[Qgis-user] QGIS 3.0.3 died on signal 11: what did go wrong? [SOLVED]
Alessandro Pasotti
apasotti at gmail.com
Mon Jun 18 07:29:45 PDT 2018
On Mon, Jun 18, 2018 at 3:53 PM, Hernán De Angelis <dhdeangelis at comhem.se>
wrote:
> In case this is of interest, I spent a few hours tracing down the causes
> of this problem and found them:
> 1. in openSUSE Leap 15 "qmake" is qt4. Solution: replace "qmake" by a
> symbolic link to "qmake-qt5". I also preemptively deleted libqt4 during the
> compilation of QGIS
> 2. in openSUSE Leap 15 the provided qwt package is precompiled against
> qt4. I compiled my own qwt against qt5
> Things went smoothly after that, but it took some effort to find out.
> This is not the first time I experience hassle because of things linked to
> different qt versions. It is not fun. I hope others can read this an avoid
> the trouble.
> /H.
Thanks for sharing, glad to know that you could finally build and run it.
We have some developer docs about building QGIS on different platforms, if
you feel like contributing to it, here is the document:
https://github.com/qgis/QGIS/blob/master/INSTALL
> On 06/18/2018 12:25 PM, Hernán De Angelis wrote:
> Thank you for this insight. You are right, it is indeed libqt4 that gets
> linked, despite all of libqt5 being present. I will have to figure out a
> way around.
> Thanks again
> /H.
> On 06/18/2018 12:11 PM, Alessandro Pasotti wrote:
> Looks like you're loading Qt4 lib here:
> #5 0x00007f3aca681d45 in QDBusMetaType::registerMarshallOperators(int,
> void (*)(QDBusArgument&, void const*), void (*)(QDBusArgument const&,
> void*)) () at /usr/lib64/libQtDBus.so.4
> On Mon, Jun 18, 2018 at 10:42 AM, Hernán De Angelis <dhdeangelis at comhem.se
> > wrote:
>> Fellow QGIS users,
>> I am experiencing a crash on starting QGIS 3.0.3: it dies in signal 11. I
>> compiled QGIS from source and absolutely no problems or warnings where
>> experienced during the build. This happens on a fresh new installation of
>> openSUSE (Leap 15).
>> I will appreciate if you could give me some hints into what could have
>> gone wrong and what potential solutions may I apply.
>> Please, find the crash report below.
>> Thanks in advance
>> H.
>> QGIS died on signal 11[New LWP 17858]
>> Missing separate debuginfo for /usr/lib64/libqwt-qt5.so.6
>> Try: zypper install -C "debuginfo(build-id)=439218fd2
>> 2c78120825b3b640c05e3464063479c"
>> Missing separate debuginfo for /usr/lib64/libqscintilla2_qt5.so.13
>> Try: zypper install -C "debuginfo(build-id)=446a73c58
>> a5766f3728da6081dfe5890e513b044"
>> Missing separate debuginfo for /usr/lib64/libQt5Sql.so.5
>> Try: zypper install -C "debuginfo(build-id)=2fc4bf082
>> c9455eb0002efeb97c2e0a5aa6448ec"
>> Missing separate debuginfo for /usr/lib64/libQt5Xml.so.5
>> Try: zypper install -C "debuginfo(build-id)=01539f679
>> a20ff25fb02be87c1e9d1a324aa9726"
>> Missing separate debuginfo for /usr/lib64/libQt5Svg.so.5
>> Try: zypper install -C "debuginfo(build-id)=24fbed0cb
>> 29b72e529ff7911963e067cd2f65bca"
>> Missing separate debuginfo for /usr/lib64/libQt5PrintSupport.so.5
>> Try: zypper install -C "debuginfo(build-id)=aa1018b0c
>> d07ec7d7dfe909e6b941b1b42ef12cb"
