that regard, I discovered that at some point I had installed 2.8.1
and, remarkably, it would load my ostensibly corrupt configuration
file. I appear to be back in business.
However, this version still bogs down upon loading the various layers
but does not fail after the delay. There are about 100 layers, mostly
vector.
Anyway, not sure if this is particularly helpful but is my current
thinking on the upgrading process.
Thank you all again for your assistance…
Cheers . . . . . Spring Harrison
On 08-Jun-2018 06:25, DelazJ wrote:
> Hi,
> Years that I'm using the osgeo4w installer (advanced install) with
> three concurrent releases minimum (ltr, current release, dev, and
> sometimes ltr-dev) and I can't recall on any issue I got due to this
> situation.
> And afaics there's nothing to be particularly careful of, it's just
> about click click click process and all got installed in the
> c:\osgeo4w64 folder.
> Just wanted to share my experience.
> Regards,
> Harrissou
> 2018-06-08 13:49 GMT+02:00 Philip Barlow
> <philipb at pembrokeshirecoast.org.uk
> <mailto:philipb at pembrokeshirecoast.org.uk>>:
> AFAIK if you install QGIS with the standalone installer that just
> puts the application and everything it needs into a folder in
> program files. You may encounter issues if you installed multiple
> versions with the osgeo4w installer if you aren’t careful.
> *From:*Qgis-user [mailto:qgis-user-bounces at lists.osgeo.org
> <mailto:qgis-user-bounces at lists.osgeo.org>] *On Behalf Of *Patrick
> Dunford
> *Sent:* 08 June 2018 11:01
> *To:* qgis-user ML
> *Subject:* Re: [Qgis-user] Unable to load project
> That may be the case for the application. However, depending on
> the installation, shared libraries may be overwritten when a new
> installation is carried out and cause older software versions to
> stop working.
> On 08/06/18 20:11, Philip Barlow wrote:
> I am happily running 2.18.20, 3.0.3 and 3.1 (nightly builds)
> side by side on Windows 10. 2.x and 3.x store their user
> settings and plugins in different locations so there are no
> conflicts.
> Phil
> *Patrick Dunford
> *Sent:* 08 June 2018 05:02
> *To:* qgis-user ML
> The Windows version of Qgis allows you to run multiple
> versions on your computer side by side. I personally haven't
> used the Windows version for several years so I can't be sure
> if you will have any issues running 3.0 alongside your current
> version. I run many of the editions I have in virtual
> machines. If your PC has 8 GB or more of memory, or if you
> have access to another computer that can run Linux, then you
> can try it out in a Linux virtual machine or physical computer
> environment without disturbing your current installation.
> On 08/06/18 07:38, Springfield Harrison wrote:
> hello Patrick, thanks for your ideas. I will try the no
> plugins option.
> The program will run with no project loaded and it will
> run older project files but has problems with newer ones
> for the same project.
> I can load an older project file and then add newer layers
> to it and reconfigure them, Etc. This is very tedious but
> will amount to a recovery. It is better than starting from
> scratch for sure. But will the same problem reoccur?
> I have contemplated migrating to version 3 but I'm always
> leery of upgrades of anything as they often bring problems
> with them. In this list I notice many references to
> installation issues and things not running. 2.10 is a
> devil I know.
> can I expect any difficulties installing 3.0 +?
> Samsung Tab 4
> On Jun 7, 2018 1:30 AM, "Patrick Dunford"
> <enzedrailmaps at gmail.com <mailto:enzedrailmaps at gmail.com>>
> wrote:
> Thre are a number of troubleshooting steps to try out
> 1. Start up qgis using the -noplugins switch or remove all
> installed plugins or test removing one at a time.
> 2. Backup the config file and start with a new empty config.
> Qgis 2.10 is well out of support, is there any reason you
> can't migrate to 3.0?
> On 07/06/18 18:28, Springfield Harrison wrote:
> hello Phil,
> I did open the project file in Word, 2033 pages, and
> found 13 instances referring to the dxf file. Hard to
> say if anything was wrong there, nothing obvious. At
> least to me. Some other research I did indicates that
> maybe there is an authentication problem, not sure
> just what that boils down to.
> I don't think the dxf file is the problem. I renamed
> it and bypassed it on the startup routine which the
> program accepted but it still seized up with a
> spinning cursor. Some things still function, such as
> modifying the properties of a layer , Etc. But the
> screen is blank and nothing can be saved.
> For some time I have noticed that loading a project
> file bogs down for a while and then would resume to
> completion. Now it bogs down and blows up. The key
> message seems to be unknown exception.
