[Qgis-user] QGIS 3.0.3 died on signal 11: what did go wrong? [SOLVED]
Hernán De Angelis
dhdeangelis at comhem.se
Mon Jun 18 06:53:54 PDT 2018
In case this is of interest, I spent a few hours tracing down the causes
of this problem and found them:
1. in openSUSE Leap 15 "qmake" is qt4. Solution: replace "qmake" by a
symbolic link to "qmake-qt5". I also preemptively deleted libqt4 during
the compilation of QGIS
2. in openSUSE Leap 15 the provided qwt package is precompiled against
qt4. I compiled my own qwt against qt5
Things went smoothly after that, but it took some effort to find out.
This is not the first time I experience hassle because of things linked
to different qt versions. It is not fun. I hope others can read this an
avoid the trouble.
/H.
On 06/18/2018 12:25 PM, Hernán De Angelis wrote:
> Thank you for this insight. You are right, it is indeed libqt4 that
> gets linked, despite all of libqt5 being present. I will have to
> figure out a way around.
> Thanks again
> /H.
> On 06/18/2018 12:11 PM, Alessandro Pasotti wrote:
>> Looks like you're loading Qt4 lib here:
>> #5 0x00007f3aca681d45 in
>> QDBusMetaType::registerMarshallOperators(int, void
>> (*)(QDBusArgument&, void const*), void (*)(QDBusArgument const&,
>> void*)) () at /usr/lib64/libQtDBus.so.4
>> On Mon, Jun 18, 2018 at 10:42 AM, Hernán De Angelis
>> <dhdeangelis at comhem.se <mailto:dhdeangelis at comhem.se>> wrote:
>> Fellow QGIS users,
>> I am experiencing a crash on starting QGIS 3.0.3: it dies in
>> signal 11. I compiled QGIS from source and absolutely no problems
>> or warnings where experienced during the build. This happens on a
>> fresh new installation of openSUSE (Leap 15).
>> I will appreciate if you could give me some hints into what could
>> have gone wrong and what potential solutions may I apply.
>> Please, find the crash report below.
>> Thanks in advance
>> H.
>> QGIS died on signal 11[New LWP 17858]
>> Missing separate debuginfo for /usr/lib64/libqwt-qt5.so.6
>> Try: zypper install -C
>> "debuginfo(build-id)=439218fd22c78120825b3b640c05e3464063479c"
>> Missing separate debuginfo for /usr/lib64/libqscintilla2_qt5.so.13
>> "debuginfo(build-id)=446a73c58a5766f3728da6081dfe5890e513b044"
>> Missing separate debuginfo for /usr/lib64/libQt5Sql.so.5
>> "debuginfo(build-id)=2fc4bf082c9455eb0002efeb97c2e0a5aa6448ec"
>> Missing separate debuginfo for /usr/lib64/libQt5Xml.so.5
>> "debuginfo(build-id)=01539f679a20ff25fb02be87c1e9d1a324aa9726"
>> Missing separate debuginfo for /usr/lib64/libQt5Svg.so.5
>> "debuginfo(build-id)=24fbed0cb29b72e529ff7911963e067cd2f65bca"
>> Missing separate debuginfo for /usr/lib64/libQt5PrintSupport.so.5
