[Qgis-user] QGIS 3.0.3 died on signal 11: what did go wrong? [SOLVED]
Hernán De Angelis dhdeangelis at comhem.se
Mon Jun 18 09:15:10 PDT 2018
Thank you, Alessandro, you contributed a lot by pointing out that I was
wrongly linking to qt4.
I will have a look to these docs. Perhaps the most important thing is to
make a reminder to ensure that qmake and dependencies shall not link to
qt4. This is arguably obvious, but it is easy to overlook. It is also
not so easy to fix if one is not at least a bit involved in Linux
programming or sysadmin.
The ideal solution would be to link all standard libraries to qt5
directly in openSUSE, but that's another story and will probably brake
other things.
H.
On 06/18/2018 04:29 PM, Alessandro Pasotti wrote:
> On Mon, Jun 18, 2018 at 3:53 PM, Hernán De Angelis
> <dhdeangelis at comhem.se <mailto:dhdeangelis at comhem.se>> wrote:
>     In case this is of interest, I spent a few hours tracing down the
>     causes of this problem and found them:
>     1. in openSUSE Leap 15 "qmake" is qt4. Solution: replace "qmake"
>     by a symbolic link to "qmake-qt5". I also preemptively deleted
>     libqt4 during the compilation of QGIS
>     2. in openSUSE Leap 15 the provided qwt package is precompiled
>     against qt4. I compiled my own qwt against qt5
>     Things went smoothly after that, but it took some effort to find out.
>     This is not the first time I experience hassle because of things
>     linked to different qt versions. It is not fun. I hope others can
>     read this an avoid the trouble.
>     /H.
> Thanks for sharing, glad to know that you could finally build and run it.
> We have some developer docs about building QGIS on different
> platforms, if you feel like contributing to it, here is the document:
> https://github.com/qgis/QGIS/blob/master/INSTALL
>     On 06/18/2018 12:25 PM, Hernán De Angelis wrote:
>>     Thank you for this insight. You are right, it is indeed libqt4
>>     that gets linked, despite all of libqt5 being present. I will
>>     have to figure out a way around.
>>     Thanks again
>>     /H.
>>     On 06/18/2018 12:11 PM, Alessandro Pasotti wrote:
>>>     Looks like you're loading Qt4 lib here:
>>>     #5  0x00007f3aca681d45 in
>>>     QDBusMetaType::registerMarshallOperators(int, void
>>>     (*)(QDBusArgument&, void const*), void (*)(QDBusArgument const&,
>>>     void*)) () at /usr/lib64/libQtDBus.so.4
>>>     On Mon, Jun 18, 2018 at 10:42 AM, Hernán De Angelis
>>>         Fellow QGIS users,
>>>         I am experiencing a crash on starting QGIS 3.0.3: it dies in
>>>         signal 11. I compiled QGIS from source and absolutely no
>>>         problems or warnings where experienced during the build.
>>>         This happens on a fresh new installation of openSUSE (Leap 15).
>>>         I will appreciate if you could give me some hints into what
>>>         could have gone wrong and what potential solutions may I apply.
>>>         Please, find the crash report below.
>>>         Thanks in advance
>>>         H.
