[Qgis-user] trying to convert geotiff UTM toWGS84
Eric Fielding
Eric.J.Fielding at jpl.nasa.gov
Mon Jun 18 08:29:48 PDT 2018
If you want to change the projection of a raster image in QGIS, you need do a
reprojection by using the Raster->Projections->Warp (reproject) command that
sets up and runs the "gdalwarp" command. The "gdal_translate" command only
changes the format of a raster image. You have to use "gdalwarp" to do the
reprojection into a different projection.
++Eric
Sent from: http://osgeo-org.1560.x6.nabble.com/QGIS-User-f4125267.html