>> "debuginfo(build-id)=aa1018b0cd07ec7d7dfe909e6b941b1b42ef12cb"
>> Missing separate debuginfo for /usr/lib64/libQt5Widgets.so.5
>> "debuginfo(build-id)=83c5d92ad8980d21c5090c41cc181238f6b08968"
>> Missing separate debuginfo for /usr/lib64/libQt5Gui.so.5
>> "debuginfo(build-id)=b611a3c0161096e5be012368ae1b7db287e302c2"
>> Missing separate debuginfo for /usr/lib64/libQt5Network.so.5
>> "debuginfo(build-id)=ea72880f67944480ad502f5c017900358e31d3ec"
>> Missing separate debuginfo for /usr/lib64/libQt5Concurrent.so.5
>> "debuginfo(build-id)=4dadc441dc469afe49d9850699f31a7324e0e927"
>> Missing separate debuginfo for /usr/lib64/libqca-qt5.so.2
>> "debuginfo(build-id)=60085683d66412fa8cd5115bbeebd480147d318c"
>> Missing separate debuginfo for /usr/lib64/libqtkeychain.so.1
>> "debuginfo(build-id)=ed261e76f91f07140c296100281ce1f576feefe4"
>> Missing separate debuginfo for /usr/lib64/libspatialindex.so.4
>> "debuginfo(build-id)=9f564e1e366b20d3ca3e06fa04679179161d622e"
>> Missing separate debuginfo for /usr/lib64/libexpat.so.1
>> "debuginfo(build-id)=6500c00bea1aa9bb1c023c36c4aa1f4456629328"
>> Missing separate debuginfo for /usr/lib64/libsqlite3.so.0
>> "debuginfo(build-id)=e1e1fc6b0e94dc99724b564dd44ff250b34535a5"
>> Missing separate debuginfo for /usr/lib64/libzip.so.5
>> "debuginfo(build-id)=7cc74fd6abaa715de4a46d34483134f6f932b703"
>> Missing separate debuginfo for /usr/lib64/libQt5Positioning.so.5
>> "debuginfo(build-id)=b03cb1d41b0f1808da19ae63a38ecc8947bd95a9"
>> Missing separate debuginfo for /usr/lib64/libQt5Core.so.5
>> "debuginfo(build-id)=38f3eda831a9c5e39e513a072b5c8f9a0a2707d1"
>> Missing separate debuginfo for /usr/lib64/libstdc++.so.6
>> "debuginfo(build-id)=5173cf3c20dbaf430ec13b12bb8fa4730e17f048"
>> Missing separate debuginfo for /lib64/libm.so.6
>> "debuginfo(build-id)=918225cf6b6ff0c6c8dd92643b45c81b25a92c63"
>> Missing separate debuginfo for /lib64/libgcc_s.so.1
>> "debuginfo(build-id)=642b28ab8de504fa60c105e7a178e1a2805181cc"
>> Missing separate debuginfo for /lib64/libc.so.6
>> "debuginfo(build-id)=b5b558c30ba01bc47a8201373569afa3df140522"
>> Missing separate debuginfo for /usr/lib64/libQt5OpenGL.so.5
>> "debuginfo(build-id)=d212b1cc95cdf3a6fee6ed7fdbc93bdf1f31f3df"
>> Missing separate debuginfo for /lib64/ld-linux-x86-64.so.2
>> "debuginfo(build-id)=3b92738c1958b86aee8b14adbebf9d2dc4a84c02"
>> Missing separate debuginfo for /lib64/libz.so.1
>> "debuginfo(build-id)=393294980f1a4bb24bd8e1cb86ef77e791afb0f6"
>> Missing separate debuginfo for /lib64/libpthread.so.0
>> "debuginfo(build-id)=00ad8e7c413091d45bb349f105a4b3e466e367a7"
>> [Thread debugging using libthread_db enabled]
>> Using host libthread_db library "/lib64/libthread_db.so.1".