>> Missing separate debuginfo for /usr/lib64/libQt5Widgets.so.5
>> Try: zypper install -C "debuginfo(build-id)=83c5d92ad
>> 8980d21c5090c41cc181238f6b08968"
>> Missing separate debuginfo for /usr/lib64/libQt5Gui.so.5
>> Try: zypper install -C "debuginfo(build-id)=b611a3c01
>> 61096e5be012368ae1b7db287e302c2"
>> Missing separate debuginfo for /usr/lib64/libQt5Network.so.5
>> Try: zypper install -C "debuginfo(build-id)=ea72880f6
>> 7944480ad502f5c017900358e31d3ec"
>> Missing separate debuginfo for /usr/lib64/libQt5Concurrent.so.5
>> Try: zypper install -C "debuginfo(build-id)=4dadc441d
>> c469afe49d9850699f31a7324e0e927"
>> Missing separate debuginfo for /usr/lib64/libqca-qt5.so.2
>> Try: zypper install -C "debuginfo(build-id)=60085683d
>> 66412fa8cd5115bbeebd480147d318c"
>> Missing separate debuginfo for /usr/lib64/libqtkeychain.so.1
>> Try: zypper install -C "debuginfo(build-id)=ed261e76f
>> 91f07140c296100281ce1f576feefe4"
>> Missing separate debuginfo for /usr/lib64/libspatialindex.so.4
>> Try: zypper install -C "debuginfo(build-id)=9f564e1e3
>> 66b20d3ca3e06fa04679179161d622e"
>> Missing separate debuginfo for /usr/lib64/libexpat.so.1
>> Try: zypper install -C "debuginfo(build-id)=6500c00be
>> a1aa9bb1c023c36c4aa1f4456629328"
>> Missing separate debuginfo for /usr/lib64/libsqlite3.so.0
>> Try: zypper install -C "debuginfo(build-id)=e1e1fc6b0
>> e94dc99724b564dd44ff250b34535a5"
>> Missing separate debuginfo for /usr/lib64/libzip.so.5
>> Try: zypper install -C "debuginfo(build-id)=7cc74fd6a
>> baa715de4a46d34483134f6f932b703"
>> Missing separate debuginfo for /usr/lib64/libQt5Positioning.so.5
>> Try: zypper install -C "debuginfo(build-id)=b03cb1d41
>> b0f1808da19ae63a38ecc8947bd95a9"
>> Missing separate debuginfo for /usr/lib64/libQt5Core.so.5
>> Try: zypper install -C "debuginfo(build-id)=38f3eda83
>> 1a9c5e39e513a072b5c8f9a0a2707d1"
>> Missing separate debuginfo for /usr/lib64/libstdc++.so.6
>> Try: zypper install -C "debuginfo(build-id)=5173cf3c2
>> 0dbaf430ec13b12bb8fa4730e17f048"
>> Missing separate debuginfo for /lib64/libm.so.6
>> Try: zypper install -C "debuginfo(build-id)=918225cf6
>> b6ff0c6c8dd92643b45c81b25a92c63"
>> Missing separate debuginfo for /lib64/libgcc_s.so.1
>> Try: zypper install -C "debuginfo(build-id)=642b28ab8
>> de504fa60c105e7a178e1a2805181cc"
>> Missing separate debuginfo for /lib64/libc.so.6
>> Try: zypper install -C "debuginfo(build-id)=b5b558c30
>> ba01bc47a8201373569afa3df140522"
>> Missing separate debuginfo for /usr/lib64/libQt5OpenGL.so.5
>> Try: zypper install -C "debuginfo(build-id)=d212b1cc9
>> 5cdf3a6fee6ed7fdbc93bdf1f31f3df"
>> Missing separate debuginfo for /lib64/ld-linux-x86-64.so.2
>> Try: zypper install -C "debuginfo(build-id)=3b92738c1
>> 958b86aee8b14adbebf9d2dc4a84c02"
>> Missing separate debuginfo for /lib64/libz.so.1
>> Try: zypper install -C "debuginfo(build-id)=393294980
>> f1a4bb24bd8e1cb86ef77e791afb0f6"
>> Missing separate debuginfo for /lib64/libpthread.so.0
>> Try: zypper install -C "debuginfo(build-id)=00ad8e7c4
>> 13091d45bb349f105a4b3e466e367a7"
>> [Thread debugging using libthread_db enabled]
>> Using host libthread_db library "/lib64/libthread_db.so.1".