>>>         QGIS died on signal 11[New LWP 17858]
>>>         Missing separate debuginfo for /usr/lib64/libqwt-qt5.so.6
>>>         Try: zypper install -C
>>>         "debuginfo(build-id)=439218fd22c78120825b3b640c05e3464063479c"
>>>         /usr/lib64/libqscintilla2_qt5.so.13
>>>         "debuginfo(build-id)=446a73c58a5766f3728da6081dfe5890e513b044"
>>>         Missing separate debuginfo for /usr/lib64/libQt5Sql.so.5
>>>         "debuginfo(build-id)=2fc4bf082c9455eb0002efeb97c2e0a5aa6448ec"
>>>         Missing separate debuginfo for /usr/lib64/libQt5Xml.so.5
>>>         "debuginfo(build-id)=01539f679a20ff25fb02be87c1e9d1a324aa9726"
>>>         Missing separate debuginfo for /usr/lib64/libQt5Svg.so.5
>>>         "debuginfo(build-id)=24fbed0cb29b72e529ff7911963e067cd2f65bca"
>>>         /usr/lib64/libQt5PrintSupport.so.5
>>>         "debuginfo(build-id)=aa1018b0cd07ec7d7dfe909e6b941b1b42ef12cb"
>>>         Missing separate debuginfo for /usr/lib64/libQt5Widgets.so.5
>>>         "debuginfo(build-id)=83c5d92ad8980d21c5090c41cc181238f6b08968"
>>>         Missing separate debuginfo for /usr/lib64/libQt5Gui.so.5
>>>         "debuginfo(build-id)=b611a3c0161096e5be012368ae1b7db287e302c2"
>>>         Missing separate debuginfo for /usr/lib64/libQt5Network.so.5
>>>         "debuginfo(build-id)=ea72880f67944480ad502f5c017900358e31d3ec"
>>>         Missing separate debuginfo for /usr/lib64/libQt5Concurrent.so.5
>>>         "debuginfo(build-id)=4dadc441dc469afe49d9850699f31a7324e0e927"
>>>         Missing separate debuginfo for /usr/lib64/libqca-qt5.so.2
>>>         "debuginfo(build-id)=60085683d66412fa8cd5115bbeebd480147d318c"
>>>         Missing separate debuginfo for /usr/lib64/libqtkeychain.so.1
>>>         "debuginfo(build-id)=ed261e76f91f07140c296100281ce1f576feefe4"
>>>         Missing separate debuginfo for /usr/lib64/libspatialindex.so.4
>>>         "debuginfo(build-id)=9f564e1e366b20d3ca3e06fa04679179161d622e"
>>>         Missing separate debuginfo for /usr/lib64/libexpat.so.1
>>>         "debuginfo(build-id)=6500c00bea1aa9bb1c023c36c4aa1f4456629328"
>>>         Missing separate debuginfo for /usr/lib64/libsqlite3.so.0
>>>         "debuginfo(build-id)=e1e1fc6b0e94dc99724b564dd44ff250b34535a5"
>>>         Missing separate debuginfo for /usr/lib64/libzip.so.5
>>>         "debuginfo(build-id)=7cc74fd6abaa715de4a46d34483134f6f932b703"
>>>         Missing separate debuginfo for /usr/lib64/libQt5Positioning.so.5
>>>         "debuginfo(build-id)=b03cb1d41b0f1808da19ae63a38ecc8947bd95a9"
>>>         Missing separate debuginfo for /usr/lib64/libQt5Core.so.5
>>>         "debuginfo(build-id)=38f3eda831a9c5e39e513a072b5c8f9a0a2707d1"
>>>         Missing separate debuginfo for /usr/lib64/libstdc++.so.6
>>>         "debuginfo(build-id)=5173cf3c20dbaf430ec13b12bb8fa4730e17f048"
>>>         Missing separate debuginfo for /lib64/libm.so.6
>>>         "debuginfo(build-id)=918225cf6b6ff0c6c8dd92643b45c81b25a92c63"
>>>         Missing separate debuginfo for /lib64/libgcc_s.so.1
>>>         "debuginfo(build-id)=642b28ab8de504fa60c105e7a178e1a2805181cc"
>>>         Missing separate debuginfo for /lib64/libc.so.6
>>>         "debuginfo(build-id)=b5b558c30ba01bc47a8201373569afa3df140522"
>>>         Missing separate debuginfo for /usr/lib64/libQt5OpenGL.so.5
>>>         "debuginfo(build-id)=d212b1cc95cdf3a6fee6ed7fdbc93bdf1f31f3df"
>>>         Missing separate debuginfo for /lib64/ld-linux-x86-64.so.2
>>>         "debuginfo(build-id)=3b92738c1958b86aee8b14adbebf9d2dc4a84c02"
>>>         Missing separate debuginfo for /lib64/libz.so.1
>>>         "debuginfo(build-id)=393294980f1a4bb24bd8e1cb86ef77e791afb0f6"
>>>         Missing separate debuginfo for /lib64/libpthread.so.0
>>>         "debuginfo(build-id)=00ad8e7c413091d45bb349f105a4b3e466e367a7"
>>>         [Thread debugging using libthread_db enabled]
>>>         Using host libthread_db library "/lib64/libthread_db.so.1".