>> Missing separate debuginfo for /usr/lib64/libGL.so.1
>> "debuginfo(build-id)=3f6a5a08196a28c3e3bb7b0da22c196e4863314e"
>> Missing separate debuginfo for /usr/lib64/libpng16.so.16
>> "debuginfo(build-id)=6f8d1393a956fccc0f9f53788660bff1a07cd274"
>> Missing separate debuginfo for /usr/lib64/libharfbuzz.so.0
>> "debuginfo(build-id)=50b253c0afbd7e7d5a95ce169be3e2414fa4706a"
>> Missing separate debuginfo for /usr/lib64/libproxy.so.1
>> "debuginfo(build-id)=26075f6aa769e887613299c7a68335a198873400"
>> Missing separate debuginfo for /lib64/libdl.so.2
>> "debuginfo(build-id)=afe13cfdcf1d5312417df860e5cbe4fee96d8c62"
>> Missing separate debuginfo for /usr/lib64/libssl.so.1.1
>> "debuginfo(build-id)=06f613d8a2f173d8b65771fa7102602a4b957933"
>> Missing separate debuginfo for /usr/lib64/libcrypto.so.1.1
>> "debuginfo(build-id)=b49c0f03a6535754553266b3f483cfd825bac441"
>> Missing separate debuginfo for /usr/lib64/libQtCore.so.4
>> "debuginfo(build-id)=311a78a67d17345da79e08b58811dd4ee0957fe4"
>> Missing separate debuginfo for /usr/lib64/libQtDBus.so.4
>> "debuginfo(build-id)=6d534db0a08650938697ab7da51330068d88bc48"
>> Missing separate debuginfo for /usr/lib64/libwebp.so.6
>> "debuginfo(build-id)=e5773c95d44ba88bdbf38f9a98f48fdad514d9c3"
>> Missing separate debuginfo for /usr/lib64/libodbc.so.2
>> "debuginfo(build-id)=01b250dde290257b7f19881e0db3d927f4dd7e93"
>> Missing separate debuginfo for /usr/lib64/libodbcinst.so.2
>> "debuginfo(build-id)=86987b20f7c03d412d944b62d4679a7787489bde"
>> Missing separate debuginfo for /usr/lib64/libhdf5.so.101
>> "debuginfo(build-id)=efdfbf5a856f6ae09f3a2be58ad0429a959d021a"
>> Missing separate debuginfo for /usr/lib64/libgif.so.7
>> "debuginfo(build-id)=85a02d3d837974258f2c1853ed6ff19a5505b39f"
>> Missing separate debuginfo for /usr/lib64/libjpeg.so.8
>> "debuginfo(build-id)=626672faaa93192ee959a6c2a161b6bfff93c0c8"
>> Missing separate debuginfo for /lib64/librt.so.1
>> "debuginfo(build-id)=0df32935357efd4230b61ff61c86d41b451bf4a5"
>> Missing separate debuginfo for /usr/lib64/libpcre.so.1
>> "debuginfo(build-id)=c49115d2ba8c6df024395408e32d3583596b4828"
>> Missing separate debuginfo for /usr/lib64/libcurl.so.4
>> "debuginfo(build-id)=acb1d5764b8d85f82ca93c0bc63b721c77e6775a"
>> Missing separate debuginfo for /usr/lib64/libxml2.so.2
>> "debuginfo(build-id)=fb063824b39bb6ac23e8ab31cf1d4fa32b972d1b"
>> Missing separate debuginfo for /usr/lib64/liblzma.so.5
>> "debuginfo(build-id)=b5e4f0176a9c38afae0f4254e4e71fb80c70015a"
>> Missing separate debuginfo for /usr/lib64/libbz2.so.1
>> "debuginfo(build-id)=78a5e01ade6b3d8db9bc9bcf7d7452c057ab7ac1"
>> Missing separate debuginfo for /usr/lib64/libsystemd.so.0
>> "debuginfo(build-id)=7f1454e1ff426b99fddfa292f35ee9e343534576"
>> Missing separate debuginfo for /usr/lib64/libicui18n.so.60.2
>> "debuginfo(build-id)=cb0b8330584b5ba73c771804127abd0fb8f9ee8a"
