[Qgis-user] Delete key does not remove item in composer
    Stefan Giese
    Stefan.Giese at wheregroup.com
    Wed Jun 27 02:10:38 PDT 2018
Hi all,
same with me: DELETE never worked (Win7, before XP) various QGIS
versions (QGIS 2.x up to QGIS 3.x)
best regards
stefan
Mit freundlichen Grüßen
Stefan Giese
Projektleiter/Consultant
AGIT 2018
4.- 6. Juli 2018 in Salzburg
Treffen Sie die WhereGroup bei der AGIT EXPO
http://www.agit.at/
WhereGroup GmbH & Co. KG
Schwimmbadstr. 2
79100 Freiburg
Germany
Fon: +49 (0)761 / 519 102 - 61
Fax: +49 (0)761 / 519 102 - 11
stefan.giese at wheregroup.com
www.wheregroup.com
Amtsgericht Bonn, HRA 6788
Komplementärin:
WhereGroup Verwaltungs GmbH
vertreten durch:
Olaf Knopp, Peter Stamm
Am 27.06.2018 um 11:08 schrieb Frank Broniewski:
> Ok,
> Windows 10 (and AFAIR Win7 also) with QGIS 2.18 & 3.0 & 3.2
> OSGeo4W-Installation (32bit & 64bit). The DELETE key never worked …
> Before reading this thread I never assumed it should work, although by
> habit I press it always before noticing that it doesn’t do anything. I
> always used the menu or backspace afterwards …
> *Von:* DelazJ <delazj at gmail.com>
> *Gesendet:* Mittwoch, 27. Juni 2018 11:02
> *An:* Frank Broniewski <hallo at frankbroniewski.com>
> *Cc:* Bernhard Ströbl <bernhard.stroebl at jena.de>;
> *Betreff:* Re: [Qgis-user] Delete key does not remove item in composer
> Hi,
> Let's not be so categorical and please, indicate also the platform you
> are working on. I've reported a bug long time ago (QGIS 2.8) about
> macOS https://issues.qgis.org/issues/12874
> Checking right now, I can say that:
> - on macOS, QGIS 2.18.0, both buttons do delete composer items
> - on Windows 10, using QGIS 2.18.21 and 3.3, both buttons do the same
> thing.
> Maybe, there are some local settings that interfere but on my side,
> documentation looks right.
> Regards,
> Harrissou
> 2018-06-27 10:30 GMT+02:00 Frank Broniewski <hallo at frankbroniewski.com
> <mailto:hallo at frankbroniewski.com>>:
>     Hi,
>     I just want to confirm that DELETE never worked for me (can't
>     recall it ever did), BACKSPACE does though.
>     Frank
>     Dipl. Geogr. Frank Broniewski
>     Waldhölzbacher Str. 51
>     66679 Losheim am See
>     06872 509 068 4
>     0176 611 26 9 2 6
>     www.frankbroniewski.com <http://www.frankbroniewski.com>
>     -----Ursprüngliche Nachricht-----
>     Von: Qgis-user <qgis-user-bounces at lists.osgeo.org
>     <mailto:qgis-user-bounces at lists.osgeo.org>> Im Auftrag von
>     Bernhard Ströbl
>     Gesendet: Mittwoch, 27. Juni 2018 10:25
>     An: Qgis-user at lists.osgeo.org <mailto:Qgis-user at lists.osgeo.org>
>     Betreff: [Qgis-user] Delete key does not remove item in composer
>     Hi all,
>     the documentation [1] states that for removing an item in composer
>     one can either use Backspace or Delete. However Delete does not
>     work for me :-( Is there anything I am missing?
>     Tried:
>     QGIS 2.18.20 on Win7 and Ubuntu 16.04, QGIS 3.2 on Ubuntu 16.04
>     [1]
>     https://docs.qgis.org/2.18/en/docs/user_manual/print_composer/overview_composer.html
>     Bernhard
>     __________ Information from ESET Mail Security, version of virus
>     signature database 17619 (20180627) __________
>     The message was checked by ESET Mail Security.
>     http://www.eset.com
>     _______________________________________________
>     Qgis-user mailing list
>     List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>     Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20180627/3de12d98/attachment.html>