>> Missing separate debuginfo for /usr/lib64/libGL.so.1
>> Try: zypper install -C "debuginfo(build-id)=3f6a5a081
>> 96a28c3e3bb7b0da22c196e4863314e"
>> Missing separate debuginfo for /usr/lib64/libpng16.so.16
>> Try: zypper install -C "debuginfo(build-id)=6f8d1393a
>> 956fccc0f9f53788660bff1a07cd274"
>> Missing separate debuginfo for /usr/lib64/libharfbuzz.so.0
>> Try: zypper install -C "debuginfo(build-id)=50b253c0a
>> fbd7e7d5a95ce169be3e2414fa4706a"
>> Missing separate debuginfo for /usr/lib64/libproxy.so.1
>> Try: zypper install -C "debuginfo(build-id)=26075f6aa
>> 769e887613299c7a68335a198873400"
>> Missing separate debuginfo for /lib64/libdl.so.2
>> Try: zypper install -C "debuginfo(build-id)=afe13cfdc
>> f1d5312417df860e5cbe4fee96d8c62"
>> Missing separate debuginfo for /usr/lib64/libssl.so.1.1
>> Try: zypper install -C "debuginfo(build-id)=06f613d8a
>> 2f173d8b65771fa7102602a4b957933"
>> Missing separate debuginfo for /usr/lib64/libcrypto.so.1.1
>> Try: zypper install -C "debuginfo(build-id)=b49c0f03a
>> 6535754553266b3f483cfd825bac441"
>> Missing separate debuginfo for /usr/lib64/libQtCore.so.4
>> Try: zypper install -C "debuginfo(build-id)=311a78a67
>> d17345da79e08b58811dd4ee0957fe4"
>> Missing separate debuginfo for /usr/lib64/libQtDBus.so.4
>> Try: zypper install -C "debuginfo(build-id)=6d534db0a
>> 08650938697ab7da51330068d88bc48"
>> Missing separate debuginfo for /usr/lib64/libwebp.so.6
>> Try: zypper install -C "debuginfo(build-id)=e5773c95d
>> 44ba88bdbf38f9a98f48fdad514d9c3"
>> Missing separate debuginfo for /usr/lib64/libodbc.so.2
>> Try: zypper install -C "debuginfo(build-id)=01b250dde
>> 290257b7f19881e0db3d927f4dd7e93"
>> Missing separate debuginfo for /usr/lib64/libodbcinst.so.2
>> Try: zypper install -C "debuginfo(build-id)=86987b20f
>> 7c03d412d944b62d4679a7787489bde"
>> Missing separate debuginfo for /usr/lib64/libhdf5.so.101
>> Try: zypper install -C "debuginfo(build-id)=efdfbf5a8
>> 56f6ae09f3a2be58ad0429a959d021a"
>> Missing separate debuginfo for /usr/lib64/libgif.so.7
>> Try: zypper install -C "debuginfo(build-id)=85a02d3d8
>> 37974258f2c1853ed6ff19a5505b39f"
>> Missing separate debuginfo for /usr/lib64/libjpeg.so.8
>> Try: zypper install -C "debuginfo(build-id)=626672faa
>> a93192ee959a6c2a161b6bfff93c0c8"
>> Missing separate debuginfo for /lib64/librt.so.1
>> Try: zypper install -C "debuginfo(build-id)=0df329353
>> 57efd4230b61ff61c86d41b451bf4a5"
>> Missing separate debuginfo for /usr/lib64/libpcre.so.1
>> Try: zypper install -C "debuginfo(build-id)=c49115d2b
>> a8c6df024395408e32d3583596b4828"
>> Missing separate debuginfo for /usr/lib64/libcurl.so.4
>> Try: zypper install -C "debuginfo(build-id)=acb1d5764
>> b8d85f82ca93c0bc63b721c77e6775a"
>> Missing separate debuginfo for /usr/lib64/libxml2.so.2
>> Try: zypper install -C "debuginfo(build-id)=fb063824b
>> 39bb6ac23e8ab31cf1d4fa32b972d1b"
>> Missing separate debuginfo for /usr/lib64/liblzma.so.5
>> Try: zypper install -C "debuginfo(build-id)=b5e4f0176
>> a9c38afae0f4254e4e71fb80c70015a"
>> Missing separate debuginfo for /usr/lib64/libbz2.so.1
>> Try: zypper install -C "debuginfo(build-id)=78a5e01ad
>> e6b3d8db9bc9bcf7d7452c057ab7ac1"
>> Missing separate debuginfo for /usr/lib64/libsystemd.so.0
>> Try: zypper install -C "debuginfo(build-id)=7f1454e1f
>> f426b99fddfa292f35ee9e343534576"
>> Missing separate debuginfo for /usr/lib64/libicui18n.so.60.2