>> Missing separate debuginfo for /usr/lib64/libicuuc.so.60.2
>> "debuginfo(build-id)=6cfc5c5ca656d7f4d937d0a20531556eb7df004d"
>> Missing separate debuginfo for /usr/lib64/libdouble-conversion.so.1
>> "debuginfo(build-id)=2e3fe9156462d55f660830566af577c7f9a4d4bf"
>> Missing separate debuginfo for /usr/lib64/libglib-2.0.so.0
>> "debuginfo(build-id)=7dfb5c1098f8e3bca84da342dfa27ab5bd84ec07"
>> Missing separate debuginfo for /usr/lib64/libGLX.so.0
>> "debuginfo(build-id)=1ad40bdfe9fa6c5f4597769e8fd76ea2d9e9760e"
>> Missing separate debuginfo for /usr/lib64/libGLdispatch.so.0
>> "debuginfo(build-id)=ddeeafa18db92852cb4bd8cf1cf829ea203e9d38"
>> Missing separate debuginfo for /usr/lib64/libfreetype.so.6
>> "debuginfo(build-id)=363462ea53ed88710f3aec2d879af9f9bde7cd1b"
>> Missing separate debuginfo for /usr/lib64/libgraphite2.so.3
>> "debuginfo(build-id)=354246a8966215f97f061f45d06ecaeea6697b35"
>> Missing separate debuginfo for /usr/lib64/libmodman.so.1
>> "debuginfo(build-id)=dc3a3d55e8d3a1dbdc6f81b8fc4ff90d92590bb1"
>> Missing separate debuginfo for /usr/lib64/libQtXml.so.4
>> "debuginfo(build-id)=aaaaf1866aec8ca07312279b2d3c6f4857d6b41d"
>> Missing separate debuginfo for /usr/lib64/libdbus-1.so.3
>> "debuginfo(build-id)=fc584f507fe77479b62a02843d026e66c1b7675f"
>> Missing separate debuginfo for /usr/lib64/libltdl.so.7
>> "debuginfo(build-id)=05a9f08fbc174560c6d610279aeb42e0ac560502"
>> Missing separate debuginfo for /usr/lib64/libhdf5_hl.so.100
>> "debuginfo(build-id)=e9b0456bb80d3faec87d16914d095c2a6ba544ab"
>> Missing separate debuginfo for /usr/lib64/libtiff.so.5
>> "debuginfo(build-id)=db4776448c2d936ea3a2f52044a3c783bb4353e6"
>> Missing separate debuginfo for /usr/lib64/libnghttp2.so.14
>> "debuginfo(build-id)=e6cc303ce1f7fe14bbc1449b11f316240cc3b600"
>> Missing separate debuginfo for /usr/lib64/libidn2.so.0
>> "debuginfo(build-id)=a7c724b2247b901cf02636ffb4cd1579eeee53de"
>> Missing separate debuginfo for /usr/lib64/libssh.so.4
>> "debuginfo(build-id)=de96783edd96e12a3200133ad07f7d3f2c647c34"
>> Missing separate debuginfo for /usr/lib64/libpsl.so.5
>> "debuginfo(build-id)=2ab0bb32a9c0e29652f262714e90268c514e1abf"
>> Missing separate debuginfo for /usr/lib64/libgssapi_krb5.so.2
>> "debuginfo(build-id)=f69bc647abca1f83de1c1e6c6a15b82d24961ce9"
>> Missing separate debuginfo for /usr/lib64/libldap_r-2.4.so.2
>> "debuginfo(build-id)=8318f5d40aa3c7c0501f804c2ed33545a04172ec"
>> Missing separate debuginfo for /usr/lib64/liblber-2.4.so.2
>> "debuginfo(build-id)=14ded17a5686423b97b6a4b0b9456acd372faeb3"
>> Missing separate debuginfo for /lib64/libresolv.so.2
>> "debuginfo(build-id)=ecc5fd5f90d7b5454477387d0a00c68ef5568bff"
>> Missing separate debuginfo for /lib64/libselinux.so.1
>> "debuginfo(build-id)=0e6d5b62943990607d0f3199e3fe7f47d729c4f3"
>> Missing separate debuginfo for /usr/lib64/libcap.so.2
