[Qgis-user] QGIS Server 3.0.3 with NGINX / FastCGI - Sessions	not persisting?
    Alessandro Pasotti
    apasotti at gmail.com
    Thu Jun 14 06:40:39 PDT 2018
Looks good.
I don't know where else to look but if you want a tested working
configuration you can have a look to:
https://github.com/elpaso/qgis3-server-vagrant
On Thu, Jun 14, 2018 at 3:34 PM, andrew terry <andrew.terry at centremaps.co.uk
> wrote:
> Hi Alessandro,
> Thanks for the thought, i did include the xvfb install and config. Always
> double check though and the status report is as follows - only just showing
> as started as i booted the instance to check:
> ● xvfb.service - X Virtual Frame Buffer Service
>    Loaded: loaded (/etc/systemd/system/xvfb.service; enabled; vendor
> preset:
> enabled)
>    Active: active (running) since Thu 2018-06-14 13:23:50 UTC; 37s ago
>  Main PID: 840 (Xvfb)
>     Tasks: 3 (limit: 4915)
>    CGroup: /system.slice/xvfb.service
>            └─840 /usr/bin/Xvfb :99 -screen 0 1024x768x24 -ac +extension GLX
> +render -noreset
> Jun 14 13:23:50 ip-172-31-14-242 systemd[1]: Started X Virtual Frame Buffer
> Service.
> Thanks Andy
> Sent from: http://osgeo-org.1560.x6.nabble.com/QGIS-User-f4125267.html
> Qgis-user mailing list
Alessandro Pasotti
w3:   www.itopen.it
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20180614/020149b3/attachment.html>
