[Qgis-user] Using qgis as realtime decision support tool
Jeroen Hovens
mail at groenebij.nl
Mon Jun 18 03:27:24 PDT 2018
I have not organized the data yet, that will depend on the pro’s and con’s of idea’s how to use it.
For now, I am thinking along the following line:
All municipalities as fields with attributes being whether or not they have a proposal and specific information about the proposal such as budget needed, type of project, etc.
That would mean 1 layer with all the proposals. That way it seems easier to show the entire map (all municipalities white, just borders, and all municipalities with proposal coloured), so to easily see the spread.
Van: Alexandre Neto <senhor.neto at gmail.com>
Verzonden: maandag 18 juni 2018 12:03
Aan: Jeroen Hovens <mail at groenebij.nl>
CC: qgis-user at lists.osgeo.org
Onderwerp: Re: [Qgis-user] Using qgis as realtime decision support tool
It's not clear how your data is organized, making it dificult to help in such a specific request. All the porposals are in the same layer, or in diferent layers?
Still, if you put all the proposal layers in mutually exclusive group, it will be easy to swap between proposals.
If they are all in the same layer, you can categorize and in the legend you can select which proposal to show.
https://docs.qgis.org/testing/en/docs/user_manual/introduction/general_tools.html?highlight=mutually#interact-with-groups-and-layers
You can also create an atlas with the necessary visualizations for each proposal and the calculus of the values you wish to show. But again, it all depends on how you have you data organized.
Jeroen Hovens <mail at groenebij.nl <mailto:mail at groenebij.nl> > escreveu no dia segunda, 18/06/2018 às 10:19:
Hello,
I am thinking about using qgis as a real-time decision support tool and I am looking for some good ideas to ease the process.
The case is the following:
I have proposals from 60 municipalities (out of a possible few hundred), each has 1 proposal. There is only room for 20 proposals to be accepted. One of the criteria will be the geographical spread of the proposals: it is preferred to have 20 proposals sort of evenly spread over the entire country, instead of having the majority of them coming from one region.
My idea is to show these proposals on a map by colouring the municipalities. As a decision support tool I need the ability to adjust the selection in real-time (during the discussion). The easy way is to just edit the attribute table or to select or deselect specific municipalities. This however requires myself to be present and make changes in qgis as the discussion goes (given that nobody else in the decision group knows how to work with qgis).
An alternative is to produce a webmap and have each municipality with a proposal have it’s own specific attribute value (but all using the same colour in categorized style), so they all show up in the map-legend, and any group member can easily select or deselect a specific municipality from the legend.
Do you have other ideas how to use a map as a real-time decision support tool?
Quality of the proposal is the main criterium, but in addition to the geographical spread there are others as well, such as variety in projects and the cumulative budget for the selected proposals (the cumulative budget is capped). Since I am not well known with database and calculation options in qgis and how to automatically show the results, I am building an easy to use excel file that will show all this information using precoded calculations, much like a dashboard. Simply selecting and deselecting proposals in an excel interface show you the changes in variety of projects and cumulative budget. This is much easier for the decision team to do themselves, since MS Excel is a well known environment.
Ideally I get the two connected somehow, so selecting and deselecting proposals will alter the results in both the map as in the excel dashboard. However, altering data in excel doesn’t automatically change the results in a qgis map, because they are not connected in real-time.
Do you have any ideas how to make a real-time connection between MS Excel and a qgis map? Or information on how to use qgis internal capabilities to calculate certain values based on the selection of proposals? However, the last option will probably still need myself to be present to somehow select or deselect the proposals in qgis.
Greetings,
Jeroen
Qgis-user mailing list
Qgis-user at lists.osgeo.org <mailto:Qgis-user at lists.osgeo.org>
List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
Alexandre Neto
@AlexNetoGeo
http://sigsemgrilhetas.wordpress.com
http://gisunchained.wordpress.com
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20180618/c3a1586f/attachment.html>
