[Qgis-user] qgis 3.2 attribute table thousand separator
    Michael Schulz
    mandschulz at googlemail.com
    Fri Jun 29 01:48:18 PDT 2018
short question: in the attribute table of a database (pg) query layer, that
has an integer field, the values are displayed with a thousand separator
(1.003 instead of 1003). Is this new in QGIS 3.2? It's kind of annoying,
because if you copy the value, the separator is copied as well, so you
cannot paste it and use it directly in another query...
Thanks, Michael
Michael Schulz
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20180629/0c575003/attachment.html>
