[Qgis-user] QGIS Server 3.0.3 with NGINX / FastCGI - Sessions not persisting?
andrew terry
andrew.terry at centremaps.co.uk
Thu Jun 14 06:46:22 PDT 2018
Excellent - i have been looking at a couple of docker examples but i'll
definitely delve into yours including the various options e.g.
fastcgi/python. Thank you again so far
Alessandro Pasotti-2 wrote
> Looks good.
> I don't know where else to look but if you want a tested working
> configuration you can have a look to:
> https://github.com/elpaso/qgis3-server-vagrant
> On Thu, Jun 14, 2018 at 3:34 PM, andrew terry <
> andrew.terry at .co
> > wrote:
>> Hi Alessandro,
>> Thanks for the thought, i did include the xvfb install and config. Always
>> double check though and the status report is as follows - only just
>> showing
>> as started as i booted the instance to check:
>> ● xvfb.service - X Virtual Frame Buffer Service
>> Loaded: loaded (/etc/systemd/system/xvfb.service; enabled; vendor
>> preset:
>> enabled)
>> Active: active (running) since Thu 2018-06-14 13:23:50 UTC; 37s ago
>> Main PID: 840 (Xvfb)
>> Tasks: 3 (limit: 4915)
>> CGroup: /system.slice/xvfb.service
>> └─840 /usr/bin/Xvfb :99 -screen 0 1024x768x24 -ac +extension
>> GLX
>> +render -noreset
>> Jun 14 13:23:50 ip-172-31-14-242 systemd[1]: Started X Virtual Frame
>> Buffer
>> Service.
>> Thanks Andy
>> Sent from: http://osgeo-org.1560.x6.nabble.com/QGIS-User-f4125267.html
>> Qgis-user mailing list
> Qgis-user at .osgeo
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
> Alessandro Pasotti
> w3: www.itopen.it
> Qgis-user at .osgeo
