[Qgis-user] Delete key does not remove item in composer
Frank Broniewski
hallo at frankbroniewski.com
Wed Jun 27 02:08:19 PDT 2018
Ok,
Windows 10 (and AFAIR Win7 also) with QGIS 2.18 & 3.0 & 3.2 OSGeo4W-Installation (32bit & 64bit). The DELETE key never worked …
Before reading this thread I never assumed it should work, although by habit I press it always before noticing that it doesn’t do anything. I always used the menu or backspace afterwards …
Von: DelazJ <delazj at gmail.com>
Gesendet: Mittwoch, 27. Juni 2018 11:02
An: Frank Broniewski <hallo at frankbroniewski.com>
Cc: Bernhard Ströbl <bernhard.stroebl at jena.de>; Qgis-user at lists.osgeo.org
Betreff: Re: [Qgis-user] Delete key does not remove item in composer
Let's not be so categorical and please, indicate also the platform you are working on. I've reported a bug long time ago (QGIS 2.8) about macOS https://issues.qgis.org/issues/12874
Checking right now, I can say that:
- on macOS, QGIS 2.18.0, both buttons do delete composer items
- on Windows 10, using QGIS 2.18.21 and 3.3, both buttons do the same thing.
Maybe, there are some local settings that interfere but on my side, documentation looks right.
Regards,
Harrissou
2018-06-27 10:30 GMT+02:00 Frank Broniewski <hallo at frankbroniewski.com <mailto:hallo at frankbroniewski.com> >:
I just want to confirm that DELETE never worked for me (can't recall it ever did), BACKSPACE does though.
Frank
Dipl. Geogr. Frank Broniewski
Waldhölzbacher Str. 51
66679 Losheim am See
06872 509 068 4
0176 611 26 9 2 6
www.frankbroniewski.com <http://www.frankbroniewski.com>
-----Ursprüngliche Nachricht-----
Von: Qgis-user <qgis-user-bounces at lists.osgeo.org <mailto:qgis-user-bounces at lists.osgeo.org> > Im Auftrag von Bernhard Ströbl
Gesendet: Mittwoch, 27. Juni 2018 10:25
An: Qgis-user at lists.osgeo.org <mailto:Qgis-user at lists.osgeo.org>
Betreff: [Qgis-user] Delete key does not remove item in composer
Hi all,
the documentation [1] states that for removing an item in composer one can either use Backspace or Delete. However Delete does not work for me :-( Is there anything I am missing?
Tried:
QGIS 2.18.20 on Win7 and Ubuntu 16.04, QGIS 3.2 on Ubuntu 16.04
[1]
https://docs.qgis.org/2.18/en/docs/user_manual/print_composer/overview_composer.html
Bernhard
__________ Information from ESET Mail Security, version of virus signature database 17619 (20180627) __________
The message was checked by ESET Mail Security.
http://www.eset.com
Qgis-user mailing list
List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20180627/16bb6635/attachment.html>
Type: application/pkcs7-signature
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20180627/16bb6635/attachment.bin>