>> Try: zypper install -C "debuginfo(build-id)=cb0b83305
>> 84b5ba73c771804127abd0fb8f9ee8a"
>> Missing separate debuginfo for /usr/lib64/libicuuc.so.60.2
>> Try: zypper install -C "debuginfo(build-id)=6cfc5c5ca
>> 656d7f4d937d0a20531556eb7df004d"
>> Missing separate debuginfo for /usr/lib64/libdouble-conversion.so.1
>> Try: zypper install -C "debuginfo(build-id)=2e3fe9156
>> 462d55f660830566af577c7f9a4d4bf"
>> Missing separate debuginfo for /usr/lib64/libglib-2.0.so.0
>> Try: zypper install -C "debuginfo(build-id)=7dfb5c109
>> 8f8e3bca84da342dfa27ab5bd84ec07"
>> Missing separate debuginfo for /usr/lib64/libGLX.so.0
>> Try: zypper install -C "debuginfo(build-id)=1ad40bdfe
>> 9fa6c5f4597769e8fd76ea2d9e9760e"
>> Missing separate debuginfo for /usr/lib64/libGLdispatch.so.0
>> Try: zypper install -C "debuginfo(build-id)=ddeeafa18
>> db92852cb4bd8cf1cf829ea203e9d38"
>> Missing separate debuginfo for /usr/lib64/libfreetype.so.6
>> Try: zypper install -C "debuginfo(build-id)=363462ea5
>> 3ed88710f3aec2d879af9f9bde7cd1b"
>> Missing separate debuginfo for /usr/lib64/libgraphite2.so.3
>> Try: zypper install -C "debuginfo(build-id)=354246a89
>> 66215f97f061f45d06ecaeea6697b35"
>> Missing separate debuginfo for /usr/lib64/libmodman.so.1
>> Try: zypper install -C "debuginfo(build-id)=dc3a3d55e
>> 8d3a1dbdc6f81b8fc4ff90d92590bb1"
>> Missing separate debuginfo for /usr/lib64/libQtXml.so.4
>> Try: zypper install -C "debuginfo(build-id)=aaaaf1866
>> aec8ca07312279b2d3c6f4857d6b41d"
>> Missing separate debuginfo for /usr/lib64/libdbus-1.so.3
>> Try: zypper install -C "debuginfo(build-id)=fc584f507
>> fe77479b62a02843d026e66c1b7675f"
>> Missing separate debuginfo for /usr/lib64/libltdl.so.7
>> Try: zypper install -C "debuginfo(build-id)=05a9f08fb
>> c174560c6d610279aeb42e0ac560502"
>> Missing separate debuginfo for /usr/lib64/libhdf5_hl.so.100
>> Try: zypper install -C "debuginfo(build-id)=e9b0456bb
>> 80d3faec87d16914d095c2a6ba544ab"
>> Missing separate debuginfo for /usr/lib64/libtiff.so.5
>> Try: zypper install -C "debuginfo(build-id)=db4776448
>> c2d936ea3a2f52044a3c783bb4353e6"
>> Missing separate debuginfo for /usr/lib64/libnghttp2.so.14
>> Try: zypper install -C "debuginfo(build-id)=e6cc303ce
>> 1f7fe14bbc1449b11f316240cc3b600"
>> Missing separate debuginfo for /usr/lib64/libidn2.so.0
>> Try: zypper install -C "debuginfo(build-id)=a7c724b22
>> 47b901cf02636ffb4cd1579eeee53de"
>> Missing separate debuginfo for /usr/lib64/libssh.so.4
>> Try: zypper install -C "debuginfo(build-id)=de96783ed
>> d96e12a3200133ad07f7d3f2c647c34"
>> Missing separate debuginfo for /usr/lib64/libpsl.so.5
>> Try: zypper install -C "debuginfo(build-id)=2ab0bb32a
>> 9c0e29652f262714e90268c514e1abf"
>> Missing separate debuginfo for /usr/lib64/libgssapi_krb5.so.2
>> Try: zypper install -C "debuginfo(build-id)=f69bc647a
>> bca1f83de1c1e6c6a15b82d24961ce9"
>> Missing separate debuginfo for /usr/lib64/libldap_r-2.4.so.2
>> Try: zypper install -C "debuginfo(build-id)=8318f5d40
>> aa3c7c0501f804c2ed33545a04172ec"
>> Missing separate debuginfo for /usr/lib64/liblber-2.4.so.2
>> Try: zypper install -C "debuginfo(build-id)=14ded17a5
>> 686423b97b6a4b0b9456acd372faeb3"
>> Missing separate debuginfo for /lib64/libresolv.so.2
>> Try: zypper install -C "debuginfo(build-id)=ecc5fd5f9
>> 0d7b5454477387d0a00c68ef5568bff"
>> Missing separate debuginfo for /lib64/libselinux.so.1
>> Try: zypper install -C "debuginfo(build-id)=0e6d5b629