>> "debuginfo(build-id)=a055a722c16b775c462afd06d7e106f21b8b96f3"
>> Missing separate debuginfo for /usr/lib64/liblz4.so.1
>> "debuginfo(build-id)=9d3b2b67346705c61874113869fc49cda1e59f7e"
>> Missing separate debuginfo for /usr/lib64/libgcrypt.so.20
>> "debuginfo(build-id)=30bb1b00b79d1f415fbb2783c386955806bc8a2e"
>> Missing separate debuginfo for /usr/lib64/libgpg-error.so.0
>> "debuginfo(build-id)=c5812b92d66f7cdd4e4e8f284c1b4d629356a80d"
>> Missing separate debuginfo for /usr/lib64/libicudata.so.60.2
>> "debuginfo(build-id)=b11f25a029eb1867928e30aa67f45389b12125bf"
>> Missing separate debuginfo for /usr/lib64/libX11.so.6
>> "debuginfo(build-id)=ff867c578f2ecf893655d95d851f9c455706ea56"
>> Missing separate debuginfo for /usr/lib64/libjbig.so.2
>> "debuginfo(build-id)=63bb61fe50e1782c7e093583580c9dea81f23527"
>> Missing separate debuginfo for /usr/lib64/libunistring.so.2
>> "debuginfo(build-id)=dbfbcf61e46f675ba21cef54c7e6d8664a73b352"
>> Missing separate debuginfo for /usr/lib64/libkrb5.so.3
>> "debuginfo(build-id)=0de532121b065c5392f821fafb746dce5d3a0f6c"
>> Missing separate debuginfo for /usr/lib64/libk5crypto.so.3
>> "debuginfo(build-id)=fb906792125f8d7051467385437a8fc9cf02cb99"
>> Missing separate debuginfo for /lib64/libcom_err.so.2
>> "debuginfo(build-id)=08d06eee4c6ad0456fa95ce2aece2b428e085320"
>> Missing separate debuginfo for /usr/lib64/libkrb5support.so.0
>> "debuginfo(build-id)=5e2403de3d110d7c06ef2d111df16b458521fcd2"
>> Missing separate debuginfo for /usr/lib64/libsasl2.so.3
>> "debuginfo(build-id)=759a9482d40bf68183e123300d666cda580d3ccc"
>> Missing separate debuginfo for /usr/lib64/libxcb.so.1
>> "debuginfo(build-id)=f452cb119f2b0a56cd2b9fda126731693c914619"
>> Missing separate debuginfo for /usr/lib64/libkeyutils.so.1
>> "debuginfo(build-id)=0fbaed7600db1edbbc687dfb885f47d958946b1c"
>> Missing separate debuginfo for /usr/lib64/libXau.so.6
>> "debuginfo(build-id)=9ad19a9b77ab3c7217d4e01f9d3369848a2a5d2e"
>> /usr/lib64/qt5/plugins/platforms/libqxcb.so
>> "debuginfo(build-id)=1f8f5b53bfdc9b5caadfc9d8d8381a55c4f27b6a"
>> Missing separate debuginfo for /usr/lib64/libQt5XcbQpa.so.5
>> "debuginfo(build-id)=574d2ce016210d5cd3f8c612653301f799831466"
>> Missing separate debuginfo for /usr/lib64/libfontconfig.so.1
>> "debuginfo(build-id)=3ac41d743c1c3e1c3bc27e7a10929b03b5c954cd"
>> Missing separate debuginfo for /usr/lib64/libQt5DBus.so.5
>> "debuginfo(build-id)=84213703ef91c226b3d177b2025fe81ed6fb5c0e"
>> Missing separate debuginfo for /usr/lib64/libX11-xcb.so.1
>> "debuginfo(build-id)=0545e1949ffad8c4a789126170e1e4376503fe45"
>> Missing separate debuginfo for /usr/lib64/libXi.so.6
>> "debuginfo(build-id)=ceeab058dec326fc3505fe5d2bef69fd67cebf47"
>> Missing separate debuginfo for /usr/lib64/libSM.so.6
>> "debuginfo(build-id)=490891d1dcbd60b05902aa61bf9058ebdddac8cf"
>> Missing separate debuginfo for /usr/lib64/libICE.so.6