> Some older project files do load successfully however...
> Samsung Tab 4
> On Jun 6, 2018 11:15 PM, "Phil Wyatt"
> <phil at wyatt-family.com <mailto:phil at wyatt-family.com>>
> wrote:
> Can you open a copy of the previous project file in
> something like notepad and see if anything obvious can
> be fixed and or removed in relation to the DXF layer?
> *From:*Qgis-user
> Of *Springfield Harrison
> *Sent:* Thursday, 7 June 2018 1:36 PM
> *To:* qgis-user at lists.osgeo.org
> <mailto:qgis-user at lists.osgeo.org> List
> *Subject:* [Qgis-user] Unable to load project
> Hello All,
> Bad News. I am unable to load a project that normally
> works with no problems:
> 1. QGIS 2.10.1, Windows 7.
> 2. Project starts to load, loads many layers . . .
> 3. halts loading "point Entity", a DXF file
> 4. the DXF file was renamed to trigger the Handle Bad
> Layers service
> 5. this was bypassed but project loading still fails
> to complete, cursor spinner on constantly
> 6. exiting with Save triggers "Unknown Exception"
> 7. the project file is trashed to 0kb
> 8. Exiting without Save is OK but no project can be
> loaded
> 9. Restoring previous project file versions yields
> the same results
> 10. Loading some other projects works but may have
> cursor spinner
> Any ideas what is going on here? I have rebooted the
> computer.
> Thanks very much . . . .
> Cheers . . . . . Springfield Harrison
> Qgis-user mailing list
> Qgis-user at lists.osgeo.org <mailto:Qgis-user at lists.osgeo.org>
> List info:https://lists.osgeo.org/mailman/listinfo/qgis-user <https://lists.osgeo.org/mailman/listinfo/qgis-user>
> Unsubscribe:https://lists.osgeo.org/mailman/listinfo/qgis-user <https://lists.osgeo.org/mailman/listinfo/qgis-user>
> List info:
> Unsubscribe:
> Mae'r Awdurdod yn hapus i gyfathrebu yn Gymraeg neu yn Saesneg
> The Authority is happy to communicate in Welsh or English
> Website www.pembrokeshirecoast.org.uk
> <http://www.pembrokeshirecoast.org.uk>
> Follow us on Twitter <http://twitter.com/PembsCoast>
> Join us on Facebook
> <http://www.facebook.com/group.php?gid=26330984774&ref=ts>
> Watch us on Youtube
> <http://www.youtube.com/user/pcnpa2008#p/u/0/Tw8Udou0p5k>
> Look at us on Flickr
> <http://www.flickr.com/photos/pembrokeshirecoast/>
> This email and any attached files should only be read by those
> persons to whom
> they are addressed and be used by them only for their intended
> purpose.
> If you are not the intended recipient please destroy all
> copies and inform the
> sender by return email.
> Please note that the contents of this email may be subject to
> public disclosure
> under the Freedom of Information Act 2000 and therefore the
> confidentiality of
> this message and any reply cannot be guaranteed.
> For further information on the PCNPA please visit our website
> at www.pembrokeshirecoast.org.uk
> Please consider the environment before printing this email.
> Dim ond y personau hynny yr anfonwyd yr e-bost hwn atynt ac
> unrhyw ffeiliau sydd
> ynghlwm ddylid eu darllen, a dim ond hwy ddylid eu defnyddio
> at y diben y bwriadwyd hwy.
> Os nad y chi yw'r person y bwriadwyd eu derbyn a fyddech
> gystal � dinistrio pob copi a rhoi
> gwybod i'r anfonwr gyda throad yr e-bost.
> Noder os gwelwch yn dda y gall cynnwys yr e-bost hwn orfod
> cael ei ddatgelu i'r cyhoedd o
> dan Deddf Rhyddid Gwybodaeth 2000 ac felly ni ellir gwarantu
> cyfrinachedd y neges hon
> nac unrhyw ateb.
> Am ragor o wybodaeth am APCAP ymwelwch �'n gwefan ar
> www.arfordirpenfro.org.uk <http://www.arfordirpenfro.org.uk>
> Ystyrier yr amgylchedd cyn argraffu'r e-bost hwn os gwelwch yn
> dda.
> <http://www.avg.com/email-signature?utm_medium=email&utm_source=link&utm_campaign=sig-email&utm_content=emailclient>
> Virus-free. www.avg.com
> <#DAB4FAD8-2DD7-40BB-A1B8-4E2AA1F9FDF2>
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20180608/e8a4c9e1/attachment.html>