>>>         Missing separate debuginfo for /usr/lib64/libGL.so.1
>>>         "debuginfo(build-id)=3f6a5a08196a28c3e3bb7b0da22c196e4863314e"
>>>         Missing separate debuginfo for /usr/lib64/libpng16.so.16
>>>         "debuginfo(build-id)=6f8d1393a956fccc0f9f53788660bff1a07cd274"
>>>         Missing separate debuginfo for /usr/lib64/libharfbuzz.so.0
>>>         "debuginfo(build-id)=50b253c0afbd7e7d5a95ce169be3e2414fa4706a"
>>>         Missing separate debuginfo for /usr/lib64/libproxy.so.1
>>>         "debuginfo(build-id)=26075f6aa769e887613299c7a68335a198873400"
>>>         Missing separate debuginfo for /lib64/libdl.so.2
>>>         "debuginfo(build-id)=afe13cfdcf1d5312417df860e5cbe4fee96d8c62"
>>>         Missing separate debuginfo for /usr/lib64/libssl.so.1.1
>>>         "debuginfo(build-id)=06f613d8a2f173d8b65771fa7102602a4b957933"
>>>         Missing separate debuginfo for /usr/lib64/libcrypto.so.1.1
>>>         "debuginfo(build-id)=b49c0f03a6535754553266b3f483cfd825bac441"
>>>         Missing separate debuginfo for /usr/lib64/libQtCore.so.4
>>>         "debuginfo(build-id)=311a78a67d17345da79e08b58811dd4ee0957fe4"
>>>         Missing separate debuginfo for /usr/lib64/libQtDBus.so.4
>>>         "debuginfo(build-id)=6d534db0a08650938697ab7da51330068d88bc48"
>>>         Missing separate debuginfo for /usr/lib64/libwebp.so.6
>>>         "debuginfo(build-id)=e5773c95d44ba88bdbf38f9a98f48fdad514d9c3"
>>>         Missing separate debuginfo for /usr/lib64/libodbc.so.2
>>>         "debuginfo(build-id)=01b250dde290257b7f19881e0db3d927f4dd7e93"
>>>         Missing separate debuginfo for /usr/lib64/libodbcinst.so.2
>>>         "debuginfo(build-id)=86987b20f7c03d412d944b62d4679a7787489bde"
>>>         Missing separate debuginfo for /usr/lib64/libhdf5.so.101
>>>         "debuginfo(build-id)=efdfbf5a856f6ae09f3a2be58ad0429a959d021a"
>>>         Missing separate debuginfo for /usr/lib64/libgif.so.7
>>>         "debuginfo(build-id)=85a02d3d837974258f2c1853ed6ff19a5505b39f"
>>>         Missing separate debuginfo for /usr/lib64/libjpeg.so.8
>>>         "debuginfo(build-id)=626672faaa93192ee959a6c2a161b6bfff93c0c8"
>>>         Missing separate debuginfo for /lib64/librt.so.1
>>>         "debuginfo(build-id)=0df32935357efd4230b61ff61c86d41b451bf4a5"
>>>         Missing separate debuginfo for /usr/lib64/libpcre.so.1
>>>         "debuginfo(build-id)=c49115d2ba8c6df024395408e32d3583596b4828"
>>>         Missing separate debuginfo for /usr/lib64/libcurl.so.4
>>>         "debuginfo(build-id)=acb1d5764b8d85f82ca93c0bc63b721c77e6775a"
>>>         Missing separate debuginfo for /usr/lib64/libxml2.so.2
>>>         "debuginfo(build-id)=fb063824b39bb6ac23e8ab31cf1d4fa32b972d1b"
>>>         Missing separate debuginfo for /usr/lib64/liblzma.so.5
>>>         "debuginfo(build-id)=b5e4f0176a9c38afae0f4254e4e71fb80c70015a"
>>>         Missing separate debuginfo for /usr/lib64/libbz2.so.1
>>>         "debuginfo(build-id)=78a5e01ade6b3d8db9bc9bcf7d7452c057ab7ac1"
>>>         Missing separate debuginfo for /usr/lib64/libsystemd.so.0
>>>         "debuginfo(build-id)=7f1454e1ff426b99fddfa292f35ee9e343534576"
>>>         Missing separate debuginfo for /usr/lib64/libicui18n.so.60.2
>>>         "debuginfo(build-id)=cb0b8330584b5ba73c771804127abd0fb8f9ee8a"
>>>         Missing separate debuginfo for /usr/lib64/libicuuc.so.60.2
