[Qgis-user] Delete key does not remove item in composer
Frank Broniewski
hallo at frankbroniewski.com
Wed Jun 27 02:22:01 PDT 2018
Good catch! Never occurred to me that this could be a language issue
-----Ursprüngliche Nachricht-----
Von: Richard Duivenvoorde <rdmailings at duif.net>
Gesendet: Mittwoch, 27. Juni 2018 11:16
An: Frank Broniewski <hallo at frankbroniewski.com>; Alexandre Neto <senhor.neto at gmail.com>; DelazJ <delazj at gmail.com>
Cc: Qgis-user at lists.osgeo.org
Betreff: Re: [Qgis-user] Delete key does not remove item in composer
I can reproduce:
in english both keys work, but if I start QGIS in German:
qgis3 --lang de
then only backspace works, del does not
(My OS is Debian english, US keyboard, LANGUAGE=en_US:en
Please create an issue for it (and preferably try some other languages too :-) )
Regards,
Richard
On 06/27/2018 11:12 AM, Frank Broniewski wrote:
> Just tried, but to no avail (QGIS 3.2, OSGeo4W64, Windows 10)
> I renamed my profile, started QGIS, created an empty composer, drew a
> rectangle and tried to delete it with DEL – does not work, BACKSPACE
> does
> *Von:* Alexandre Neto <senhor.neto at gmail.com>
> *Gesendet:* Mittwoch, 27. Juni 2018 11:08
> *An:* DelazJ <delazj at gmail.com>
> *Cc:* Frank Broniewski <hallo at frankbroniewski.com>;
> *Betreff:* Re: [Qgis-user] Delete key does not remove item in composer
> Hi,
> On Linux, version 3.2 works as expected, both DELETE and Backspace
> remove layout composer items
> Can you try to use a clean settings profile and check again?
> DelazJ <delazj at gmail.com <mailto:delazj at gmail.com>> escreveu no dia
> quarta, 27/06/2018 às 10:02:
> Hi,
> Let's not be so categorical and please, indicate also the platform
> you are working on. I've reported a bug long time ago (QGIS 2.8)
> about macOS https://issues.qgis.org/issues/12874
> Checking right now, I can say that:
> - on macOS, QGIS 2.18.0, both buttons do delete composer items
> - on Windows 10, using QGIS 2.18.21 and 3.3, both buttons do the
> same thing.
> Maybe, there are some local settings that interfere but on my side,
> documentation looks right.
> Regards,
> Harrissou
> 2018-06-27 10:30 GMT+02:00 Frank Broniewski
> <hallo at frankbroniewski.com <mailto:hallo at frankbroniewski.com>>:
> Hi,
> I just want to confirm that DELETE never worked for me (can't
> recall it ever did), BACKSPACE does though.
> Frank
> Dipl. Geogr. Frank Broniewski
> Waldhölzbacher Str. 51
> 66679 Losheim am See
> 06872 509 068 4
> 0176 611 26 9 2 6
> www.frankbroniewski.com <http://www.frankbroniewski.com>
> Von: Qgis-user <qgis-user-bounces at lists.osgeo.org
> <mailto:qgis-user-bounces at lists.osgeo.org>> Im Auftrag von
> Bernhard Ströbl
> Gesendet: Mittwoch, 27. Juni 2018 10:25
> An: Qgis-user at lists.osgeo.org <mailto:Qgis-user at lists.osgeo.org>
> Betreff: [Qgis-user] Delete key does not remove item in
> composer
> Hi all,
> the documentation [1] states that for removing an item in
> composer one can either use Backspace or Delete. However Delete
> does not work for me :-( Is there anything I am missing?
> Tried:
> QGIS 2.18.20 on Win7 and Ubuntu 16.04, QGIS 3.2 on Ubuntu
> 16.04
> [1]
> https://docs.qgis.org/2.18/en/docs/user_manual/print_composer/overview
> _composer.html
> Bernhard
> __________ Information from ESET Mail Security, version of virus
> signature database 17619 (20180627) __________
> The message was checked by ESET Mail Security.
> http://www.eset.com
> Qgis-user mailing list
> Unsubscribe:
> Unsubscribe:
> Alexandre Neto
> @AlexNetoGeo
> http://sigsemgrilhetas.wordpress.com
> http://gisunchained.wordpress.com
Type: application/pkcs7-signature
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20180627/b93546ac/attachment.bin>
