[Qgis-user] Delete key does not remove item in composer
    Bernhard Ströbl
    bernhard.stroebl at jena.de
    Wed Jun 27 02:24:41 PDT 2018
done:
https://issues.qgis.org/issues/19281
Am 27.06.2018 um 11:16 schrieb Richard Duivenvoorde:
> I can reproduce:
> in english both keys work, but if I start QGIS in German:
> qgis3 --lang de
> then only backspace works, del does not
> (My OS is Debian english, US keyboard, LANGUAGE=en_US:en
> Please create an issue for it (and preferably try some other languages
> too :-) )
> Regards,
> Richard
> On 06/27/2018 11:12 AM, Frank Broniewski wrote:
>> Just tried, but to no avail (QGIS 3.2, OSGeo4W64, Windows 10)
>> I renamed my profile, started QGIS, created an empty composer, drew a
>> rectangle and tried to delete it with DEL – does not work, BACKSPACE does
>> *Von:* Alexandre Neto <senhor.neto at gmail.com>
>> *Gesendet:* Mittwoch, 27. Juni 2018 11:08
>> *An:* DelazJ <delazj at gmail.com>
>> *Cc:* Frank Broniewski <hallo at frankbroniewski.com>;
>> *Betreff:* Re: [Qgis-user] Delete key does not remove item in composer
>> Hi,
>> On Linux, version 3.2 works as expected, both DELETE and Backspace
>> remove layout composer items
>> Can you try to use a clean settings profile and check again?
>> DelazJ <delazj at gmail.com <mailto:delazj at gmail.com>> escreveu no dia
>> quarta, 27/06/2018 às 10:02:
>>      Hi,
>>      Let's not be so categorical and please, indicate also the platform
>>      you are working on. I've reported a bug long time ago (QGIS 2.8)
>>      about macOS https://issues.qgis.org/issues/12874
>>      Checking right now, I can say that:
>>      - on macOS, QGIS 2.18.0, both buttons do delete composer items
>>      - on Windows 10, using QGIS 2.18.21 and 3.3, both buttons do the
>>      same thing.
>>      Maybe, there are some local settings that interfere but on my side,
>>      documentation looks right.
>>      Regards,
>>      Harrissou
>>      2018-06-27 10:30 GMT+02:00 Frank Broniewski
>>      <hallo at frankbroniewski.com <mailto:hallo at frankbroniewski.com>>:
>>          Hi,
>>          I just want to confirm that DELETE never worked for me (can't
>>          recall it ever did), BACKSPACE does though.
>>          Frank
>>          Dipl. Geogr. Frank Broniewski
>>          Waldhölzbacher Str. 51
>>          66679 Losheim am See
>>          06872 509 068 4
>>          0176 611 26 9 2 6
>>          www.frankbroniewski.com <http://www.frankbroniewski.com>
>>          -----Ursprüngliche Nachricht-----
>>          Von: Qgis-user <qgis-user-bounces at lists.osgeo.org
>>          <mailto:qgis-user-bounces at lists.osgeo.org>> Im Auftrag von
>>          Bernhard Ströbl
>>          Gesendet: Mittwoch, 27. Juni 2018 10:25
>>          An: Qgis-user at lists.osgeo.org <mailto:Qgis-user at lists.osgeo.org>
>>          Betreff: [Qgis-user] Delete key does not remove item in composer
>>          Hi all,
>>          the documentation [1] states that for removing an item in
>>          composer one can either use Backspace or Delete. However Delete
>>          does not work for me :-( Is there anything I am missing?
>>          Tried:
>>          QGIS 2.18.20 on Win7 and Ubuntu 16.04, QGIS 3.2 on Ubuntu 16.04
>>          [1]
>>          https://docs.qgis.org/2.18/en/docs/user_manual/print_composer/overview_composer.html
>>          Bernhard
>>          __________ Information from ESET Mail Security, version of virus
>>          signature database 17619 (20180627) __________
>>          The message was checked by ESET Mail Security.
>>          http://www.eset.com
>>          _______________________________________________
>>          Qgis-user mailing list
>>          List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>>          Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
>> Alexandre Neto
>> @AlexNetoGeo
>> http://sigsemgrilhetas.wordpress.com
>> http://gisunchained.wordpress.com
__________ Information from ESET Mail Security, version of virus signature database 17619 (20180627) __________
http://www.eset.com