>>>         "debuginfo(build-id)=6cfc5c5ca656d7f4d937d0a20531556eb7df004d"
>>>         /usr/lib64/libdouble-conversion.so.1
>>>         "debuginfo(build-id)=2e3fe9156462d55f660830566af577c7f9a4d4bf"
>>>         Missing separate debuginfo for /usr/lib64/libglib-2.0.so.0
>>>         "debuginfo(build-id)=7dfb5c1098f8e3bca84da342dfa27ab5bd84ec07"
>>>         Missing separate debuginfo for /usr/lib64/libGLX.so.0
>>>         "debuginfo(build-id)=1ad40bdfe9fa6c5f4597769e8fd76ea2d9e9760e"
>>>         Missing separate debuginfo for /usr/lib64/libGLdispatch.so.0
>>>         "debuginfo(build-id)=ddeeafa18db92852cb4bd8cf1cf829ea203e9d38"
>>>         Missing separate debuginfo for /usr/lib64/libfreetype.so.6
>>>         "debuginfo(build-id)=363462ea53ed88710f3aec2d879af9f9bde7cd1b"
>>>         Missing separate debuginfo for /usr/lib64/libgraphite2.so.3
>>>         "debuginfo(build-id)=354246a8966215f97f061f45d06ecaeea6697b35"
>>>         Missing separate debuginfo for /usr/lib64/libmodman.so.1
>>>         "debuginfo(build-id)=dc3a3d55e8d3a1dbdc6f81b8fc4ff90d92590bb1"
>>>         Missing separate debuginfo for /usr/lib64/libQtXml.so.4
>>>         "debuginfo(build-id)=aaaaf1866aec8ca07312279b2d3c6f4857d6b41d"
>>>         Missing separate debuginfo for /usr/lib64/libdbus-1.so.3
>>>         "debuginfo(build-id)=fc584f507fe77479b62a02843d026e66c1b7675f"
>>>         Missing separate debuginfo for /usr/lib64/libltdl.so.7
>>>         "debuginfo(build-id)=05a9f08fbc174560c6d610279aeb42e0ac560502"
>>>         Missing separate debuginfo for /usr/lib64/libhdf5_hl.so.100
>>>         "debuginfo(build-id)=e9b0456bb80d3faec87d16914d095c2a6ba544ab"
>>>         Missing separate debuginfo for /usr/lib64/libtiff.so.5
>>>         "debuginfo(build-id)=db4776448c2d936ea3a2f52044a3c783bb4353e6"
>>>         Missing separate debuginfo for /usr/lib64/libnghttp2.so.14
>>>         "debuginfo(build-id)=e6cc303ce1f7fe14bbc1449b11f316240cc3b600"
>>>         Missing separate debuginfo for /usr/lib64/libidn2.so.0
>>>         "debuginfo(build-id)=a7c724b2247b901cf02636ffb4cd1579eeee53de"
>>>         Missing separate debuginfo for /usr/lib64/libssh.so.4
>>>         "debuginfo(build-id)=de96783edd96e12a3200133ad07f7d3f2c647c34"
>>>         Missing separate debuginfo for /usr/lib64/libpsl.so.5
>>>         "debuginfo(build-id)=2ab0bb32a9c0e29652f262714e90268c514e1abf"
>>>         Missing separate debuginfo for /usr/lib64/libgssapi_krb5.so.2
>>>         "debuginfo(build-id)=f69bc647abca1f83de1c1e6c6a15b82d24961ce9"
>>>         Missing separate debuginfo for /usr/lib64/libldap_r-2.4.so.2
>>>         "debuginfo(build-id)=8318f5d40aa3c7c0501f804c2ed33545a04172ec"
>>>         Missing separate debuginfo for /usr/lib64/liblber-2.4.so.2
>>>         "debuginfo(build-id)=14ded17a5686423b97b6a4b0b9456acd372faeb3"
>>>         Missing separate debuginfo for /lib64/libresolv.so.2
>>>         "debuginfo(build-id)=ecc5fd5f90d7b5454477387d0a00c68ef5568bff"
>>>         Missing separate debuginfo for /lib64/libselinux.so.1
>>>         "debuginfo(build-id)=0e6d5b62943990607d0f3199e3fe7f47d729c4f3"
>>>         Missing separate debuginfo for /usr/lib64/libcap.so.2
>>>         "debuginfo(build-id)=a055a722c16b775c462afd06d7e106f21b8b96f3"
>>>         Missing separate debuginfo for /usr/lib64/liblz4.so.1
>>>         "debuginfo(build-id)=9d3b2b67346705c61874113869fc49cda1e59f7e"