>> 43990607d0f3199e3fe7f47d729c4f3"
>> Missing separate debuginfo for /usr/lib64/libcap.so.2
>> Try: zypper install -C "debuginfo(build-id)=a055a722c
>> 16b775c462afd06d7e106f21b8b96f3"
>> Missing separate debuginfo for /usr/lib64/liblz4.so.1
>> Try: zypper install -C "debuginfo(build-id)=9d3b2b673
>> 46705c61874113869fc49cda1e59f7e"
>> Missing separate debuginfo for /usr/lib64/libgcrypt.so.20
>> Try: zypper install -C "debuginfo(build-id)=30bb1b00b
>> 79d1f415fbb2783c386955806bc8a2e"
>> Missing separate debuginfo for /usr/lib64/libgpg-error.so.0
>> Try: zypper install -C "debuginfo(build-id)=c5812b92d
>> 66f7cdd4e4e8f284c1b4d629356a80d"
>> Missing separate debuginfo for /usr/lib64/libicudata.so.60.2
>> Try: zypper install -C "debuginfo(build-id)=b11f25a02
>> 9eb1867928e30aa67f45389b12125bf"
>> Missing separate debuginfo for /usr/lib64/libX11.so.6
>> Try: zypper install -C "debuginfo(build-id)=ff867c578
>> f2ecf893655d95d851f9c455706ea56"
>> Missing separate debuginfo for /usr/lib64/libjbig.so.2
>> Try: zypper install -C "debuginfo(build-id)=63bb61fe5
>> 0e1782c7e093583580c9dea81f23527"
>> Missing separate debuginfo for /usr/lib64/libunistring.so.2
>> Try: zypper install -C "debuginfo(build-id)=dbfbcf61e
>> 46f675ba21cef54c7e6d8664a73b352"
>> Missing separate debuginfo for /usr/lib64/libkrb5.so.3
>> Try: zypper install -C "debuginfo(build-id)=0de532121
>> b065c5392f821fafb746dce5d3a0f6c"
>> Missing separate debuginfo for /usr/lib64/libk5crypto.so.3
>> Try: zypper install -C "debuginfo(build-id)=fb9067921
>> 25f8d7051467385437a8fc9cf02cb99"
>> Missing separate debuginfo for /lib64/libcom_err.so.2
>> Try: zypper install -C "debuginfo(build-id)=08d06eee4
>> c6ad0456fa95ce2aece2b428e085320"
>> Missing separate debuginfo for /usr/lib64/libkrb5support.so.0
>> Try: zypper install -C "debuginfo(build-id)=5e2403de3
>> d110d7c06ef2d111df16b458521fcd2"
>> Missing separate debuginfo for /usr/lib64/libsasl2.so.3
>> Try: zypper install -C "debuginfo(build-id)=759a9482d
>> 40bf68183e123300d666cda580d3ccc"
>> Missing separate debuginfo for /usr/lib64/libxcb.so.1
>> Try: zypper install -C "debuginfo(build-id)=f452cb119
>> f2b0a56cd2b9fda126731693c914619"
>> Missing separate debuginfo for /usr/lib64/libkeyutils.so.1
>> Try: zypper install -C "debuginfo(build-id)=0fbaed760
>> 0db1edbbc687dfb885f47d958946b1c"
>> Missing separate debuginfo for /usr/lib64/libXau.so.6
>> Try: zypper install -C "debuginfo(build-id)=9ad19a9b7
>> 7ab3c7217d4e01f9d3369848a2a5d2e"
>> Missing separate debuginfo for /usr/lib64/qt5/plugins/platfor
>> ms/libqxcb.so
>> Try: zypper install -C "debuginfo(build-id)=1f8f5b53b
>> fdc9b5caadfc9d8d8381a55c4f27b6a"
>> Missing separate debuginfo for /usr/lib64/libQt5XcbQpa.so.5
>> Try: zypper install -C "debuginfo(build-id)=574d2ce01
>> 6210d5cd3f8c612653301f799831466"
>> Missing separate debuginfo for /usr/lib64/libfontconfig.so.1
>> Try: zypper install -C "debuginfo(build-id)=3ac41d743
>> c1c3e1c3bc27e7a10929b03b5c954cd"
>> Missing separate debuginfo for /usr/lib64/libQt5DBus.so.5
>> Try: zypper install -C "debuginfo(build-id)=84213703e
>> f91c226b3d177b2025fe81ed6fb5c0e"
>> Missing separate debuginfo for /usr/lib64/libX11-xcb.so.1
>> Try: zypper install -C "debuginfo(build-id)=0545e1949
>> ffad8c4a789126170e1e4376503fe45"
>> Missing separate debuginfo for /usr/lib64/libXi.so.6
>> Try: zypper install -C "debuginfo(build-id)=ceeab058d
