[Qgis-user] QGIS Server 3.0.3 with NGINX / FastCGI - Sessions not persisting?
andrew terry
andrew.terry at centremaps.co.uk
Thu Jun 14 07:08:09 PDT 2018
Of course. This is only some closed testing. One element i did note from your
code and some of the docker examples on github was seemingly explicitly
setting the sockets/processes. I didn't have a problem not doing this with
2.18 and haven't seen it in the documentation generally, do i need to extend
my linux knowledge?:
# Configure FastCGI nginx conf
sed -i -e "s at QGIS_SERVER_DIR@${QGIS_SERVER_DIR}@g"
/etc/nginx/sites-enabled/qgis-server-fcgi
SOCKETS=''
for i in $( eval echo {1..$NUM_PROCESSES}); do SOCKETS=" server
unix:/run/qgis_mapserv$i.sock;\n$SOCKETS" ; done
sed -i -e "s at QGIS_SERVER_SOCKETS@${SOCKETS}@g"
Alessandro Pasotti-2 wrote
> On Thu, Jun 14, 2018 at 3:46 PM, andrew terry <
> andrew.terry at .co
> > wrote:
> np, but please keep in mind that my vagrant was prepared for a training
> course and it wasn't security audited!
> the goal was to explore all different possibilities to deploy QGIS server
> (with some focus to Python).
>> > Looks good.
>> > I don't know where else to look but if you want a tested working
>> > configuration you can have a look to:
>> > https://github.com/elpaso/qgis3-server-vagrant
>> > On Thu, Jun 14, 2018 at 3:34 PM, andrew terry <
>> > andrew.terry at .co
>> > > wrote:
>> >> Hi Alessandro,
>> >> Thanks for the thought, i did include the xvfb install and config.
>> Always
>> >> double check though and the status report is as follows - only just
>> >> showing
>> >> as started as i booted the instance to check:
>> >> ● xvfb.service - X Virtual Frame Buffer Service
>> >> Loaded: loaded (/etc/systemd/system/xvfb.service; enabled; vendor
>> >> preset:
>> >> enabled)
>> >> Active: active (running) since Thu 2018-06-14 13:23:50 UTC; 37s ago
>> >> Main PID: 840 (Xvfb)
>> >> Tasks: 3 (limit: 4915)
>> >> CGroup: /system.slice/xvfb.service
>> >> └─840 /usr/bin/Xvfb :99 -screen 0 1024x768x24 -ac
>> +extension
>> >> GLX
>> >> +render -noreset
>> >> Jun 14 13:23:50 ip-172-31-14-242 systemd[1]: Started X Virtual Frame
>> >> Buffer
>> >> Service.
>> >> Thanks Andy
>> >> Sent from: http://osgeo-org.1560.x6.nabble.com/QGIS-User-f4125267.html
>> >> _______________________________________________
>> >> Qgis-user mailing list
>> > Qgis-user at .osgeo
>> >> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>> >> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
>> > Alessandro Pasotti
>> > w3: www.itopen.it
>> > Qgis-user at .osgeo
> Qgis-user at .osgeo
> Alessandro Pasotti
> w3: www.itopen.it
> Qgis-user at .osgeo
