[Qgis-user] Irregular map frame with transparent mask?
Richard Duivenvoorde
rdmailings at duif.net
Wed Jun 20 00:56:33 PDT 2018
Works like a charm.
Thanks Frank for the tip! Quick and easy:
- copy a feature
- paste as memory layer
- put it on top
- choose 'Inverted polygons' as Symbology
- fiddle with transparency
Is worth a blog post somewhere if you ask me :-)
Regards,
On 20-06-18 08:39, Frank Broniewski wrote:
> The process in this video is really outdated, there’s an „inverted
> polygon“ renderer which does the same without having to go through all
> the hassle. You can find the renderer where you „select single symbol“,
> „categorized“ etc.
> HHT
> Frank
> Dipl. Geogr. Frank Broniewski
> Waldhölzbacher Str. 51
> 66679 Losheim am See
> 06872 509 068 4
> 0176 611 26 9 2 6
> www.frankbroniewski.com <http://www.frankbroniewski.com>
> *Von:*Qgis-user <qgis-user-bounces at lists.osgeo.org> *Im Auftrag von
> *Phil Wyatt
> *Gesendet:* Mittwoch, 20. Juni 2018 03:47
> *An:* 'Alexandre Neto' <senhor.neto at gmail.com>; 'QGIS User'
> <qgis-user at lists.osgeo.org>
> *Betreff:* Re: [Qgis-user] Irregular map frame with transparent mask?
> Does this video show what you want to achieve?
> https://www.youtube.com/watch?v=6h5kT2--xBM
> Cheers - Phil
> *From:*Qgis-user [mailto:qgis-user-bounces at lists.osgeo.org] *On Behalf
> Of *Alexandre Neto
> *Sent:* Wednesday, 20 June 2018 4:20 AM
> *To:* QGIS User
> *Subject:* [Qgis-user] Irregular map frame with transparent mask?
> Hi,
> I am looking for a way to create a map with an irregular (non-rectangle)
> frame.
> There is blog post from Anita showing how to do it but it needs a white
> mask all around the map. While I need it to be transparent.
> I don't think this is possible yet without going the SVGs way, but maybe
> someone have so cool trick to share.
> Thanks
> Alexandre Neto
> @AlexNetoGeo
> http://sigsemgrilhetas.wordpress.com
> http://gisunchained.wordpress.com
> Qgis-user mailing list
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20180620/9d0d07be/attachment.jpg>