>> "debuginfo(build-id)=447ef3f4fa1bf8e88498e05625f2719631bc06eb"
>> Missing separate debuginfo for /usr/lib64/libxcb-xkb.so.1
>> "debuginfo(build-id)=75803fcdc925628dd2476992c3a96b5070adb7b3"
>> Missing separate debuginfo for /usr/lib64/libxcb-render-util.so.0
>> "debuginfo(build-id)=dbc98d19b4474cc1757558d0f4402be59d0a3309"
>> Missing separate debuginfo for /usr/lib64/libxcb-render.so.0
>> "debuginfo(build-id)=d5668d121e372edd7b38067625be3b1d7077ddb9"
>> Missing separate debuginfo for /usr/lib64/libxcb-sync.so.1
>> "debuginfo(build-id)=25c7221346af63063ac54f7eb195ec5869540032"
>> Missing separate debuginfo for /usr/lib64/libxcb-xfixes.so.0
>> "debuginfo(build-id)=93cbec4d502369fa1942c2d47674bb4a8bc52f13"
>> Missing separate debuginfo for /usr/lib64/libxcb-xinerama.so.0
>> "debuginfo(build-id)=c0b6b30ece1944c8cf6f85f4a4afed7205bc2655"
>> Missing separate debuginfo for /usr/lib64/libxcb-randr.so.0
>> "debuginfo(build-id)=059aa8c00b4c54c66bb9f07db79906fd78bb5f96"
>> Missing separate debuginfo for /usr/lib64/libxcb-image.so.0
>> "debuginfo(build-id)=a2a8f1038082364579278a5acdc65341b8c043f7"
>> Missing separate debuginfo for /usr/lib64/libxcb-shm.so.0
>> "debuginfo(build-id)=944b7e1e36d2f5ec8bfe2ab76abf35d8a6ce220e"
>> Missing separate debuginfo for /usr/lib64/libxcb-keysyms.so.1
>> "debuginfo(build-id)=d65557a7d948f50280ef185837b97f2babbe4c82"
>> Missing separate debuginfo for /usr/lib64/libxcb-icccm.so.4
>> "debuginfo(build-id)=fb59991a8467fd61363124e41c1c7c9e0e9d1f56"
>> Missing separate debuginfo for /usr/lib64/libxcb-shape.so.0
>> "debuginfo(build-id)=3ec6ae47e663c25e670669ad7638b04f0b38e6cb"
>> Missing separate debuginfo for /usr/lib64/libxkbcommon-x11.so.0
>> "debuginfo(build-id)=3c7c720137a01053700412c63b1f4e747b32ebac"
>> Missing separate debuginfo for /usr/lib64/libxkbcommon.so.0
>> "debuginfo(build-id)=dc752531ef6dea01cde8ad3fec74ad4fb9dc42f1"
>> Missing separate debuginfo for /usr/lib64/libXext.so.6
>> "debuginfo(build-id)=fe1f9107049ede7c35286dab93700b798365b895"
>> Missing separate debuginfo for /usr/lib64/libuuid.so.1
>> "debuginfo(build-id)=0a2815953252f036958f3f043833e4d394ea18c8"
>> Missing separate debuginfo for /usr/lib64/libxcb-util.so.1
>> "debuginfo(build-id)=f7ac95970dca43ab33ad52ff08aaa668cd78ffd4"
>> Missing separate debuginfo for /usr/lib64/libXcursor.so.1
>> "debuginfo(build-id)=45886473becd10a9bf1705a7cff86d5276af76b1"
>> Missing separate debuginfo for /usr/lib64/libXrender.so.1
>> "debuginfo(build-id)=26742b2ff984147a2c7508148704b3cb2f752038"
>> Missing separate debuginfo for /usr/lib64/libXfixes.so.3
>> "debuginfo(build-id)=aa047315ac397f95aa829f479b1039b63aa05809"
>> /usr/lib64/qt5/plugins/xcbglintegrations/libqxcb-glx-integration.so
>> "debuginfo(build-id)=f88d07942e67292b9580a1d746e8e9d343e586af"
>> Missing separate debuginfo for /usr/lib64/libxcb-glx.so.0