>> ec326fc3505fe5d2bef69fd67cebf47"
>> Missing separate debuginfo for /usr/lib64/libSM.so.6
>> Try: zypper install -C "debuginfo(build-id)=490891d1d
>> cbd60b05902aa61bf9058ebdddac8cf"
>> Missing separate debuginfo for /usr/lib64/libICE.so.6
>> Try: zypper install -C "debuginfo(build-id)=447ef3f4f
>> a1bf8e88498e05625f2719631bc06eb"
>> Missing separate debuginfo for /usr/lib64/libxcb-xkb.so.1
>> Try: zypper install -C "debuginfo(build-id)=75803fcdc
>> 925628dd2476992c3a96b5070adb7b3"
>> Missing separate debuginfo for /usr/lib64/libxcb-render-util.so.0
>> Try: zypper install -C "debuginfo(build-id)=dbc98d19b
>> 4474cc1757558d0f4402be59d0a3309"
>> Missing separate debuginfo for /usr/lib64/libxcb-render.so.0
>> Try: zypper install -C "debuginfo(build-id)=d5668d121
>> e372edd7b38067625be3b1d7077ddb9"
>> Missing separate debuginfo for /usr/lib64/libxcb-sync.so.1
>> Try: zypper install -C "debuginfo(build-id)=25c722134
>> 6af63063ac54f7eb195ec5869540032"
>> Missing separate debuginfo for /usr/lib64/libxcb-xfixes.so.0
>> Try: zypper install -C "debuginfo(build-id)=93cbec4d5
>> 02369fa1942c2d47674bb4a8bc52f13"
>> Missing separate debuginfo for /usr/lib64/libxcb-xinerama.so.0
>> Try: zypper install -C "debuginfo(build-id)=c0b6b30ec
>> e1944c8cf6f85f4a4afed7205bc2655"
>> Missing separate debuginfo for /usr/lib64/libxcb-randr.so.0
>> Try: zypper install -C "debuginfo(build-id)=059aa8c00
>> b4c54c66bb9f07db79906fd78bb5f96"
>> Missing separate debuginfo for /usr/lib64/libxcb-image.so.0
>> Try: zypper install -C "debuginfo(build-id)=a2a8f1038
>> 082364579278a5acdc65341b8c043f7"
>> Missing separate debuginfo for /usr/lib64/libxcb-shm.so.0
>> Try: zypper install -C "debuginfo(build-id)=944b7e1e3
>> 6d2f5ec8bfe2ab76abf35d8a6ce220e"
>> Missing separate debuginfo for /usr/lib64/libxcb-keysyms.so.1
>> Try: zypper install -C "debuginfo(build-id)=d65557a7d
>> 948f50280ef185837b97f2babbe4c82"
>> Missing separate debuginfo for /usr/lib64/libxcb-icccm.so.4
>> Try: zypper install -C "debuginfo(build-id)=fb59991a8
>> 467fd61363124e41c1c7c9e0e9d1f56"
>> Missing separate debuginfo for /usr/lib64/libxcb-shape.so.0
>> Try: zypper install -C "debuginfo(build-id)=3ec6ae47e
>> 663c25e670669ad7638b04f0b38e6cb"
>> Missing separate debuginfo for /usr/lib64/libxkbcommon-x11.so.0
>> Try: zypper install -C "debuginfo(build-id)=3c7c72013
>> 7a01053700412c63b1f4e747b32ebac"
>> Missing separate debuginfo for /usr/lib64/libxkbcommon.so.0
>> Try: zypper install -C "debuginfo(build-id)=dc752531e
>> f6dea01cde8ad3fec74ad4fb9dc42f1"
>> Missing separate debuginfo for /usr/lib64/libXext.so.6
>> Try: zypper install -C "debuginfo(build-id)=fe1f91070
>> 49ede7c35286dab93700b798365b895"
>> Missing separate debuginfo for /usr/lib64/libuuid.so.1
>> Try: zypper install -C "debuginfo(build-id)=0a2815953
>> 252f036958f3f043833e4d394ea18c8"
>> Missing separate debuginfo for /usr/lib64/libxcb-util.so.1
>> Try: zypper install -C "debuginfo(build-id)=f7ac95970
>> dca43ab33ad52ff08aaa668cd78ffd4"
>> Missing separate debuginfo for /usr/lib64/libXcursor.so.1
>> Try: zypper install -C "debuginfo(build-id)=45886473b
>> ecd10a9bf1705a7cff86d5276af76b1"
>> Missing separate debuginfo for /usr/lib64/libXrender.so.1
>> Try: zypper install -C "debuginfo(build-id)=26742b2ff
>> 984147a2c7508148704b3cb2f752038"
>> Missing separate debuginfo for /usr/lib64/libXfixes.so.3
>> Try: zypper install -C "debuginfo(build-id)=aa047315a