>>>         Missing separate debuginfo for /usr/lib64/libgcrypt.so.20
>>>         "debuginfo(build-id)=30bb1b00b79d1f415fbb2783c386955806bc8a2e"
>>>         Missing separate debuginfo for /usr/lib64/libgpg-error.so.0
>>>         "debuginfo(build-id)=c5812b92d66f7cdd4e4e8f284c1b4d629356a80d"
>>>         Missing separate debuginfo for /usr/lib64/libicudata.so.60.2
>>>         "debuginfo(build-id)=b11f25a029eb1867928e30aa67f45389b12125bf"
>>>         Missing separate debuginfo for /usr/lib64/libX11.so.6
>>>         "debuginfo(build-id)=ff867c578f2ecf893655d95d851f9c455706ea56"
>>>         Missing separate debuginfo for /usr/lib64/libjbig.so.2
>>>         "debuginfo(build-id)=63bb61fe50e1782c7e093583580c9dea81f23527"
>>>         Missing separate debuginfo for /usr/lib64/libunistring.so.2
>>>         "debuginfo(build-id)=dbfbcf61e46f675ba21cef54c7e6d8664a73b352"
>>>         Missing separate debuginfo for /usr/lib64/libkrb5.so.3
>>>         "debuginfo(build-id)=0de532121b065c5392f821fafb746dce5d3a0f6c"
>>>         Missing separate debuginfo for /usr/lib64/libk5crypto.so.3
>>>         "debuginfo(build-id)=fb906792125f8d7051467385437a8fc9cf02cb99"
>>>         Missing separate debuginfo for /lib64/libcom_err.so.2
>>>         "debuginfo(build-id)=08d06eee4c6ad0456fa95ce2aece2b428e085320"
>>>         Missing separate debuginfo for /usr/lib64/libkrb5support.so.0
>>>         "debuginfo(build-id)=5e2403de3d110d7c06ef2d111df16b458521fcd2"
>>>         Missing separate debuginfo for /usr/lib64/libsasl2.so.3
>>>         "debuginfo(build-id)=759a9482d40bf68183e123300d666cda580d3ccc"
>>>         Missing separate debuginfo for /usr/lib64/libxcb.so.1
>>>         "debuginfo(build-id)=f452cb119f2b0a56cd2b9fda126731693c914619"
>>>         Missing separate debuginfo for /usr/lib64/libkeyutils.so.1
>>>         "debuginfo(build-id)=0fbaed7600db1edbbc687dfb885f47d958946b1c"
>>>         Missing separate debuginfo for /usr/lib64/libXau.so.6
>>>         "debuginfo(build-id)=9ad19a9b77ab3c7217d4e01f9d3369848a2a5d2e"
>>>         /usr/lib64/qt5/plugins/platforms/libqxcb.so
>>>         "debuginfo(build-id)=1f8f5b53bfdc9b5caadfc9d8d8381a55c4f27b6a"
>>>         Missing separate debuginfo for /usr/lib64/libQt5XcbQpa.so.5
>>>         "debuginfo(build-id)=574d2ce016210d5cd3f8c612653301f799831466"
>>>         Missing separate debuginfo for /usr/lib64/libfontconfig.so.1
>>>         "debuginfo(build-id)=3ac41d743c1c3e1c3bc27e7a10929b03b5c954cd"
>>>         Missing separate debuginfo for /usr/lib64/libQt5DBus.so.5
>>>         "debuginfo(build-id)=84213703ef91c226b3d177b2025fe81ed6fb5c0e"
>>>         Missing separate debuginfo for /usr/lib64/libX11-xcb.so.1
>>>         "debuginfo(build-id)=0545e1949ffad8c4a789126170e1e4376503fe45"
>>>         Missing separate debuginfo for /usr/lib64/libXi.so.6
>>>         "debuginfo(build-id)=ceeab058dec326fc3505fe5d2bef69fd67cebf47"
>>>         Missing separate debuginfo for /usr/lib64/libSM.so.6
>>>         "debuginfo(build-id)=490891d1dcbd60b05902aa61bf9058ebdddac8cf"
>>>         Missing separate debuginfo for /usr/lib64/libICE.so.6
>>>         "debuginfo(build-id)=447ef3f4fa1bf8e88498e05625f2719631bc06eb"
>>>         Missing separate debuginfo for /usr/lib64/libxcb-xkb.so.1
>>>         "debuginfo(build-id)=75803fcdc925628dd2476992c3a96b5070adb7b3"
>>>         /usr/lib64/libxcb-render-util.so.0