>> "debuginfo(build-id)=6fe7632ac563fa6afc4f058d2b6c9b8bcbe9f44d"
>> /usr/lib64/qt5/plugins/platformthemes/libqgtk2.so
>> "debuginfo(build-id)=72b3ac22d02b403017e0d9fb23f72b89c1df1698"
>> Missing separate debuginfo for /usr/lib64/libgtk-x11-2.0.so.0
>> "debuginfo(build-id)=78a96e5e0d18aca5d63f07f1ba96418d654578b3"
>> Missing separate debuginfo for /usr/lib64/libgdk-x11-2.0.so.0
>> "debuginfo(build-id)=5d133f917df46cfeb3a1501c3fd85420f29077eb"
>> Missing separate debuginfo for /usr/lib64/libpango-1.0.so.0
>> "debuginfo(build-id)=4fd506f39a9b8b77760d0c1d287b99bf21a93644"
>> Missing separate debuginfo for /usr/lib64/libgobject-2.0.so.0
>> "debuginfo(build-id)=2af4acce680f8e44d6d27878702948d91220b82e"
>> Missing separate debuginfo for /usr/lib64/libgmodule-2.0.so.0
>> "debuginfo(build-id)=01fe244ff6ebb593a149f9e01e94848a5778ece2"
>> Missing separate debuginfo for /usr/lib64/libpangocairo-1.0.so.0
>> "debuginfo(build-id)=fa1d34a2085db3801a612741284dce89769b8d52"
>> Missing separate debuginfo for /usr/lib64/libatk-1.0.so.0
>> "debuginfo(build-id)=1761265526fc5fe25c8046334eed5696942df876"
>> Missing separate debuginfo for /usr/lib64/libcairo.so.2
>> "debuginfo(build-id)=6aaf1598f5797268dd29566f2c411bdfb45a46d1"
>> Missing separate debuginfo for /usr/lib64/libgdk_pixbuf-2.0.so.0
>> "debuginfo(build-id)=f6871d73e2b0d6eccaebe11cfd63a691013658e5"
>> Missing separate debuginfo for /usr/lib64/libgio-2.0.so.0
>> "debuginfo(build-id)=3f8d76f60fe8961f2499f0d9c3a5fbbbff220564"
>> Missing separate debuginfo for /usr/lib64/libpangoft2-1.0.so
>> <http://libpangoft2-1.0.so>.0
>> "debuginfo(build-id)=3029bae740e94a74913fdcab9fdda3f84f47b968"
>> Missing separate debuginfo for /usr/lib64/libXinerama.so.1
>> "debuginfo(build-id)=764d559bdc75ec52c17065bb5df95f7acff88473"
>> Missing separate debuginfo for /usr/lib64/libXrandr.so.2
>> "debuginfo(build-id)=b83f2e8882df57fe854139c84ea4a00697a8277d"
>> Missing separate debuginfo for /usr/lib64/libXcomposite.so.1
>> "debuginfo(build-id)=551fca4a9e6ac9bd7d90246692bfc4e2469940ff"
>> Missing separate debuginfo for /usr/lib64/libXdamage.so.1
>> "debuginfo(build-id)=4756f2ec5596947bebd4bd183557decba44fec6b"
>> Missing separate debuginfo for /usr/lib64/libthai.so.0
>> "debuginfo(build-id)=9c25e54f25d6784d415e8db48094f40052c0b0db"
>> Missing separate debuginfo for /usr/lib64/libffi.so.7
>> "debuginfo(build-id)=6a8e76464a8f8f17118793f0b43d45a226392039"
>> Missing separate debuginfo for /usr/lib64/libpixman-1.so.0
>> "debuginfo(build-id)=38b33ac1a1347aa0903444f36f96f4def77424f8"
>> Missing separate debuginfo for /usr/lib64/libEGL.so.1
>> "debuginfo(build-id)=48ee2deffee9609f2808ebc0a97bef0465aa5846"
>> Missing separate debuginfo for /usr/lib64/libmount.so.1
>> "debuginfo(build-id)=e2bb051ab7dbc168b1f2411965311ea20cef92b4"
>> Missing separate debuginfo for /usr/lib64/libdatrie.so.1