>> c397f95aa829f479b1039b63aa05809"
>> Missing separate debuginfo for /usr/lib64/qt5/plugins/xcbglin
>> tegrations/libqxcb-glx-integration.so
>> Try: zypper install -C "debuginfo(build-id)=f88d07942
>> e67292b9580a1d746e8e9d343e586af"
>> Missing separate debuginfo for /usr/lib64/libxcb-glx.so.0
>> Try: zypper install -C "debuginfo(build-id)=6fe7632ac
>> 563fa6afc4f058d2b6c9b8bcbe9f44d"
>> mthemes/libqgtk2.so
>> Try: zypper install -C "debuginfo(build-id)=72b3ac22d
>> 02b403017e0d9fb23f72b89c1df1698"
>> Missing separate debuginfo for /usr/lib64/libgtk-x11-2.0.so.0
>> Try: zypper install -C "debuginfo(build-id)=78a96e5e0
>> d18aca5d63f07f1ba96418d654578b3"
>> Missing separate debuginfo for /usr/lib64/libgdk-x11-2.0.so.0
>> Try: zypper install -C "debuginfo(build-id)=5d133f917
>> df46cfeb3a1501c3fd85420f29077eb"
>> Missing separate debuginfo for /usr/lib64/libpango-1.0.so.0
>> Try: zypper install -C "debuginfo(build-id)=4fd506f39
>> a9b8b77760d0c1d287b99bf21a93644"
>> Missing separate debuginfo for /usr/lib64/libgobject-2.0.so.0
>> Try: zypper install -C "debuginfo(build-id)=2af4acce6
>> 80f8e44d6d27878702948d91220b82e"
>> Missing separate debuginfo for /usr/lib64/libgmodule-2.0.so.0
>> Try: zypper install -C "debuginfo(build-id)=01fe244ff
>> 6ebb593a149f9e01e94848a5778ece2"
>> Missing separate debuginfo for /usr/lib64/libpangocairo-1.0.so.0
>> Try: zypper install -C "debuginfo(build-id)=fa1d34a20
>> 85db3801a612741284dce89769b8d52"
>> Missing separate debuginfo for /usr/lib64/libatk-1.0.so.0
>> Try: zypper install -C "debuginfo(build-id)=176126552
>> 6fc5fe25c8046334eed5696942df876"
>> Missing separate debuginfo for /usr/lib64/libcairo.so.2
>> Try: zypper install -C "debuginfo(build-id)=6aaf1598f
>> 5797268dd29566f2c411bdfb45a46d1"
>> Missing separate debuginfo for /usr/lib64/libgdk_pixbuf-2.0.so.0
>> Try: zypper install -C "debuginfo(build-id)=f6871d73e
>> 2b0d6eccaebe11cfd63a691013658e5"
>> Missing separate debuginfo for /usr/lib64/libgio-2.0.so.0
>> Try: zypper install -C "debuginfo(build-id)=3f8d76f60
>> fe8961f2499f0d9c3a5fbbbff220564"
>> Missing separate debuginfo for /usr/lib64/libpangoft2-1.0.so.0
>> Try: zypper install -C "debuginfo(build-id)=3029bae74
>> 0e94a74913fdcab9fdda3f84f47b968"
>> Missing separate debuginfo for /usr/lib64/libXinerama.so.1
>> Try: zypper install -C "debuginfo(build-id)=764d559bd
>> c75ec52c17065bb5df95f7acff88473"
>> Missing separate debuginfo for /usr/lib64/libXrandr.so.2
>> Try: zypper install -C "debuginfo(build-id)=b83f2e888
>> 2df57fe854139c84ea4a00697a8277d"
>> Missing separate debuginfo for /usr/lib64/libXcomposite.so.1
>> Try: zypper install -C "debuginfo(build-id)=551fca4a9
>> e6ac9bd7d90246692bfc4e2469940ff"
>> Missing separate debuginfo for /usr/lib64/libXdamage.so.1
>> Try: zypper install -C "debuginfo(build-id)=4756f2ec5
>> 596947bebd4bd183557decba44fec6b"
>> Missing separate debuginfo for /usr/lib64/libthai.so.0
>> Try: zypper install -C "debuginfo(build-id)=9c25e54f2
>> 5d6784d415e8db48094f40052c0b0db"
>> Missing separate debuginfo for /usr/lib64/libffi.so.7
>> Try: zypper install -C "debuginfo(build-id)=6a8e76464
>> a8f8f17118793f0b43d45a226392039"
>> Missing separate debuginfo for /usr/lib64/libpixman-1.so.0
>> Try: zypper install -C "debuginfo(build-id)=38b33ac1a
>> 1347aa0903444f36f96f4def77424f8"
>> Missing separate debuginfo for /usr/lib64/libEGL.so.1
