[Qgis-user] QGIS Server 3.0.3 with NGINX / FastCGI - Sessions not persisting?
andrew terry
andrew.terry at centremaps.co.uk
Thu Jun 14 06:34:17 PDT 2018
Hi Alessandro,
Thanks for the thought, i did include the xvfb install and config. Always
double check though and the status report is as follows - only just showing
as started as i booted the instance to check:
● xvfb.service - X Virtual Frame Buffer Service
Loaded: loaded (/etc/systemd/system/xvfb.service; enabled; vendor preset:
enabled)
Active: active (running) since Thu 2018-06-14 13:23:50 UTC; 37s ago
Main PID: 840 (Xvfb)
Tasks: 3 (limit: 4915)
CGroup: /system.slice/xvfb.service
└─840 /usr/bin/Xvfb :99 -screen 0 1024x768x24 -ac +extension GLX
+render -noreset
Jun 14 13:23:50 ip-172-31-14-242 systemd[1]: Started X Virtual Frame Buffer
Service.
Thanks Andy
Sent from: http://osgeo-org.1560.x6.nabble.com/QGIS-User-f4125267.html