>> "debuginfo(build-id)=0d2835e1ddd1d8c86a887c19a38a5b4ae707fb59"
>> Missing separate debuginfo for /usr/lib64/libblkid.so.1
>> "debuginfo(build-id)=b394c5d746855f00a87c97ec173fc0ad7ea5ec14"
>> /usr/lib64/gtk-2.0/modules/libcanberra-gtk-module.so
>> "debuginfo(build-id)=132c4af6d309f7ee188f389e6a55dcfa1a162bfc"
>> Missing separate debuginfo for /usr/lib64/libcanberra-gtk.so.0
>> "debuginfo(build-id)=66436c1a352e91d57cb357d5956baf7ff4b7a864"
>> Missing separate debuginfo for /usr/lib64/libcanberra.so.0
>> "debuginfo(build-id)=9a6346b2ba4e6a5a0f910321eef2d6bd5e2a4054"
>> Missing separate debuginfo for /usr/lib64/libvorbisfile.so.3
>> "debuginfo(build-id)=ab6cd4515ea838342503b6b49f0a10ca3cc6f99b"
>> Missing separate debuginfo for /usr/lib64/libvorbis.so.0
>> "debuginfo(build-id)=3b9fc3187161236530cf16a311af84159ca6cf10"
>> Missing separate debuginfo for /usr/lib64/libogg.so.0
>> "debuginfo(build-id)=a1ba55e2e3236d160e3d7facdd56f5201c5d3075"
>> /usr/lib64/gtk-2.0/2.10.0/engines/libadwaita.so
>> "debuginfo(build-id)=1b0601f6ecbef3211dc72a57c43805043b6826d7"
>> /usr/lib64/gtk-2.0/2.10.0/engines/libpixmap.so
>> "debuginfo(build-id)=5ef566f06bf5709e8cf90060a4408a2290ecb1a4"
>> /usr/lib64/qt5/plugins/platforminputcontexts/libibusplatforminputcontextplugin.so
>> "debuginfo(build-id)=bf29e473497b05ce7ea117dffe08074784f23b3b"
>> 0x00007f3acc786da7 in waitpid () from /lib64/libc.so.6
>> [Current thread is 1 (Thread 0x7f3ad6c6b940 (LWP 17857))]
>> #0 0x00007f3acc786da7 in waitpid () at /lib64/libc.so.6
>> #1 0x000000000040cd55 in qgisCrash(int) ()
>> #2 0x00007f3acc6f7160 in <signal handler called> () at
>> /lib64/libc.so.6
>> #3 0x00007f3aca9255f9 in QReadWriteLock::QReadWriteLock() () at
>> #4 0x00007f3aca68180c in () at /usr/lib64/libQtDBus.so.4
>> #6 0x00007f3ab2a86086 in () at
>> #7 0x00007f3ad12e6110 in
>> QPlatformInputContextFactory::create(QString const&) () at
>> #8 0x00007f3abf97d5ad in QXcbIntegration::initialize() () at
>> #9 0x00007f3ad12fc539 in
>> QGuiApplicationPrivate::eventDispatcherReady() () at
>> #10 0x00007f3acd5f04e5 in QCoreApplicationPrivate::init() () at
>> #11 0x00007f3ad12fdd5c in QGuiApplicationPrivate::init() () at
>> #12 0x00007f3ad1ac5999 in QApplicationPrivate::init() () at
>> #13 0x00007f3ad314e4a4 in QgsApplication::QgsApplication(int&,
>> char**, bool, QString const&, QString const&) () at
>> /usr/local/lib/libqgis_core.so.3.0.3
>> #14 0x000000000040f716 in main ()
>> gdb returned 0
>> Aborted (core dumped)
>> Qgis-user mailing list
>> Qgis-user at lists.osgeo.org <mailto:Qgis-user at lists.osgeo.org>
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>> <https://lists.osgeo.org/mailman/listinfo/qgis-user>
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
>> Alessandro Pasotti
>> w3: www.itopen.it <http://www.itopen.it>
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20180618/71f6f09a/attachment.html>