>> Try: zypper install -C "debuginfo(build-id)=48ee2deff
>> ee9609f2808ebc0a97bef0465aa5846"
>> Missing separate debuginfo for /usr/lib64/libmount.so.1
>> Try: zypper install -C "debuginfo(build-id)=e2bb051ab
>> 7dbc168b1f2411965311ea20cef92b4"
>> Missing separate debuginfo for /usr/lib64/libdatrie.so.1
>> Try: zypper install -C "debuginfo(build-id)=0d2835e1d
>> dd1d8c86a887c19a38a5b4ae707fb59"
>> Missing separate debuginfo for /usr/lib64/libblkid.so.1
>> Try: zypper install -C "debuginfo(build-id)=b394c5d74
>> 6855f00a87c97ec173fc0ad7ea5ec14"
>> Missing separate debuginfo for /usr/lib64/gtk-2.0/modules/lib
>> canberra-gtk-module.so
>> Try: zypper install -C "debuginfo(build-id)=132c4af6d
>> 309f7ee188f389e6a55dcfa1a162bfc"
>> Missing separate debuginfo for /usr/lib64/libcanberra-gtk.so.0
>> Try: zypper install -C "debuginfo(build-id)=66436c1a3
>> 52e91d57cb357d5956baf7ff4b7a864"
>> Missing separate debuginfo for /usr/lib64/libcanberra.so.0
>> Try: zypper install -C "debuginfo(build-id)=9a6346b2b
>> a4e6a5a0f910321eef2d6bd5e2a4054"
>> Missing separate debuginfo for /usr/lib64/libvorbisfile.so.3
>> Try: zypper install -C "debuginfo(build-id)=ab6cd4515
>> ea838342503b6b49f0a10ca3cc6f99b"
>> Missing separate debuginfo for /usr/lib64/libvorbis.so.0
>> Try: zypper install -C "debuginfo(build-id)=3b9fc3187
>> 161236530cf16a311af84159ca6cf10"
>> Missing separate debuginfo for /usr/lib64/libogg.so.0
>> Try: zypper install -C "debuginfo(build-id)=a1ba55e2e
>> 3236d160e3d7facdd56f5201c5d3075"
>> Missing separate debuginfo for /usr/lib64/gtk-2.0/2.10.0/engi
>> nes/libadwaita.so
>> Try: zypper install -C "debuginfo(build-id)=1b0601f6e
>> cbef3211dc72a57c43805043b6826d7"
>> nes/libpixmap.so
>> Try: zypper install -C "debuginfo(build-id)=5ef566f06
>> bf5709e8cf90060a4408a2290ecb1a4"
>> minputcontexts/libibusplatforminputcontextplugin.so
>> Try: zypper install -C "debuginfo(build-id)=bf29e4734
>> 97b05ce7ea117dffe08074784f23b3b"
>> 0x00007f3acc786da7 in waitpid () from /lib64/libc.so.6
>> [Current thread is 1 (Thread 0x7f3ad6c6b940 (LWP 17857))]
>> #0 0x00007f3acc786da7 in waitpid () at /lib64/libc.so.6
>> #1 0x000000000040cd55 in qgisCrash(int) ()
>> #2 0x00007f3acc6f7160 in <signal handler called> () at /lib64/libc.so.6
>> #3 0x00007f3aca9255f9 in QReadWriteLock::QReadWriteLock() () at
>> #4 0x00007f3aca68180c in () at /usr/lib64/libQtDBus.so.4
>> #6 0x00007f3ab2a86086 in () at /usr/lib64/qt5/plugins/platfor
>> #7 0x00007f3ad12e6110 in QPlatformInputContextFactory::create(QString
>> const&) () at /usr/lib64/libQt5Gui.so.5
>> #8 0x00007f3abf97d5ad in QXcbIntegration::initialize() () at
>> #9 0x00007f3ad12fc539 in QGuiApplicationPrivate::eventDispatcherReady()
>> #10 0x00007f3acd5f04e5 in QCoreApplicationPrivate::init() () at
>> #11 0x00007f3ad12fdd5c in QGuiApplicationPrivate::init() () at
>> #12 0x00007f3ad1ac5999 in QApplicationPrivate::init() () at
>> #13 0x00007f3ad314e4a4 in QgsApplication::QgsApplication(int&, char**,
>> bool, QString const&, QString const&) () at /usr/local/lib/libqgis_core.so
>> .3.0.3
>> #14 0x000000000040f716 in main ()
>> gdb returned 0
>> Aborted (core dumped)
>> Qgis-user mailing list
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
> Alessandro Pasotti
> w3: www.itopen.it
> Qgis-user mailing listQgis-user at lists.osgeo.org
Alessandro Pasotti
w3: www.itopen.it
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20180618/2fd525c0/attachment.html>
