[Qgis-user] Irregular map frame with transparent mask?
Frank Broniewski
hallo at frankbroniewski.com
Tue Jun 19 23:39:11 PDT 2018
The process in this video is really outdated, there’s an „inverted polygon“ renderer which does the same without having to go through all the hassle. You can find the renderer where you „select single symbol“, „categorized“ etc.
HHT
Frank
Dipl. Geogr. Frank Broniewski
Waldhölzbacher Str. 51
66679 Losheim am See
06872 509 068 4
0176 611 26 9 2 6
<http://www.frankbroniewski.com> www.frankbroniewski.com
Von: Qgis-user <qgis-user-bounces at lists.osgeo.org> Im Auftrag von Phil Wyatt
Gesendet: Mittwoch, 20. Juni 2018 03:47
An: 'Alexandre Neto' <senhor.neto at gmail.com>; 'QGIS User' <qgis-user at lists.osgeo.org>
Betreff: Re: [Qgis-user] Irregular map frame with transparent mask?
Does this video show what you want to achieve?
https://www.youtube.com/watch?v=6h5kT2--xBM
Cheers - Phil
From: Qgis-user [mailto:qgis-user-bounces at lists.osgeo.org] On Behalf Of Alexandre Neto
Sent: Wednesday, 20 June 2018 4:20 AM
To: QGIS User
Subject: [Qgis-user] Irregular map frame with transparent mask?
I am looking for a way to create a map with an irregular (non-rectangle) frame.
There is blog post from Anita showing how to do it but it needs a white mask all around the map. While I need it to be transparent.
I don't think this is possible yet without going the SVGs way, but maybe someone have so cool trick to share.
Thanks
Alexandre Neto
@AlexNetoGeo
http://sigsemgrilhetas.wordpress.com
http://gisunchained.wordpress.com
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20180620/76e86f68/attachment.html>
Type: application/pkcs7-signature
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20180620/76e86f68/attachment.bin>
