[Qgis-user] QGIS 3.0.3 died on signal 11: what did go wrong? [SOLVED]
Patrick Dunford
enzedrailmaps at gmail.com
Mon Jun 18 10:47:27 PDT 2018
The case of which version of QT the software is being built against is
specifically addressed in the BUILD documentation. It has been possible
in previous versions of the software to build against either QT4 or QT5.
On 19/06/18 04:15, HernĂ¡n De Angelis wrote:
> Thank you, Alessandro, you contributed a lot by pointing out that I
> was wrongly linking to qt4.
> I will have a look to these docs. Perhaps the most important thing is
> to make a reminder to ensure that qmake and dependencies shall not
> link to qt4. This is arguably obvious, but it is easy to overlook. It
> is also not so easy to fix if one is not at least a bit involved in
> Linux programming or sysadmin.
> The ideal solution would be to link all standard libraries to qt5
> directly in openSUSE, but that's another story and will probably brake
> other things.
> H.
