[Qgis-user] Delete key does not remove item in composer
Frank Broniewski
hallo at frankbroniewski.com
Wed Jun 27 02:46:44 PDT 2018
I've tried all the locales in C:\OSGeo4W64\apps\qgis\i18n
And the following ones are affected (added already to the bug report)
ca
de
es
gl
hi
hu
km
nb
pt_BR
sl
zh-Hant
-----Ursprüngliche Nachricht-----
Von: Bernhard Ströbl <bernhard.stroebl at jena.de>
Gesendet: Mittwoch, 27. Juni 2018 11:25
An: richard at duif.net; Frank Broniewski <hallo at frankbroniewski.com>; Alexandre Neto <senhor.neto at gmail.com>; DelazJ <delazj at gmail.com>
Cc: Qgis-user at lists.osgeo.org
Betreff: Re: [Qgis-user] Delete key does not remove item in composer
done:
https://issues.qgis.org/issues/19281
Am 27.06.2018 um 11:16 schrieb Richard Duivenvoorde:
> I can reproduce:
> in english both keys work, but if I start QGIS in German:
> qgis3 --lang de
> then only backspace works, del does not
> (My OS is Debian english, US keyboard, LANGUAGE=en_US:en
> Please create an issue for it (and preferably try some other languages
> too :-) )
> Regards,
> Richard
> On 06/27/2018 11:12 AM, Frank Broniewski wrote:
>> Just tried, but to no avail (QGIS 3.2, OSGeo4W64, Windows 10)
>> I renamed my profile, started QGIS, created an empty composer, drew a
>> rectangle and tried to delete it with DEL – does not work, BACKSPACE
>> does
>> *Von:* Alexandre Neto <senhor.neto at gmail.com>
>> *Gesendet:* Mittwoch, 27. Juni 2018 11:08
>> *An:* DelazJ <delazj at gmail.com>
>> *Cc:* Frank Broniewski <hallo at frankbroniewski.com>;
>> *Betreff:* Re: [Qgis-user] Delete key does not remove item in
>> composer
>> Hi,
>> On Linux, version 3.2 works as expected, both DELETE and Backspace
>> remove layout composer items
>> Can you try to use a clean settings profile and check again?
>> DelazJ <delazj at gmail.com <mailto:delazj at gmail.com>> escreveu no dia
>> quarta, 27/06/2018 às 10:02:
>> Hi,
>> Let's not be so categorical and please, indicate also the platform
>> you are working on. I've reported a bug long time ago (QGIS 2.8)
>> about macOS https://issues.qgis.org/issues/12874
>> Checking right now, I can say that:
>> - on macOS, QGIS 2.18.0, both buttons do delete composer items
>> - on Windows 10, using QGIS 2.18.21 and 3.3, both buttons do the
>> same thing.
>> Maybe, there are some local settings that interfere but on my side,
>> documentation looks right.
>> Regards,
>> Harrissou
>> 2018-06-27 10:30 GMT+02:00 Frank Broniewski
>> <hallo at frankbroniewski.com <mailto:hallo at frankbroniewski.com>>:
>> Hi,
>> I just want to confirm that DELETE never worked for me (can't
>> recall it ever did), BACKSPACE does though.
>> Frank
>> Dipl. Geogr. Frank Broniewski
>> Waldhölzbacher Str. 51
>> 66679 Losheim am See
>> 06872 509 068 4
>> 0176 611 26 9 2 6
>> www.frankbroniewski.com <http://www.frankbroniewski.com>
>> Von: Qgis-user <qgis-user-bounces at lists.osgeo.org
>> <mailto:qgis-user-bounces at lists.osgeo.org>> Im Auftrag von
>> Bernhard Ströbl
>> Gesendet: Mittwoch, 27. Juni 2018 10:25
>> An: Qgis-user at lists.osgeo.org <mailto:Qgis-user at lists.osgeo.org>
>> Betreff: [Qgis-user] Delete key does not remove item in
>> composer
>> Hi all,
>> the documentation [1] states that for removing an item in
>> composer one can either use Backspace or Delete. However Delete
>> does not work for me :-( Is there anything I am missing?
>> Tried:
>> QGIS 2.18.20 on Win7 and Ubuntu 16.04, QGIS 3.2 on Ubuntu
>> 16.04
>> [1]
>> https://docs.qgis.org/2.18/en/docs/user_manual/print_composer/overvie
>> w_composer.html
>> Bernhard
>> __________ Information from ESET Mail Security, version of virus
>> signature database 17619 (20180627) __________
>> The message was checked by ESET Mail Security.
>> http://www.eset.com
>> Qgis-user mailing list
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe:
>> Unsubscribe:
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
>> Alexandre Neto
>> @AlexNetoGeo
>> http://sigsemgrilhetas.wordpress.com
>> http://gisunchained.wordpress.com
__________ Information from ESET Mail Security, version of virus signature database 17619 (20180627) __________
http://www.eset.com
Type: application/pkcs7-signature
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20180627/ecf17303/attachment.bin>