>>>         "debuginfo(build-id)=dbc98d19b4474cc1757558d0f4402be59d0a3309"
>>>         Missing separate debuginfo for /usr/lib64/libxcb-render.so.0
>>>         "debuginfo(build-id)=d5668d121e372edd7b38067625be3b1d7077ddb9"
>>>         Missing separate debuginfo for /usr/lib64/libxcb-sync.so.1
>>>         "debuginfo(build-id)=25c7221346af63063ac54f7eb195ec5869540032"
>>>         Missing separate debuginfo for /usr/lib64/libxcb-xfixes.so.0
>>>         "debuginfo(build-id)=93cbec4d502369fa1942c2d47674bb4a8bc52f13"
>>>         Missing separate debuginfo for /usr/lib64/libxcb-xinerama.so.0
>>>         "debuginfo(build-id)=c0b6b30ece1944c8cf6f85f4a4afed7205bc2655"
>>>         Missing separate debuginfo for /usr/lib64/libxcb-randr.so.0
>>>         "debuginfo(build-id)=059aa8c00b4c54c66bb9f07db79906fd78bb5f96"
>>>         Missing separate debuginfo for /usr/lib64/libxcb-image.so.0
>>>         "debuginfo(build-id)=a2a8f1038082364579278a5acdc65341b8c043f7"
>>>         Missing separate debuginfo for /usr/lib64/libxcb-shm.so.0
>>>         "debuginfo(build-id)=944b7e1e36d2f5ec8bfe2ab76abf35d8a6ce220e"
>>>         Missing separate debuginfo for /usr/lib64/libxcb-keysyms.so.1
>>>         "debuginfo(build-id)=d65557a7d948f50280ef185837b97f2babbe4c82"
>>>         Missing separate debuginfo for /usr/lib64/libxcb-icccm.so.4
>>>         "debuginfo(build-id)=fb59991a8467fd61363124e41c1c7c9e0e9d1f56"
>>>         Missing separate debuginfo for /usr/lib64/libxcb-shape.so.0
>>>         "debuginfo(build-id)=3ec6ae47e663c25e670669ad7638b04f0b38e6cb"
>>>         Missing separate debuginfo for /usr/lib64/libxkbcommon-x11.so.0
>>>         "debuginfo(build-id)=3c7c720137a01053700412c63b1f4e747b32ebac"
>>>         Missing separate debuginfo for /usr/lib64/libxkbcommon.so.0
>>>         "debuginfo(build-id)=dc752531ef6dea01cde8ad3fec74ad4fb9dc42f1"
>>>         Missing separate debuginfo for /usr/lib64/libXext.so.6
>>>         "debuginfo(build-id)=fe1f9107049ede7c35286dab93700b798365b895"
>>>         Missing separate debuginfo for /usr/lib64/libuuid.so.1
>>>         "debuginfo(build-id)=0a2815953252f036958f3f043833e4d394ea18c8"
>>>         Missing separate debuginfo for /usr/lib64/libxcb-util.so.1
>>>         "debuginfo(build-id)=f7ac95970dca43ab33ad52ff08aaa668cd78ffd4"
>>>         Missing separate debuginfo for /usr/lib64/libXcursor.so.1
>>>         "debuginfo(build-id)=45886473becd10a9bf1705a7cff86d5276af76b1"
>>>         Missing separate debuginfo for /usr/lib64/libXrender.so.1
>>>         "debuginfo(build-id)=26742b2ff984147a2c7508148704b3cb2f752038"
>>>         Missing separate debuginfo for /usr/lib64/libXfixes.so.3
>>>         "debuginfo(build-id)=aa047315ac397f95aa829f479b1039b63aa05809"
>>>         /usr/lib64/qt5/plugins/xcbglintegrations/libqxcb-glx-integration.so
>>>         "debuginfo(build-id)=f88d07942e67292b9580a1d746e8e9d343e586af"
>>>         Missing separate debuginfo for /usr/lib64/libxcb-glx.so.0
>>>         "debuginfo(build-id)=6fe7632ac563fa6afc4f058d2b6c9b8bcbe9f44d"
>>>         /usr/lib64/qt5/plugins/platformthemes/libqgtk2.so
>>>         "debuginfo(build-id)=72b3ac22d02b403017e0d9fb23f72b89c1df1698"
>>>         Missing separate debuginfo for /usr/lib64/libgtk-x11-2.0.so.0
>>>         "debuginfo(build-id)=78a96e5e0d18aca5d63f07f1ba96418d654578b3"
>>>         Missing separate debuginfo for /usr/lib64/libgdk-x11-2.0.so.0
