[Qgis-user] QGIS Server 3.0.3 with NGINX / FastCGI - Sessions	not persisting?
    Alessandro Pasotti
    apasotti at gmail.com
    Thu Jun 14 06:49:16 PDT 2018
On Thu, Jun 14, 2018 at 3:46 PM, andrew terry <andrew.terry at centremaps.co.uk
> wrote:
> Excellent - i have been looking at a couple of docker examples but i'll
> definitely delve into yours including the various options e.g.
> fastcgi/python. Thank you again so far
np, but please keep in mind that my vagrant was prepared for a training
course and it wasn't security audited!
the goal was to explore all different possibilities to deploy QGIS server
(with some focus to Python).
Alessandro Pasotti-2 wrote
> > Looks good.
> > I don't know where else to look but if you want a tested working
> > configuration you can have a look to:
> > https://github.com/elpaso/qgis3-server-vagrant
> > On Thu, Jun 14, 2018 at 3:34 PM, andrew terry <
> > andrew.terry at .co
> > > wrote:
> >> Hi Alessandro,
> >> Thanks for the thought, i did include the xvfb install and config.
> Always
> >> double check though and the status report is as follows - only just
> >> showing
> >> as started as i booted the instance to check:
> >> ● xvfb.service - X Virtual Frame Buffer Service
> >>    Loaded: loaded (/etc/systemd/system/xvfb.service; enabled; vendor
> >> preset:
> >> enabled)
> >>    Active: active (running) since Thu 2018-06-14 13:23:50 UTC; 37s ago
> >>  Main PID: 840 (Xvfb)
> >>     Tasks: 3 (limit: 4915)
> >>    CGroup: /system.slice/xvfb.service
> >>            └─840 /usr/bin/Xvfb :99 -screen 0 1024x768x24 -ac +extension
> >> GLX
> >> +render -noreset
> >> Jun 14 13:23:50 ip-172-31-14-242 systemd[1]: Started X Virtual Frame
> >> Buffer
> >> Service.
> >> Thanks Andy
> >> Sent from: http://osgeo-org.1560.x6.nabble.com/QGIS-User-f4125267.html
> >> _______________________________________________
> >> Qgis-user mailing list
> > Qgis-user at .osgeo
> >> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
> >> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
> > Alessandro Pasotti
> > w3:   www.itopen.it
> > Qgis-user at .osgeo
Alessandro Pasotti
w3:   www.itopen.it
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20180614/4e6cf296/attachment.html>