>>>         "debuginfo(build-id)=5d133f917df46cfeb3a1501c3fd85420f29077eb"
>>>         Missing separate debuginfo for /usr/lib64/libpango-1.0.so.0
>>>         "debuginfo(build-id)=4fd506f39a9b8b77760d0c1d287b99bf21a93644"
>>>         Missing separate debuginfo for /usr/lib64/libgobject-2.0.so.0
>>>         "debuginfo(build-id)=2af4acce680f8e44d6d27878702948d91220b82e"
>>>         Missing separate debuginfo for /usr/lib64/libgmodule-2.0.so.0
>>>         "debuginfo(build-id)=01fe244ff6ebb593a149f9e01e94848a5778ece2"
>>>         Missing separate debuginfo for /usr/lib64/libpangocairo-1.0.so.0
>>>         "debuginfo(build-id)=fa1d34a2085db3801a612741284dce89769b8d52"
>>>         Missing separate debuginfo for /usr/lib64/libatk-1.0.so.0
>>>         "debuginfo(build-id)=1761265526fc5fe25c8046334eed5696942df876"
>>>         Missing separate debuginfo for /usr/lib64/libcairo.so.2
>>>         "debuginfo(build-id)=6aaf1598f5797268dd29566f2c411bdfb45a46d1"
>>>         Missing separate debuginfo for /usr/lib64/libgdk_pixbuf-2.0.so.0
>>>         "debuginfo(build-id)=f6871d73e2b0d6eccaebe11cfd63a691013658e5"
>>>         Missing separate debuginfo for /usr/lib64/libgio-2.0.so.0
>>>         "debuginfo(build-id)=3f8d76f60fe8961f2499f0d9c3a5fbbbff220564"
>>>         Missing separate debuginfo for /usr/lib64/libpangoft2-1.0.so
>>>         <http://libpangoft2-1.0.so>.0
>>>         "debuginfo(build-id)=3029bae740e94a74913fdcab9fdda3f84f47b968"
>>>         Missing separate debuginfo for /usr/lib64/libXinerama.so.1
>>>         "debuginfo(build-id)=764d559bdc75ec52c17065bb5df95f7acff88473"
>>>         Missing separate debuginfo for /usr/lib64/libXrandr.so.2
>>>         "debuginfo(build-id)=b83f2e8882df57fe854139c84ea4a00697a8277d"
>>>         Missing separate debuginfo for /usr/lib64/libXcomposite.so.1
>>>         "debuginfo(build-id)=551fca4a9e6ac9bd7d90246692bfc4e2469940ff"
>>>         Missing separate debuginfo for /usr/lib64/libXdamage.so.1
>>>         "debuginfo(build-id)=4756f2ec5596947bebd4bd183557decba44fec6b"
>>>         Missing separate debuginfo for /usr/lib64/libthai.so.0
>>>         "debuginfo(build-id)=9c25e54f25d6784d415e8db48094f40052c0b0db"
>>>         Missing separate debuginfo for /usr/lib64/libffi.so.7
>>>         "debuginfo(build-id)=6a8e76464a8f8f17118793f0b43d45a226392039"
>>>         Missing separate debuginfo for /usr/lib64/libpixman-1.so.0
>>>         "debuginfo(build-id)=38b33ac1a1347aa0903444f36f96f4def77424f8"
>>>         Missing separate debuginfo for /usr/lib64/libEGL.so.1
>>>         "debuginfo(build-id)=48ee2deffee9609f2808ebc0a97bef0465aa5846"
>>>         Missing separate debuginfo for /usr/lib64/libmount.so.1
>>>         "debuginfo(build-id)=e2bb051ab7dbc168b1f2411965311ea20cef92b4"
>>>         Missing separate debuginfo for /usr/lib64/libdatrie.so.1
>>>         "debuginfo(build-id)=0d2835e1ddd1d8c86a887c19a38a5b4ae707fb59"
>>>         Missing separate debuginfo for /usr/lib64/libblkid.so.1
>>>         "debuginfo(build-id)=b394c5d746855f00a87c97ec173fc0ad7ea5ec14"
>>>         /usr/lib64/gtk-2.0/modules/libcanberra-gtk-module.so
>>>         "debuginfo(build-id)=132c4af6d309f7ee188f389e6a55dcfa1a162bfc"
>>>         Missing separate debuginfo for /usr/lib64/libcanberra-gtk.so.0
>>>         "debuginfo(build-id)=66436c1a352e91d57cb357d5956baf7ff4b7a864"
>>>         Missing separate debuginfo for /usr/lib64/libcanberra.so.0
>>>         "debuginfo(build-id)=9a6346b2ba4e6a5a0f910321eef2d6bd5e2a4054"
>>>         Missing separate debuginfo for /usr/lib64/libvorbisfile.so.3
>>>         "debuginfo(build-id)=ab6cd4515ea838342503b6b49f0a10ca3cc6f99b"
>>>         Missing separate debuginfo for /usr/lib64/libvorbis.so.0
>>>         "debuginfo(build-id)=3b9fc3187161236530cf16a311af84159ca6cf10"
>>>         Missing separate debuginfo for /usr/lib64/libogg.so.0
>>>         "debuginfo(build-id)=a1ba55e2e3236d160e3d7facdd56f5201c5d3075"
>>>         /usr/lib64/gtk-2.0/2.10.0/engines/libadwaita.so
>>>         "debuginfo(build-id)=1b0601f6ecbef3211dc72a57c43805043b6826d7"
>>>         /usr/lib64/gtk-2.0/2.10.0/engines/libpixmap.so
>>>         "debuginfo(build-id)=5ef566f06bf5709e8cf90060a4408a2290ecb1a4"
>>>         /usr/lib64/qt5/plugins/platforminputcontexts/libibusplatforminputcontextplugin.so
>>>         "debuginfo(build-id)=bf29e473497b05ce7ea117dffe08074784f23b3b"
>>>         0x00007f3acc786da7 in waitpid () from /lib64/libc.so.6
>>>         [Current thread is 1 (Thread 0x7f3ad6c6b940 (LWP 17857))]
>>>         #0  0x00007f3acc786da7 in waitpid () at /lib64/libc.so.6
>>>         #1  0x000000000040cd55 in qgisCrash(int) ()
>>>         #2  0x00007f3acc6f7160 in <signal handler called> () at
>>>         /lib64/libc.so.6
>>>         #3  0x00007f3aca9255f9 in QReadWriteLock::QReadWriteLock()
>>>         () at /usr/lib64/libQtCore.so.4
>>>         #4  0x00007f3aca68180c in  () at /usr/lib64/libQtDBus.so.4
>>>         const&, void*)) () at /usr/lib64/libQtDBus.so.4
>>>         #6  0x00007f3ab2a86086 in  () at
>>>         #7  0x00007f3ad12e6110 in
>>>         QPlatformInputContextFactory::create(QString const&) () at
>>>         #8  0x00007f3abf97d5ad in QXcbIntegration::initialize() ()
>>>         at /usr/lib64/libQt5XcbQpa.so.5
>>>         #9  0x00007f3ad12fc539 in
>>>         QGuiApplicationPrivate::eventDispatcherReady() () at
>>>         #10 0x00007f3acd5f04e5 in QCoreApplicationPrivate::init() ()
>>>         at /usr/lib64/libQt5Core.so.5
>>>         #11 0x00007f3ad12fdd5c in QGuiApplicationPrivate::init() ()
>>>         at /usr/lib64/libQt5Gui.so.5
>>>         #12 0x00007f3ad1ac5999 in QApplicationPrivate::init() () at
>>>         #13 0x00007f3ad314e4a4 in
>>>         QgsApplication::QgsApplication(int&, char**, bool, QString
>>>         const&, QString const&) () at
>>>         /usr/local/lib/libqgis_core.so.3.0.3
>>>         #14 0x000000000040f716 in main ()
>>>         gdb returned 0
>>>         Aborted (core dumped)
>>>         _______________________________________________
>>>         Qgis-user mailing list
>>>         Qgis-user at lists.osgeo.org <mailto:Qgis-user at lists.osgeo.org>
>>>         List info:
>>>         https://lists.osgeo.org/mailman/listinfo/qgis-user
>>>         <https://lists.osgeo.org/mailman/listinfo/qgis-user>
>>>         Unsubscribe:
>>>     Alessandro Pasotti
>>>     w3: www.itopen.it <http://www.itopen.it>
>>     List info:https://lists.osgeo.org/mailman/listinfo/qgis-user
>>     Unsubscribe:https://lists.osgeo.org/mailman/listinfo/qgis-user
>     List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>     Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
> Alessandro Pasotti
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20180618/18da323d/attachment.html>
